질문게시판 > 답변 : 답변 : SG90C
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 질문게시판
답변 : 답변 : SG90C
작성자 master 작성일18-12-18 15:31 조회2,957회 댓글0건
// DateTime : 2018-12-18 오후 3:36:47
#define F_CPU 16000000
#include <avr/io.h>
#include <stdio.h>
#include <util/delay.h>
#include <math.h>
#include <avr/interrupt.h>
#define LINE1       0x80 //첫번째 라인의 DDRAM address: 0x00->0x80+0x00
#define LINE2       0xC0 //두번째 라인의 DDRAM address: 0x40->0x80+0x40
#define MAX         4
//PG2=LCD_EN,PG1=RW,PG0=RS 에 연결
#define CMD_WRITE   0x09 //명령어쓰기 E=1,RW=0,RS=0 1
#define CMD_READ    0x0B //명령어읽기 E=1,RW=1,RS=0 1
#define DATA_WRITE  0x0D //데이터쓰기 E=1,RW=0,RS=1 1
#define DATA_READ   0x0F //데이터읽기 E=1,RW=1,RS=1 1
#define LCD_EN      0x01 //PG0에 연결되어 있기 때문에 bit2를 1로 했다.
void LCD_cmd_write(char cmd){
  PORTA=cmdPORTG=CMD_WRITEPORTG=PORTG^LCD_EN_delay_ms(2);
void LCD_data_write(char data){
  PORTA=dataPORTG=DATA_WRITEPORTG=PORTG^LCD_EN_delay_ms(2);
char rx_char(){ while((UCSR1A&0x80)==0); return UDR1; }
void tx_char(char t){ while((UCSR1A&0x20)==0); UDR1=t; }
void USART_SendString(char *s){ while(*s)tx_char(*s++); }
void LCD_wr_string(char d_line,char *s){ LCD_cmd_write(d_line); while(*s)LCD_data_write(*s++); }
void init_LCD(void){
  _delay_ms(15); LCD_cmd_write(0x38); LCD_cmd_write(0x38); LCD_cmd_write(0x38);
  LCD_cmd_write(0x08); LCD_cmd_write(0x01); LCD_cmd_write(0x06); LCD_cmd_write(0x0C);
void svangle1(float angle){
  unsigned int pulsepulse=angle*225/90+375+0.5OCR1A=pulse;
void svangle2(float angle){
  unsigned int pulsepulse=angle*225/90+375+0.5OCR1B=pulse;
unsigned int Echo1(){
  unsigned int range;
  PORTC=PORTC|0x01_delay_us(10); PORTC=PORTC&0xfe;
  while((PINC&4)==0); TCNT3=0TCCR3B=2;
  while(PINC&4); TCCR3B=8range=TCNT3/116;
  return range;
unsigned int Echo2(){
  unsigned int range;
  PORTC=PORTC|0x02_delay_us(10); PORTC=PORTC&0xfd;
  while((PINC&8)==0); TCNT3=0TCCR3B=2;
  while(PINC&8); TCCR3B=8range=TCNT3/116;
  return range;
void init_Echo(){
  TCCR3A=0TCCR3B=8_delay_ms(100);
int main(void){
  int flag=0,range[2]; char str[16];
  PORTA=0xFFDDRA=0xFF//LCD 데이터 버스
  PORTG=0x3FDDRG=0x7F//LCD 컨트롤 신호(PG2=LCD_EN,PG1=RW,PG0=RS)
  DDRC=0x03;
  DDRB=0xff;
  init_LCD();
  UCSR1B=0x18UBRR1L=0x67;
  TCCR1A=0xA2TCCR1B=0x1bICR1=4999;
  init_Echo();
    range[0]=Echo1(); //들어가는거 //차단
    if(range[0]<30){
      if(flag==0){ flag=1;
        LCD_wr_string(LINE1,str); USART_SendString("CW \r\n");
        PORTB|=1_delay_ms(1000); PORTB&=~1;
        svangle10); _delay_ms(500); // 정방향
        svangle1(90); _delay_ms(500); // 정지
    range[1]=Echo2(); //나가는거
    if(range[1]<30){
      if(flag==1){ flag=0;
        LCD_wr_string(LINE1,str); USART_SendString("CCW \r\n");
        PORTB|=4_delay_ms(1000); PORTB&=~4;
        svangle2(180); _delay_ms(500); // 역방향
        svangle2(90);  _delay_ms(500); // 정지
  • 카카오톡으로 보내기
댓글 : 0
조회수 : 2,957
BASIC4MCU > 질문게시판 목록
제목 날짜
질문 아두이노 센서 쉴드 v5.0 과 음성인식 모듈(V2)통… 첨부파일AutoSun 새글 17:58
질문 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니… 첨부파일뉴비에오 새글 22-07-04
답변 답변 : 초음파 센서를 사용한 dc모터 제어에 관해 질… 댓글[2] master 새글 10:56
질문 아두이노 Sensor Shield 5.0 시리얼 통신 … 댓글[2] AutoSun 새글 22-07-04
질문 Atmega 코드 좀 봐주세요. 댓글[1] 첨부파일chelsea 새글 22-07-04
PC버전
