질문게시판 > 답변 : 초음파 센서와 네오픽셀, 서버모터, GROVE MP3
TODAY684 TOTAL400,790
BASIC4MCU | 질문게시판 | 답변 : 초음파 센서와 네오픽셀, 서버모터, GROVE MP3
작성자 master 작성일2018-12-18 21:49 조회84회 댓글2건
// DateTime : 2018-12-18 오후 9:53:44
//--------------grove mp3 v2.0--------------------------
#include <SoftwareSerial.h>
#include <MP3Player_KT403A.h>
SoftwareSerial mp3(2,3);
static uint8_t recv_cmd[20];
  mp3.begin(9600);
  Serial.begin(9600); while(!Serial);
  Serial.println("Grove-Serial MP3 Demo");
  Serial.println(
  "Input command: \r\n\r\n"
  "P[]play music by default index\r\n"
  "Pm[]play music in MP3 folder by index\r\n"
  "Pf[][]play music by specify folder and index\r\n"
  "p Pause\r\n"
  "R Resume\r\n"
  "N Next\r\n"
  "L Previous\r\n"
  "l Loop\r\n"
  "I Increase volume\r\n"
  "D Decrease volumern\r\n");
  SelectPlayerDevice(0x02); // Select SD card as the player device.
  SetVolume(15); // 0~30
uint8_t len=0;
  uint8_t i;
  if(Serial.available()){
    byte chr=Serial.read(); // Serial.print(chr);
    if(chr=='\n'){
      recv_cmd[len]=0;
      // Print reveiced data
      // Serial.print("Received cmd: ");
      // for(i=0; i<len; i++){ Serial.print(recv_cmd[i]); Serial.print(" "); }
      // Serial.println();
      switch(recv_cmd[0]){
        case 'P':{
          if(recv_cmd[1]=='m'){ /***Play music in "MP3" folder by index*example: "Pm1"->./MP3/0001.mp3*/
            PlayMP3folder(recv_cmd[2]-'0');
            Serial.print("Play "); Serial.write(byte(recv_cmd[2])); Serial.println(".mp3 in MP3 folder");
          else if(recv_cmd[1]=='f'){ /***Play specify folder and music*example: "Pf11"->./01/001.mp3*/
            SpecifyfolderPlay(recv_cmd[2]-'0',recv_cmd[3]-'0');
            Serial.print("Play ");       Serial.write(byte(recv_cmd[3])); Serial.print("xxx.mp3");
            Serial.print(" in folder "); Serial.write(byte(recv_cmd[2])); Serial.println();
          else/***Play music by default index*example: "P1"->./***.mp3*/
            SpecifyMusicPlay(recv_cmd[1]-'0');
            Serial.print("Play xxx.MP3 by index "); Serial.write(byte(recv_cmd[1])); Serial.println();
          // Serial.println("Specify the music index to play");
        case 'p'PlayPause();      Serial.println("Pause the MP3 player");        break;
        case 'R'PlayResume();     Serial.println("Resume the MP3 player");       break;
        case 'N'PlayNext();       Serial.println("Play the next song");          break;
        case 'L'PlayPrevious();   Serial.println("Play the previous song");      break;
        case 'l'PlayLoop();       Serial.println("Play loop for all the songs"); break;
        case 'I'IncreaseVolume(); Serial.println("Increase volume");             break;
        case 'D'DecreaseVolume(); Serial.println("Decrease volume");             break;
      for(i=0;i<8;i++)recv_cmd[i]=0// clean data buffer
      len=0;
      recv_cmd[len++]=chr;
  // printReturnedData();
일단 위에 올린 mp3 소스를 정리 했습니다.
잘 동작하는지 체크 해보세요
조회수 84
손문일님의 댓글
손문일 작성일
    chr=Serial.read(); // Serial.print(chr);에서 에러 납니다.
오류메세지
sketch_dec18b:34:5: error: 'chr' was not declared in this scope
exit status 1
데이터형 선언이 빠져서 생긴 오류입니다.
수정했으니 다시 돌려보세요
질문 아두이노 AT커맨드 관련 질문입니다. 댓글[1] 까맣곰곰 18-12-26 76
질문 글을 늦게 봤습니다. 댓글[9] 첨부파일 누구냐 18-12-25 77
답변 답변글 답변 : 글을 늦게 봤습니다. master 18-12-25 49
답변 답변글 답변 : 글을 늦게 봤습니다. master 18-12-25 54
질문 코드 질문드립니다. 댓글[5] 누구냐 18-12-25 77
질문 신호파형입니다. 댓글[12] 이미지 고전압 18-12-25 86
질문 여쭤볼게 있습니다. 댓글[1] 고전압 18-12-24 44
질문 초음파 센서 기본소스 이해관련 댓글[2] 이미지 정기린 18-12-24 95
질문 적외선센서+LED 댓글[2] 코딩코딩 18-12-23 119
질문 초음파센서+네오픽셀+서보모터+grove mp3 손문일 18-12-23 98
답변 답변글 답변 : 초음파센서+네오픽셀+서보모터+grove mp3 master 18-12-23 105
답변 답변글 답변 : 답변 : 초음파센서+네오픽셀+서보모터+grove mp3 댓글[5] 첨부파일 손문일 18-12-23 104
답변 답변글 답변 : 답변 : 답변 : 초음파센서+네오픽셀+서보모터+grove mp3 댓글[1] 이미지 손문일 18-12-24 74
답변 답변글 답변 : 답변 : 답변 : 답변 : 초음파센서+네오픽셀+서보모터+grove mp3 댓글[2] 이미지 손문일 18-12-24 102
답변 답변글 답변 : 답변 : 답변 : 답변 : 초음파센서+네오픽셀+서보모터+grove mp3 master 18-12-29 78
질문 도트매트릭스에 글자가 안나옵니다. 첨부파일 은리스탈 18-12-23 63
답변 답변글 답변 : 도트매트릭스에 글자가 안나옵니다. master 18-12-23 59
질문 역전압 문제일까요?? 댓글[7] 이미지 무야더싱 18-12-22 101
질문 AVR소스코드 블루투스 댓글[2] 첨부파일 모모 18-12-21 99
질문 STM32F SDRAM 에서 Heap 및 Stack 을 사용하려면 댓글[1] MIB2 18-12-21 66
질문 Codevision에서 avr studio4 변환 질문입니다 댓글[3] 첨부파일 은리스탈 18-12-20 94
답변 답변글 답변 : Codevision에서 avr studio4 변환 질문입니다 master 18-12-21 70
답변 답변글 답변 : 답변 : Codevision에서 avr studio4 변환 질문입니다 첨부파일 은리스탈 18-12-22 59
답변 답변글 답변 : 답변 : 답변 : Codevision에서 avr studio4 변환 질문입니다 master 18-12-23 55
질문 초음파센서+네오픽셀+서보모터+grove mp3 댓글[5] 첨부파일 손문일 18-12-20 94
질문 atmega128 코드질문드려요 댓글[8] atmegaga 18-12-20 212
답변 답변글 답변 : atmega128 코드질문드려요 댓글[1] master 18-12-20 86
질문 서보모터 3개 동시제어하기 댓글[1] 심종현 18-12-20 102
질문 방수온도센서를 이용한 네오픽셀점등 구퓨리 18-12-20 50
답변 답변글 답변 : 방수온도센서를 이용한 네오픽셀점등 댓글[1] master 18-12-20 57
