질문게시판 > 답변 : 답변 : 초음파 센서와 네오픽셀, 서버모터, GROVE MP3
TODAY949 TOTAL605,578
BASIC4MCU | 질문게시판 | 답변 : 답변 : 초음파 센서와 네오픽셀, 서버모터, GROVE MP3
작성자 master 작성일2018-12-18 22:28 조회243회 댓글0건
// DateTime : 2018-12-18 오후 10:41:00
#include <SoftwareSerial.h>
#include <MP3Player_KT403A.h>
SoftwareSerial mp3(2,3);
#include <Adafruit_NeoPixel.h>
int  PIN=3;
Adafruit_NeoPixel strip=Adafruit_NeoPixel(60,PIN,NEO_GRB+NEO_KHZ800);
int echo=7,trig=6;
#include <Servo.h>
Servo servo1;
static uint8_t len=0,recv_cmd[20];
unsigned long sonar_time=0,servo_time=0,Neo_time=0;
int  cnt=0,i,pos=0;;
long distance=100;
  pinMode(trig,OUTPUT); pinMode(echo,INPUT);
  strip.begin(); strip.show();
  servo1.attach(9);
  mp3.begin(9600);
  Serial.begin(9600); while(!Serial);
  Serial.println("Grove-Serial MP3 Demo");
  Serial.println(
  "Input command: \r\n\r\n"
  "P[]play music by default index\r\n"
  "Pm[]play music in MP3 folder by index\r\n"
  "Pf[][]play music by specify folder and index\r\n"
  "p Pause\r\n"
  "R Resume\r\n"
  "N Next\r\n"
  "L Previous\r\n"
  "l Loop\r\n"
  "I Increase volume\r\n"
  "D Decrease volumern\r\n");
  SelectPlayerDevice(0x02); // Select SD card as the player device.
  SetVolume(15); // 0~30
bool flag=0;
  if(Serial.available()){
    byte chr=Serial.read(); // Serial.print(chr);
    if(chr=='\n'){
      recv_cmd[len]=0;
      // Print reveiced data
      // Serial.print("Received cmd: ");
      // for(i=0; i<len; i++){ Serial.print(recv_cmd[i]); Serial.print(" "); }
      // Serial.println();
      switch(recv_cmd[0]){
        case 'P':{
          if(recv_cmd[1]=='m'){ /***Play music in "MP3" folder by index*example: "Pm1"->./MP3/0001.mp3*/
            PlayMP3folder(recv_cmd[2]-'0');
            Serial.print("Play "); Serial.write(byte(recv_cmd[2])); Serial.println(".mp3 in MP3 folder");
          else if(recv_cmd[1]=='f'){ /***Play specify folder and music*example: "Pf11"->./01/001.mp3*/
            SpecifyfolderPlay(recv_cmd[2]-'0',recv_cmd[3]-'0');
            Serial.print("Play "); Serial.write(byte(recv_cmd[3])); Serial.print("xxx.mp3");
            Serial.print(" in folder "); Serial.write(byte(recv_cmd[2])); Serial.println();
          else/***Play music by default index*example: "P1"->./***.mp3*/
            SpecifyMusicPlay(recv_cmd[1]-'0');
            Serial.print("Play xxx.MP3 by index "); Serial.write(byte(recv_cmd[1])); Serial.println();
        case 'p'PlayPause(); Serial.println("Pause the MP3 player"); break;
        case 'R'PlayResume(); Serial.println("Resume the MP3 player"); break;
        case 'N'PlayNext(); Serial.println("Play the next song"); break;
        case 'L'PlayPrevious(); Serial.println("Play the previous song"); break;
        case 'l'PlayLoop(); Serial.println("Play loop for all the songs"); break;
        case 'I'IncreaseVolume(); Serial.println("Increase volume"); break;
        case 'D'DecreaseVolume(); Serial.println("Decrease volume"); break;
      for(i=0i<8i++)recv_cmd[i]=0// clean data buffer
      len=0;
    elserecv_cmd[len++]=chr; }
  if(millis()-sonar_time>=100){ sonar_time=millis();
    digitalWrite(trig,1); delayMicroseconds(10); digitalWrite(trig,0);
    distance=pulseIn(echo,HIGH)/58;
    Serial.print(distance); Serial.println(" Cm");
    if(distance<30){
      if(flag==0){ flag=1PlayMP3folder(1); }
      if(flag==1){ flag=0PlayPause(); }
  if(millis()-servo_time>=1000){ servo_time=millis();
    if(distance<30){ if(pos==0)pos=180else pos=0servo1.write(pos); }
  if(millis()-Neo_time>=10){ Neo_time=millis(); // 네오픽셀 딜레이 10ms
    if(distance<30){
      if(cnt<256)i=cnt;
      else if(cnt<512)i=511-cnt;
      if(++cnt>811)cnt=0;
      if(cnt<512){
        strip.setPixelColor(0,strip.Color(0,50,255));
        strip.setPixelColor(1,strip.Color(0,100,255));
        strip.setPixelColor(2,strip.Color(0,150,255));
        strip.setPixelColor(3,strip.Color(0,200,255));
        strip.setPixelColor(4,strip.Color(0,255,255));
        strip.setPixelColor(5,strip.Color(i,255-i,255-i));
        strip.setPixelColor(6,strip.Color(i,255,255-i));
        strip.setPixelColor(7,strip.Color(0,255,255)); //초록
        strip.setPixelColor(8,strip.Color(255,255,0)); //노랑
        strip.show();
    else// if(distance>30)
      cnt=0;
      strip.setPixelColor(0,strip.Color(255,50,0));
      strip.setPixelColor(1,strip.Color(255,100,0));
      strip.setPixelColor(2,strip.Color(255,150,0));
      strip.setPixelColor(3,strip.Color(255,200,0));
      strip.setPixelColor(4,strip.Color(255,255,0));
      strip.setPixelColor(5,strip.Color(255,255,0));
      strip.setPixelColor(6,strip.Color(255,255,0));
      strip.setPixelColor(7,strip.Color(255,255,0)); //초록
      strip.show();
조회수 243
질문 atmega128 스톱워치 질문있습니다.댓글[3] 이미지첨부파일 s공돌 19-06-06 174
질문 아두이노 등 질문있습니다 . 엽빵이 19-06-05 126
질문 아두이노 DFPlayer mini와 RFID 가나다 19-06-05 81
답변 답변글 답변 : 아두이노 DFPlayer mini와 RFID master 19-06-09 70
질문 아두이노 키패드와 블루투스를 이용한 금고 제작 명령어인데 작동이 안됩니다.댓글[2] 훈빵이 19-06-05 171
질문 아두이노 심박센서와 스피커댓글[3] 이채희 19-06-05 130
질문 아두이노 자동창문 코딩 해석좀 부탁드립니다. 나무늘보 19-06-05 79
질문 리모컨 초기설정에 따른 제어 방법 급히 여쭤봅니다 ㅠ 고수분들 부탁드려요 눙봅 19-06-05 75
질문 칵테일 머신 아두이노 컴파일 오류. 소방관 19-06-05 81
답변 답변글 답변 : 칵테일 머신 아두이노 컴파일 오류. master 19-06-09 72
질문 아두이노 LCD 판넬 이용댓글[1] 깈잌으 19-06-05 159
질문 네오픽셀과 인체 감지센서댓글[1] 손문일 19-06-05 94
질문 라즈베리파이 이용하여 스마트 작물 만들기 현꾸리다메 19-06-05 79
질문 아두이노 블루투스 연결방법 wait 19-06-04 115
답변 답변글 답변 : 아두이노 블루투스 연결방법 master 19-06-09 75
질문 무게센서를 4개정도 아두이노메가에 연결하고 싶습니다.댓글[1] 임베초보 19-06-04 99
질문 가스센서, 먼지센서, 서보모터, DC모터 관련 타이거 19-06-04 119
질문 세븐 세그먼트 출력이이상한문제(사진)상세 내용댓글[1] 첨부파일 바다조아 19-06-04 101
질문 atmega128 질문드립니다 깡용 19-06-04 126
답변 답변글 답변 : atmega128 질문드립니다 master 19-06-09 84
질문 스텝모터 (정방향+역방향) + 자기 리드 센서 acidrain 19-06-04 138
답변 답변글 답변 : 스텝모터 (정방향+역방향) + 자기 리드 센서 master 19-06-09 91
질문 아두이노 전력부족 관련 질문드립니다.댓글[1] 한쭈 19-06-04 127
질문 PWM 제어를 통해 팬 작동중 아두이노 재부팅 현상댓글[1] mjmj 19-06-04 130
질문 세븐 세그먼트 불빛이 안들어오는 문제댓글[2] 바다조아 19-06-04 121
질문 아두이노에서 시리얼 통신값으로 LED 50개에 각각 신호보내기 문의건댓글[1] 만불산 19-06-04 132
질문 시리얼통신, FND 바바바사옹 19-06-04 138
답변 답변글 답변 : 시리얼통신, FND master 19-06-09 57
질문 함수관련하여 질문하나 드립니다.댓글[1] 배우자 19-06-03 63
질문 아두이노 보드와 초음파 모듈 연결 관련 질문드립니다댓글[3] 이미지첨부파일 한쭈 19-06-03 125
