질문게시판 > 답변 : 도어락 소스코드 오류수정 부탁드려요..
TODAY470 TOTAL2,696,349
BASIC4MCU | 질문게시판 | 답변 : 도어락 소스코드 오류수정 부탁드려요..
작성자 master 작성일2018-12-18 22:59 조회11,972회 댓글3건
// DateTime : 2018-12-18 오후 11:31:08
#include <mega128.h>
#include <delay.h>
#include <stdio.h>
#include <alcd.h>
#define  BYTE unsigned char
unsigned char key;
int  key_IN[4];                        //입력되는 키값 저장배열
int  sec_num[4]={0x33,0x31,0x32,0x31}; //비밀번호
int  arr_cnt=1,right=1;                //비밀번호 검사를 위한 변수 선언
int  g=0,s=0;                          //비밀번호 검사를 위한 변수선언
char i=0;                              //LCD출력을 위한 변수
//flash BYTE seg_hexfont[2]={0xc0,0xbf};
BYTE FND_selector[3]={0xBF,0xDF,0xEF};
BYTE seg_data[3]={0xbf,0xbf,0xbf};
unsigned char KeyCheck(void){
  PORTE=0x10delay_ms(1);
  if     (PINE.4)return 0x30// 0
  else if(PINE.5)return 0x34// 4
  else if(PINE.6)return 0x38// 8
  else if(PINE.7)return 0x41// A
  PORTE=0x20delay_ms(1);
  if     (PINE.4)return 0x31// 1
  else if(PINE.5)return 0x35// 5
  else if(PINE.6)return 0x39// 9
  else if(PINE.7)return 0x42// B
  PORTE=0x40delay_ms(1);
  if     (PINE.4)return 0x32// 2
  else if(PINE.5)return 0x36// 6
  else if(PINE.6)return 0x2a// *
  else if(PINE.7)return 0x43// C
  PORTE=0x80delay_ms(1);
  if     (PINE.4)return 0x33// 3
  else if(PINE.5)return 0x37// 7
  else if(PINE.6)return 0x23// #
  else if(PINE.7)return 0x44// D
  return 0xff;
void sec_test(){
  if(arr_cnt==8){
    for(g=0g<8g++){
      if(key_IN[g]==sec_num[g])right++;
    if(right==8){
      lcd_clear(); lcd_gotoxy(0,0); lcd_puts("open"); delay_ms(500);
      lcd_clear(); lcd_gotoxy(0,0); lcd_puts("password");
      PORTC=seg_data[1]; PORTD=FND_selector[2];
      arr_cnt=1right=1g=0s=0i=0;
      lcd_clear(); lcd_gotoxy(0,0); lcd_puts("RETRY"); delay_ms(500);
      lcd_clear(); lcd_gotoxy(0,0); lcd_puts("password"); // LCD의 첫번째 라인
      PORTC=seg_data[2]; PORTD=FND_selector[2];
interrupt[EXT_INT4]void RETRY(void){ lcd_clear(); lcd_puts("password"); }
interrupt[EXT_INT5]void sw5(void){ lcd_gotoxy(0,0); lcd_puts("1"); }
interrupt[EXT_INT6]void sw6(void){ lcd_gotoxy(0,1); lcd_puts("2"); }
interrupt[EXT_INT7]void sw7(void){ lcd_gotoxy(0,2); lcd_puts("3"); }
void main(void){
  PORTA=0xFFDDRA=0xFF// PORTA 출력
  PORTC=0xFFDDRC=0xFF// PORTC 출력
  PORTD=0xFFDDRD=0xFF// PORTD 출력
  lcd_clear();
  lcd_gotoxy(0,0); lcd_putsf("password");  delay_ms(100);
  DDRE=0xff;
  EICRB=0xffEIFR|=0xf0EIMSK=0x0f// 상승 에지
  SREG=0x80;
    key=KeyCheck();
    if(key!=0xff){
      lcd_gotoxy(i,1);  delay_ms(1000);
      lcd_putchar(key); delay_ms500);
      if(i<15)i++;
      sec_test();
PE4~PE7은 키 스캔 입력, 키스캔 출력, 외부인터럽트 등 몇군데에서 사용하고 있습니다.
출력에 스위치를 연결하면 고장납니다.
회로도 참고해서 수정하세요
다른 부분도 잘 체크하세요
댓글 3
조회수 11,972
rkdeh님의 댓글
rkdeh 작성일
Error: C:\Users\user\Desktop\Debug\List\b.asm(1735): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1736): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1758): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1759): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1762): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1765): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1767): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1769): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1778): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1779): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1781): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1788): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1792): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1799): Undefined symbol: __lcd_port
Error: C:\Users\user\Desktop\Debug\List\b.asm(1865): Undefined symbol: __lcd_port
이렇게 에러가 나오면서 error ocurred during assembly 라고 뜨는데 어떻게 처리해야 될까요??
프로젝트옵션/c컴파일러/라이브러리/LCD 라이브러리에서
체크하고
LCD 포트를 지정해줘야합니다.
평가버전이라면 라이브러리 사용하지 못합니다.
왼쪽 카테고리에서 디스플레이/LCD 게시판에서 LCD 예제를 참고하세요
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 19704
공지 사이트 이용 안내댓글[28] master 17-10-29 34155
질문 atmega128 uart 질문입니다. bme12 23-06-05 25
질문 ATMEGA128 혹시 여기서 왜 인터럽트 기능이 안되는지 알 수 있나요 IEEE 23-06-04 34
질문 lora 무선 모듈에 관한 질문입니다.댓글[1] 로이스10 23-06-01 23
질문 초음파 센서를 이용한 인원 카운팅댓글[1] 초음파야 23-05-31 39
답변 답변글 답변 : 아두이노 타이머 인터럽트댓글[7] master 23-05-30 56
질문 앱인벤터 아두이노 보드 LCD 글씨 나타내기 질문댓글[7] 이미지 당찬병아리 23-05-29 52
질문 atmega128 led와 fan댓글[3] 이라 23-05-28 56
