BASIC4MCU | 질문게시판 | atmega128fh 라인트레이서 제작중 방향 문제에 관해서
작성자 라이언과어피치 작성일2018-12-19 04:15 조회3,164회 댓글0건본문
안녕하세요 라인트레이서 제작중인 학생입니다.
서툴지만 직진은 가능하나 좌우회전이 안됩니다.
돌아도 크게 돕니다. 다음은 사용중인 코드인데
어느 부분을 수정하면 좋을지 조언부탁드립니다.
참고로 발광센서는 세 쌍을 사용중입니다.
typedef unsigned int WORD;
typedef unsigned char BYTE;
#define SenserNum 3
#define BAUD_38400 25
WORD speed_L;
WORD speed_R;
WORD ADC_Data[SenserNum+1];
int state;
int count_R,count_L,CrossCount,StopState;
int Left_Sum,Right_Sum,Center_Sum;
//int count_R = 0;
//int count_L = 0;
//unsigned char left_motor[8] = { 0x55, 0x11, 0x99, 0x88, 0xaa, 0x22, 0x66, 0x44};
//unsigned char right_motor[8]
//unsigned char left_motor[8] = { 0x11,0x55,0x44,0x66,0x22,0xaa,0x88,0x99}; //1-2 Phase Control Method
//unsigned char right_motor[8] = { 0x99,0x88,0xaa,0x22,0x66,0x44,0x55,0x11};
unsigned char left_motor[8] = {0x99,0x88,0xcc,0x44,0x66,0x22,0x33,0x11};
unsigned char right_motor[8] = {0x11,0x33,0x22,0x66,0x44,0xcc,0x88,0x99};
//unsigned char left_motor_count;
//unsigned char right_motor_count;
void PORT_init(void)
DDRE = DDRF = DDRG = 0; //Set port to input direction first.
PORTA = PORTB = PORTC = PORTD = PORTE = PORTF = PORTG = 0x00; //
DDRA = 0XFF;
DDRB = 0xFF;
DDRC = 0xFF;
DDRE = 0xFF;
DDRD = 0xFF;
PORTC = 0xFF;
PORTD = 0xFF;
void ADC_init(void)
ADMUX = 0;
ADCSRA = (1<<ADEN)|(1<<ADFR)|(1<<ADSC)|(1<<ADIE)|(1<<ADPS2)|(ADPS1)|(1<<ADPS0);
for(int i =0; i<SenserNum; i++)
ADC_Data[i]=0;
void Timer_init(void)
TCCR1B = (1<<CS10);
TCNT1 = speed_R;
TCCR3B = (1<<CS30);
TCNT3 = speed_L;
TIMSK = (1<<TOIE1);
ETIMSK = (1<<TOIE3);
void Delay_us(unsigned char time_us)
register unsigned char i;
for(i = 0; i < time_us; i++) {
asm (" PUSH R0 ");
asm (" POP R0 ");
asm (" PUSH R0 ");
asm (" POP R0 ");
asm (" PUSH R0 ");
asm (" POP R0 ");
void Delay_ms(unsigned int time_ms)
register unsigned int i;
for(i = 0; i < time_ms; i++)
Delay_us(250);
Delay_us(250);
Delay_us(250);
Delay_us(250);
void Set_Speed(void)
Left_Sum = ADC_Data[1];
Center_Sum = ADC_Data[2];
Right_Sum = ADC_Data[3];
if(Left_Sum > 800 && Center_Sum < 550 && Right_Sum < 500) { //Left Corner
speed_L = 30000;
speed_R = 50000;
state=1;
else if(Left_Sum > 800 && Center_Sum > 550 && Right_Sum < 500) { //Left
speed_L = 35000;
speed_R = 50000;
state=2;
else if(Left_Sum < 500 && Center_Sum < 550 && Right_Sum > 800 ) { //Right Corner
speed_L = 50000;
speed_R = 30000;
state=3;
else if(Left_Sum < 500 && Center_Sum > 550 && Right_Sum > 800) { //Right
speed_L = 50000;
speed_R = 35000;
state=4;
else if(Center_Sum > 800) //Straight
speed_L = 50000;
speed_R = 50000;
state=5;
else //Stop
speed_L = 0;
speed_R = 0;
state=6;
void USART_init(unsigned int baud0,unsigned int baud1)
UBRR0H = (unsigned char)(baud0 >> 8);
UBRR0L = (unsigned char)baud0;
UCSR0B = (0<<RXEN0)|(1<<TXEN0)|(0 << RXCIE0)|(0 << TXCIE0);
UCSR0C = (1<<UCSZ01)|(1<<UCSZ00);
UBRR1H = (unsigned char)(baud1 >> 8);
UBRR1L = (unsigned char)baud1;
UCSR1B = (0<<RXEN1)|(1<<TXEN1)|(0<<RXCIE1)|(0<<TXCIE1);
UCSR1C = (1<<UCSZ11)|(1<<UCSZ10);
void Txd0Byte(unsigned char datum)
while(!(UCSR0A & (1<<UDRE0)));
UDR0 = datum;
void Txd1Byte(unsigned char datum)
while(!(UCSR1A & (1<<UDRE1)));
UDR1 = datum;
unsigned char Rxd0Byte(void)
while(!(UCSR0A & (1 << RXC0)));
return UDR0;
unsigned char Rxd1Byte(void)
while(!(UCSR1A & (1 << RXC1)));
return UDR1;
void Txd0String(unsigned char *str)
int i;
for( i=0; str[i]!=0; i++)
Txd0Byte( str[i]);
void Txd1String(unsigned char *str)
int i;
Txd1Byte( str[i]);
void Txd0Dec(int dec)
char String[5];
int loop;
for (loop = 0 ; loop <5 ; loop++)
String[loop] = 0x30 + (dec % 10);
dec = dec / 10;
for(loop = 4; loop >= 0; loop --)
Txd0Byte(String[loop]);
void Txd1Dec(int dec)
char String[5];
int loop;
dec = dec / 10;
Txd1Byte(String[loop]);
int main (void)
USART_init(BAUD_38400,BAUD_38400);
PORT_init();
Timer_init();
ADC_init();
count_R = 0;
count_L = 0;
CrossCount = 0;
StopState = 0;
state = 0;
sei();
for(;;) {
Delay_ms(100);
Txd1Dec(ADC_Data[3]);
Txd1Byte(' ');
Txd1Dec(ADC_Data[2]);
Txd1Byte(' ');
Txd1Dec(ADC_Data[1]);
Txd1Byte(' ');
// Txd1Dec(ADC_Data[4]);
// Txd1Byte(' ');
// Txd1Dec(ADC_Data[5]);
// Txd1Byte(' ');
Txd0Dec(ADC_Data[3]);
Txd0Byte(' ');
Txd0Dec(ADC_Data[2]);
Txd0Byte(' ');
Txd0Dec(ADC_Data[1]);
// Txd0Byte(' ');
// Txd0Dec(ADC_Data[4]);
// Txd0Byte(' ');
// Txd0Dec(ADC_Data[5]);
Txd0Byte(' ');
if(state==1) Txd1String("Left Corner");
else if (state==2) Txd1String("Left");
else if (state==3) Txd1String("Right Corner");
else if (state==4) Txd1String("Right");
else if (state==5) Txd1String("Straight");
else Txd1String("Stop");
Txd1Byte('\n');
return 0;
SIGNAL(TIMER1_OVF_vect)
PORTB = right_motor[count_R++];
count_R %=8;
Set_Speed();
TCNT1 = speed_R;
SIGNAL(TIMER3_OVF_Vect)
PORTC= left_motor[count_L++];
count_L %= 8;
Set_Speed();
TCNT3 = speed_L;
SIGNAL(ADC_vect)
ADC_Data[ADMUX++] = ADC ;
// ADC_Data[SenserNum-1] = ADC_Data[0];
ADMUX %= SenserNum+1;
조회수 3,164등록된 댓글이 없습니다.
