BASIC4MCU | 질문게시판 | PID제어 코드 관련 2
작성자 서씨 작성일2018-05-05 15:41 조회20,727회 댓글4건본문
디지털로 다 바꿨는데도 여전히 안되네요. 어떻게 해야할까요? 아니면 혹시 아날로그로 다 바꿀 수 있는 방법은 없나요? m12랑 m22가 여전히 안되네요.
#include "Wire.h"
#define IR_TRIG 9
#define IR_ECHO 8union {int16_t val; byte med[sizeof(val)];} dat; //union 사용.
const byte m11=10; const byte m12=12; const byte m21=11; const byte m22=13;
const byte DT=5; const float pi=3.141592;
int16_t accX, accY, accZ, gyroX, gyroY, gyroZ;
uint32_t timer; uint8_t i2cData[14]; float gyroYangle, compAngleY, gyroYrate;
float A=0.96, croll0=0, croll, roll;
const float scaling=0.0076336; // MPU6050: +/-250degree per 16bit (500/65536)
uint32_t rt0=0, oldt3; int16_t Output33;
float inc=50.0, bangle=0.0; //inc: angle band in control, bangle: balancing angle to be maintainedfloat Input3, Output3, Output31, olderror3=0, oldintegral3=0;
float dt=(DT)/1000.0, fc=120.0 ; //filtered data, sampling time, cutoff freq.
float alpha=dt/((1/(2*pi*fc))+dt); //LPF for the gyrosensor
float fc1=4.0; //Cutoff frequency [Hz] for the derivative gain
float alpha1=dt/((1/(2*pi*fc1))+dt); //LPF the derivative gain
int16_t yaw, rotation=150;
const float runangle=18.0; //forward/backward reference angle to be tracked// Very Important!! Control Gain
float Kpg =90, Kig = 20, Kdg =0.1; //PID gain: Gyroscopic sensor at 12v
//void Receive() //Receiving the refrence input from the tranmitter via the Bluetooth
{while(Serial2.available()>=((2*sizeof(dat.med))+1))
{if (Serial2.read()=='@'){
for (int16_t i=0; i<sizeof(dat.med); i++) {dat.med[i]=Serial2.read();}
bangle= -(((float) dat.val)/500.0)*runangle; Serial.println(bangle); //-5 degree~ 5 degree
yaw=map(dat.val, -500, 500, rotation, -rotation); Serial.println(yaw); }
else {}}}void motion() //Move the balancing machine upon request from the arduino
{ if (abs(Input3)<inc){
Output3=PID3(bangle-0.0,-Input3);
Output31=constrain(Output3, -255,255);
int16_t Output311=Output31;
int motorA=Output311+yaw, motorB=Output311-yaw;
if(motorA>0) {analogWrite(m11,min(motorA,200));analogWrite(m12,min(motorA,200));
if(motorB>0) {analogWrite(m21,min(motorB,200));analogWrite(m22,0);}
else {analogWrite(m21,min(abs(motorB),200));analogWrite(m22,min(abs(motorB),200));}}
else {analogWrite(m11,min(abs(motorA),200)); analogWrite(m12,0);
else {analogWrite(m21,min(abs(motorB),200));analogWrite(m22,min(abs(motorB),200));}}}
else {analogWrite(m11,0);analogWrite(m21,0);}}
float gyroangle(){
while (i2cRead(0x3B, i2cData, 14));
accX = ((i2cData[0] << 8) | i2cData[1]); accY = ((i2cData[2] << 8) | i2cData[3]); accZ = ((i2cData[4] << 8) | i2cData[5]);
gyroX = (i2cData[8] << 8) | i2cData[9]; gyroY = (i2cData[10] << 8) | i2cData[11]; gyroZ = (i2cData[12] << 8) | i2cData[13];
float dt = (float)(micros() - timer) / 1000000.0;
timer = micros();
float aroll=atan2(accY,accZ)*180.0/pi; //in degree, -180~180
float groll=scaling*(gyroX*dt)+croll0;
croll=A*groll+(1-A)*aroll; //Complementary filter, cf) float K = 0.8; float A = K / (K + dt);
croll0=croll;
roll=(1-alpha)*roll+alpha*croll;
float y=(1-alpha)*y+alpha*roll;
//Serial.println(y);
return y;}float PID3(float Setpoint, float Input) //PID Control w.r.t. Gyro sensor
{float newerror3=Setpoint-Input; //
uint32_t newt3=millis();
uint32_t dt3=newt3-oldt3; //in milliseconds
float Kpgg,Kigg,Kdgg;
if(newerror3*oldintegral3<0){oldintegral3=0.0; Kpgg=1*Kpg; Kigg=2*Kig; Kdgg=1*Kdg;} //Gain Weighting
else {Kpgg=Kpg; Kigg=Kig; Kdgg=Kdg;}
float newintegral3=oldintegral3+newerror3*dt3/1000;
float Kpgg0=Kpgg*newerror3;
float Kpgg1=constrain(Kpgg0,-350.0,350.0);
float newerror33=(1-alpha1)*newerror33+alpha1*newerror3; //LPF for the D term
float derivative3=((newerror33-olderror3)/dt3)*1000;
float derivative330=Kdgg*derivative3;
float derivative33=constrain(derivative330,-350.0,350.0);
float iterm=Kigg*newintegral3;
float iterm3=constrain(iterm,-330.0,330.0);
float Output3=Kpgg1+iterm3+derivative33;
olderror3=newerror3; oldintegral3=newintegral3; oldt3=newt3;
//Serial2.print(Kpgg1);Serial2.print("\t");Serial2.print(iterm3);Serial2.print("\t");Serial2.println(derivative33);
return Output3;}
pinMode(m12,1); pinMode(m22,1);
Wire.begin(); while (i2cWrite(0x6B, 0x01, true)); // PLL(phase locked loop)출력주파수 일정하게 유지 with X axis gyroscope reference and disable sleep mode
Serial.begin(9600); Serial2.begin(9600);Serial2.flush();
pinMode(m11, OUTPUT);
pinMode(m21, OUTPUT);
pinMode(m12, OUTPUT);
pinMode(m22, OUTPUT);
//초음파 센서 핀모드 설정
pinMode(IR_TRIG, OUTPUT);
pinMode(IR_ECHO, INPUT);}
float duration, distance;
digitalWrite(IR_TRIG, HIGH);
delay(10);
digitalWrite(IR_TRIG, LOW);
// echoPin 이 HIGH를 유지한 시간
duration = pulseIn(IR_ECHO, HIGH);
// HIGH 였을 때 시간(초음파가 보냈다가 다시 들어온 시간)을 가지고 거리를 계산 한다.
// 340은 초당 초음파(소리)의 속도, 10000은 밀리세컨드를 세컨드로, 왕복거리이므로 2로 나눠주면 거리가 cm 로 나옴
distance = ((float)(340 * duration) / 10000) / 2;
Serial.print("\nDIstance : ");
Serial.println(distance);
if(distance < 20) { //장애물 감지 (20cm 이내)
back();
int rnd = random(0,2); //장애물 감지시 좌/우회전 랜덤처리
Serial.println(rnd);
if(rnd == 0){
Serial.println("right");
right();
}else{
Serial.println("left");
left();
}Receive(); Input3=gyroangle(); motion(); delay(DT);
void left(){
digitalWrite(m11, LOW); //오른쪽 뒤
digitalWrite(m12,HIGH);
digitalWrite(m21,LOW);
digitalWrite(m22,HIGH);
delay(3000);
void right(){
digitalWrite(m11, HIGH);
digitalWrite(m12, LOW);
digitalWrite(m21, HIGH); //왼쪽 앞
digitalWrite(m22, LOW);
delay(3000);
void back(){
digitalWrite(m21, LOW);
digitalWrite(m22, HIGH);
delay(3000);
댓글 4
조회수 20,727master님의 댓글
master 작성일analogWrite()가 아직도 많으니 모두 바꾸세요
서씨님의 댓글
서씨 작성일pid제어하는데 다 디지털로 바꿔버리면 제어가 어렵지 않나요 ??? 아날로그로 바꾸는 방법은 없나요?
서씨님의 댓글
서씨 작성일EN핀을 하시라고 하셨는데 , 그럼 어떻게 해야할까요.... 도움이 될 만한 자료가 있을까요?
회로도를 올리고
모터와 드라이버모듈 자료도 올려야합니다.
뭘 사용하고 있는지 제가 알 길이 없는데
어떻게 도와드리겠습니까...
