질문게시판 > 답변 : 초음파센서+네오픽셀+서보모터+grove mp3
TODAY600 TOTAL2,267,421
BASIC4MCU | 질문게시판 | 답변 : 초음파센서+네오픽셀+서보모터+grove mp3
작성자 master 작성일2018-12-23 08:40 조회4,409회 댓글0건
// DateTime : 2018-12-23 오전 8:45:31
#include <SoftwareSerial.h>
#include <MP3Player_KT403A.h>
SoftwareSerial mp3(2,3);
#include <Adafruit_NeoPixel.h>
#define  PIN      11
Adafruit_NeoPixel strip=Adafruit_NeoPixel(60,PIN,NEO_GRB+NEO_KHZ800);
#include <Servo.h>
Servo Biteservo//servomotor 를 정의합니다.
const int trigPin=6,echoPin=7;
int   distance=0;
  pinMode(trigPin,OUTPUT); // trigPin을 출력으로
  pinMode(echoPin,INPUT); // echoPin을 입력이다.
  strip.begin(); strip.show(); // Initialize all pixels to 'off'
  Biteservo.attach(9); //신호를 받을부분의 핀을 선정합니다.
  mp3.begin(9600);
  while(!Serial);
  Serial.println("Grove-Serial MP3 Demo");
  Serial.println(
  "Input command: \r\n\r\n"
  "P[]play music by default index\r\n"
  "Pm[]play music in MP3 folder by index\r\n"
  "Pf[][]play music by specify folder and index\r\n"
  "p Pause\r\n"
  "R Resume\r\n"
  "N Next\r\n"
  "L Previous\r\n"
  "l Loop\r\n"
  "I Increase volume\r\n"
  "D Decrease volumern\r\n");
  SelectPlayerDevice(0x02); // Select SD card as the player device.
  SetVolume(0x0E); // Set the volume,the range is 0x00 to 0x1E.
unsigned long t,t_trig=0;
  t=millis();
  if(t-t_trig>100){ t_trig=t;
    digitalWrite(trigPin,HIGH); delayMicroseconds(10); digitalWrite(trigPin,LOW);
    distance=pulseIn(echoPin,HIGH)/58.2;
    //Serial.print("Distance: "); Serial.print(distance); Serial.println("cm");
  distanceneopixel_loop();
  distanceservo_loop();
  distancemp3_loop();
//----------------------서보모터 코드------------------------------
unsigned long t_servo=0;
unsigned int  servo_cnt=0,pos=0;
void distanceservo_loop(){
  if(distance<30){
    if(t-t_servo>10){ t_servo=t;
      if(servo_cnt<100){ } // delay(1000);
      else if(servo_cnt<=280){ pos=servo_cnt-100Biteservo.write(pos); } // for(pos=0; pos<180; pos+=1){ Biteservo.write(pos); delay(10); } //서보의 위치 0~180도 각을 정의합니다.
      else if(servo_cnt<=380){ } // delay(1000);
      else if(servo_cnt<=561){ pos=561-servo_cntBiteservo.write(pos); } // for(pos=180; pos>=1; pos-=1){ Biteservo.write(pos); delay(10); } // 180도에서 0도까지 내려갑니다.
      if(++servo_cnt>561)servo_cnt=0;
  elsepos=0servo_cnt=0Biteservo.write(pos); Serial.println("AAAA"); // 30 이상이면 0도로 이동
//----------------------네오픽셀 코드------------------------------
unsigned long t_neo=0;
unsigned int  neo_cnt=0,fade=0;
void distanceneopixel_loop(){
  if(distance<30){
    if(t-t_neo>10){ t_neo=t;
      if(neo_cnt==0){
        strip.setPixelColor(0,strip.Color(0,50,255)); strip.setPixelColor(1,strip.Color(0,100,255));
        strip.setPixelColor(2,strip.Color(0,150,255)); strip.setPixelColor(3,strip.Color(0,200,255));
        strip.setPixelColor(4,strip.Color(0,255,255));
        strip.setPixelColor(5,strip.Color(0,255,255)); strip.setPixelColor(6,strip.Color(0,255,255));
        strip.setPixelColor(7,strip.Color(0,255,255)); strip.setPixelColor(8,strip.Color(255,255,0)); //초록 //노랑
      else if(neo_cnt<=256){ // for(int i=0; i<=255; i+=1)
        fade=neo_cnt-1;
        strip.setPixelColor(5,strip.Color(fade,255-fade,255-fade));
        strip.setPixelColor(6,strip.Color(fade,255,255-fade));
      else if(neo_cnt<=511){ // for(int i=255; i>=0; i-=1)
        fade=511-neo_cnt;
      strip.show();
      if(++neo_cnt>511)neo_cnt=0;
  else// if(distance>30)
      strip.setPixelColor(0,strip.Color(255,50,0)); strip.setPixelColor(1,strip.Color(255,100,0));
      strip.setPixelColor(2,strip.Color(255,150,0)); strip.setPixelColor(3,strip.Color(255,200,0));
      strip.setPixelColor(4,strip.Color(255,255,0));
      strip.setPixelColor(5,strip.Color(255,255,0)); strip.setPixelColor(6,strip.Color(255,255,0));
      strip.setPixelColor(7,strip.Color(255,255,0)); strip.setPixelColor(8,strip.Color(255,255,0)); //초록 //노랑
      strip.show();
//----------------------MP3 코드------------------------------
uint8_t  len=0,i,recv_cmd[8];
unsigned long t_mp3=0;
bool flag=0;
void distancemp3_loop(){
  if(distance<30){ // 거리30보다 작은 경우
    if(flag==0){ flag=1PlayResume(); }
  else// if(distance>30)// 거리30보다 큰 경우
    flag=0;
    if(t-t_mp3>1000){ t_mp3=tDecreaseVolume(); } // 1초마다 볼륨 점점 작게
  if(Serial.available()){
    char chr=Serial.read(); // Serial.print(chr);
    if(chr=='\n'){
      switch(recv_cmd[0]){
        case 'P':{
          if(recv_cmd[1]=='m'){ /***Play music in "MP3" folder by index*example:*"Pm1"->./MP3/0001.mp3*/
            PlayMP3folder(recv_cmd[2]-'0');
            Serial.print("Play "); Serial.write(recv_cmd[2]); Serial.println(".mp3 in MP3 folder");
          else if(recv_cmd[1]=='f'){ /***Play specify folder and music*example:*"Pf11"->./01/001***.mp3*/
            SpecifyfolderPlay(recv_cmd[2]-'0',recv_cmd[3]-'0');
            Serial.print("Play "); Serial.write(recv_cmd[3]); Serial.print("xxx.mp3"); Serial.print(" in folder "); Serial.write(recv_cmd[2]); Serial.println();
          else/***Play music by default index*example:*"P1"->./***.mp3*/
            SpecifyMusicPlay(recv_cmd[1]-'0');
            Serial.print("Play xxx.MP3 by index "); Serial.write(recv_cmd[1]); Serial.println();
          // Serial.println("Specify the music index to play");
        case 'p'PlayPause();      Serial.println("Pause the MP3 player");        break;
        case 'R'PlayResume();     Serial.println("Resume the MP3 player");       break;
        case 'N'PlayNext();       Serial.println("Play the next song");          break;
        case 'L'PlayPrevious();   Serial.println("Play the previous song");      break;
        case 'l'PlayLoop();       Serial.println("Play loop for all the songs"); break;
        case 'I'IncreaseVolume(); Serial.println("Increase volume");             break;
        case 'D'DecreaseVolume(); Serial.println("Decrease volume");             break;
      len=0;
    elserecv_cmd[len++]=chr; }
  // printReturnedData();
조회수 4,409
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 11767
공지 사이트 이용 안내댓글[25] master 17-10-29 31096
질문 PIC 블루투스 연결댓글[17] 새글 픽공부 10:28 17
질문 PIC18F452 블루투스 연결댓글[4] 새글 마이컴 22-08-08 22
질문 아두이노 코드 해석을 못하겠습니다...댓글[2] 새글 김가헌 22-08-08 23
질문 아두이노 코드를 avr로 변환해 주세요 ...ㅠ댓글[3] 새글 옹냥냥 22-08-08 21
질문 아두이노 녹음-스피커모듈 관련 질문있습니다 ㅠㅠ댓글[2] 새글 방귀뿡뿡 22-08-08 18
질문 Serial EEPROM 실수값 저장..댓글[2] 이미지새글첨부파일 광이 22-08-07 19
질문 STM32 Live Expression 값들이 깜빡이는 현상댓글[3] 둠둠 22-08-05 58
질문 아두이노 ESP32 wifi module댓글[1] Yoon 22-08-03 122
질문 atmega128과 dht11, lcd를 연결했는데 0도라고 뜹니다.댓글[1] 고양이33 22-08-02 260
질문 ATMEGA 128 코드를 합치려고 하는데 어렵네요댓글[2] 고양이33 22-08-02 169
질문 서보모터 제어에 대해 질문있습니다.댓글[2] 첨부파일 뉴비에오 22-07-30 121
질문 적외선 통신 알려주실분있나요 ㅠㅠ댓글[1] hkjsj10 22-07-30 128
질문 아두이노 관련 궁금합니다.댓글[1] 뱝뱝 22-07-28 129
질문 아두이노 우노 MCP4725댓글[3] 이미지 opqr 22-07-27 267
질문 레오나르도 인체감지센서 알림 안옴 면지지 22-07-24 184
답변 답변글 답변 : 레오나르도 인체감지센서 알림 안옴 master 22-07-25 129
질문 Uno에서 엔코더값 놓치는 이유가 뭘까요...댓글[3] MAKTUB 22-07-24 139
질문 아두이노 압력센서 연동 질문댓글[4] dbice 22-07-23 209
질문 아두이노 버튼 누르기 문의댓글[1] 김형근 22-07-23 156
질문 HM10 다중페어링댓글[1] ㅎㅋㅎㅋㅎ 22-07-22 179
질문 모터드라이브 선정댓글[6] 이미지 조숩인 22-07-22 244
질문 ad9850 sin파 2댓글[6] 이미지첨부파일 opqr 22-07-21 184
질문 ad9850 sin파 합성댓글[7] 첨부파일 opqr 22-07-20 227
질문 특정값이 n초이상,n번 이상 연속될경우를 감지하는 함수가 있나요댓글[4] 우수 22-07-17 268
질문 delay를 millis함수로 바꾸는데 질문있습니다.댓글[12] 첨부파일 뉴비에오 22-07-16 637
질문 피에조 부저로 맬로디 만들기인대 코딩 까지 했는데 아두이노 가 동작을 안해요.댓글[2] 이미지첨부파일 mingu123 22-07-15 1605
질문 블루투스와 안드로이드 연동관련 질문입니다! ㅎㅇㅎㅇ 22-07-14 407
질문 아두이노간 블루투스 통신에 대해서 질문있습니다 첨부파일 뉴비에오 22-07-13 173
