질문게시판 > 답변 : FND를 활용해서 덧셈결과를 출력하는 코드에대해서 질문드립니다.
TODAY760 TOTAL2,918,651
BASIC4MCU | 질문게시판 | 답변 : FND를 활용해서 덧셈결과를 출력하는 코드에대해서 질문드립니다.
작성자 master 작성일2018-05-07 06:17 조회29,568회 댓글5건
// DateTime : 2018-05-07 오전 6:19:40
#include <mega128.h>
#include <delay.h>
#define disp_val       0
#define disp_operator  1
#define disp_ovf       2
#define disp_sum       3
char fnd[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
bit  erase_flag=0,equal_flag=0,plus_flag=0;
char disp_mode=disp_val;
unsigned int val=0,old_val=0,sum=0;
void display_operator(void){
  PORTB=0x8cPORTG=1delay_ms(1); PORTG=0;
  PORTB=0xc7PORTG=2delay_ms(1); PORTG=0;
  PORTB=0xc1PORTG=4delay_ms(1); PORTG=0;
  PORTB=0x92PORTG=8delay_ms(1); PORTG=0;
void display_ovf(void){
  PORTB=0x8cPORTG=0x7fdelay_ms(1); PORTG=0;
  PORTB=0xc7PORTG=0x7fdelay_ms(1); PORTG=0;
  PORTB=0xc1PORTG=0x7fdelay_ms(1); PORTG=0;
  PORTB=0x92PORTG=0x7fdelay_ms(1); PORTG=0;
void display_val(void){
  PORTB=fnd[val/1000  ]; PORTG=1delay_ms(1); PORTG=0;
  PORTB=fnd[val/100%10]; PORTG=2delay_ms(1); PORTG=0;
  PORTB=fnd[val/10 %10]; PORTG=4delay_ms(1); PORTG=0;
  PORTB=fnd[val    %10]; PORTG=8delay_ms(1); PORTG=0;
void display_sum(void){
  PORTB=fnd[sum/1000  ]; PORTG=1delay_ms(1); PORTG=0;
  PORTB=fnd[sum/100%10]; PORTG=2delay_ms(1); PORTG=0;
  PORTB=fnd[sum/10 %10]; PORTG=4delay_ms(1); PORTG=0;
  PORTB=fnd[sum    %10]; PORTG=8delay_ms(1); PORTG=0;
char keyscan(void){
  char n=0xff
  DDRC=0PORTC=0xffDDRC=1PORTC.0=0delay_us(1); if(!PINC.4)n=1if(!PINC.5)n=2if(!PINC.6)n=3if(!PINC.7){ plus_flag=1;  }
  DDRC=0PORTC=0xffDDRC=2PORTC.1=0delay_us(1); if(!PINC.4)n=4if(!PINC.5)n=5if(!PINC.6)n=6if(!PINC.7){ erase_flag=1; }
  DDRC=0PORTC=0xffDDRC=4PORTC.2=0delay_us(1); if(!PINC.4)n=7if(!PINC.5)n=8if(!PINC.6)n=9if(!PINC.7){ equal_flag=1; }
  DDRC=0PORTC=0xffDDRC=8PORTC.3=0delay_us(1);                 if(!PINC.5)n=0;
  DDRC=0PORTC=0xff;
  return n;
void main(void){
  char num=0,old=0;
  DDRG=0x0fDDRB=0xff;
  old=keyscan();
    num=keyscan();
    if(old!=num){ old=num;
      if((num>=0)&&(num<=9)){
        if(val<1000){ val*=10val+=numdisp_mode=disp_val; }
      delay_ms(50);
    if(erase_flag){ erase_flag=0;                  val=0disp_mode=disp_val;                                      }
    if(plus_flag ){ plus_flag=0;  old_val=val;     val=0disp_mode=disp_operator;                                 }
    if(equal_flag){ equal_flag=0sum=old_val+valval=0if(sum>9999)disp_mode=disp_ovfelse disp_mode=disp_sum; }
    switch(disp_mode){
      case disp_val:      display_val();      break;
      case disp_operatordisplay_operator(); break;
      case disp_ovf:      display_ovf();      break;
      case disp_sum:      display_sum();      break;
이 코드로 돌려보세요
댓글 5
조회수 29,568
27315co님의 댓글
27315co 작성일
중간에 이부분에서 if(val<1000){ val*=10; val+=num; display(); }
display함수가 어떤함수를 의미하는것이죠??
if(val<1000){ val*=10; val+=num; disp_mode=disp_val; }
수정할 때 빼먹었나봅니다.
27315co님의 댓글
27315co 작성일
말씀하신것까지 반영을해보았는데 결과값이 덧셈을한값이아닌계속 0000이 발생합니다.
마지막 결과(sum)만 제대로 표시되지 않는 것인가요?
27315co님의 댓글
27315co 작성일
네 마지막결과값 sum 만 FND 에 0000 으로 계속 표시가되네요...
답변 답변글 답변 : 스탭모터 제어댓글[2] master 18-07-10 11084
질문 아두이노 컴파일 오류 질문 master 18-07-10 8645
질문 for문에서 i++와 ++i의 차이 질문 master 18-07-10 8867
질문 동화 bhs-800/s 자외선살균소독기 램프가없어서 알수가 없어요 master 18-07-10 9771
질문 아두이노 블루투스 모터제어 질문 master 18-07-10 8908
질문 아두이노 LED 쉬프트 코드 질문 master 18-07-10 9414
질문 리눅스 두가지질문입니다댓글[1] 찐찐형 18-07-09 10525
질문 아두이노 메가보드 스텝모터 6개 연결, usb 유선 연결, 스마트폰 앱으로 스텝모터 구동 질문 master 18-07-09 11958
질문 피에조 센서 질문 master 18-07-09 9113
질문 ATmega 128코드비전 스위치 질문 master 18-07-09 10943
질문 아두이노 delay말고 count 변수나 다른방법을 사용해서 반복하게 할 수 있나요? master 18-07-09 12221
질문 아두이노 센서 질문 master 18-07-09 8945
질문 아두이노 네오픽셀 2개 동시 구동 질문 master 18-07-09 10626
질문 UART 통신 질문합니다댓글[3] 비공개 18-07-09 14567
질문 아두이노 조명 체크 네오픽셀 구동 질문 master 18-07-08 9299
질문 아두이노 펄스의 개수를 세는 코드 질문 master 18-07-08 11143
질문 앱인벤터 실시간 위치받기댓글[1] 이미지 비공개 18-07-07 10037
질문 UART 수신 비공개 18-07-06 8940
답변 답변글 답변 : UART 수신댓글[4] master 18-07-08 16190
질문 ADC(AD컨버터) 질문 master 18-07-06 9243
질문 아두이노로 전자석 작동시킬때 주파수를 알고싶습니다.댓글[12] 이미지첨부파일 냐아 18-07-06 53578
질문 아두이노로 전자석 작동시킬때 주파수를 알고싶습니다.댓글[1] 비공개 18-07-06 9948
질문 라즈베리파이-앱인벤터-블루투스 UART 통신 질문드립니다.댓글[1] 두부 18-07-05 13324
질문 아두이노에서 블루투를통해 값 전달댓글[3] 비공개 18-07-05 16131
질문 아두이노 보드 질문 master 18-07-05 9930
질문 로드셀 질문 master 18-07-05 11076
질문 '' 문자가 왜 쓰인건가요? 역할이 뭔지... master 18-07-05 8127
질문 Atmega128 타이머 카운터 질문 master 18-07-05 8753
질문 아두이노 온습도센서 질문 이미지 master 18-07-05 10035
질문 블루투스데이터처리댓글[2] 선유 18-07-04 12023
