질문게시판 > 아두이노 LED 회로와 코드 질문
TODAY288 TOTAL2,173,680
BASIC4MCU | 질문게시판 | 아두이노 LED 회로와 코드 질문
작성자 Lami 작성일2019-01-11 14:40 조회8,208회 댓글3건
인터넷에서 블루투스로 조종되는 LED 회로에 대한 글을 찾았는데, 회로가 맞는지 코드가 맞는지 알 수도 없고 작동도 안되네요...
이 사진에 나온 회로가 브래드보드에 옮기면 어떤 형태인지하고, 이 코드가 맞는지 알려주실 수 있나요?
감사합니다
코드:
/* RGB LED strip with arduino and Android App bluetooth connection
 *  http://www.electronoobs.com
ARDUINO       RGB
  3          RED
  5          GREEN
  9          BLUE
Bluetooth HC-06 module and Arduino
ARDUINO    Bluetooth HC-06
 0 (RX)       TX
 1 (TX)       RX
 5V           VCC
 GND          GND
///////////////////////////////pre upload ERROR////////////////////////////////////
//#error delete this line after you make sure that the Tx and Rx pin are disconnected
//Tx and Rx pins of the HC06 module should not be connected while we upload the
//"Sketch" to the arduino. The code won't be upload if the pins are connected
int color=0;
//define the RGB pind
int red = 3;
int green = 5;
int blue = 9;
char received;
void setup()  {
  Serial.begin(9600);     //Start the serial comunication for the bluetooth module
  pinMode(red, OUTPUT);   //Red color pwm pin defined as output
  pinMode(green, OUTPUT); //Green color pwm pin defined as output
  pinMode(blue, OUTPUT);  //Blue color pwm pin defined as output
  //Give first value of the PWM 0, we start with the RGB LEDs off
  analogWrite(red,255);
  analogWrite(green,255);
  analogWrite(blue,255);
void loop()  {
  if(Serial.available()>0){
    // read the bluetoot data and store it
    color = Serial.read();
    char Rec = char(color);
    if (Rec != '0')
    Serial.println(Rec); //This is to visualise the received character on the serial monitor
  //LEDs off
  if (color == 'n')
  //White
  if (color == 'w')
    analogWrite(red,0);
    analogWrite(green,0);
    analogWrite(blue,2550);
  //Red
  if (color == 'r')
    analogWrite(red,0);
  //Green
  if (color == 'g')
  //Blue
  if (color == 'b')
    analogWrite(blue,0);
  //Orange
  if (color == 'o')
    analogWrite(red,0);
    analogWrite(green,98);
  //Violet
  if (color == 'v')
    analogWrite(red,148);
    analogWrite(blue,107);
  //Cyan
  if (color == 'c')
  //Yellow
  if (color == 'y')
    analogWrite(red,0);
    analogWrite(green,51);
Drop here!
Detect languageAfrikaansAlbanianAmharicArabicArmenianAzerbaijaniBasqueBelarusianBengaliBosnianBulgarianCatalanCebuanoChichewaChinese (Simplified)Chinese (Traditional)CorsicanCroatianCzechDanishDutchEnglishEsperantoEstonianFilipinoFinnishFrenchFrisianGalicianGeorgianGermanGreekGujaratiHaitian CreoleHausaHawaiianHebrewHindiHmongHungarianIcelandicIgboIndonesianIrishItalianJapaneseJavaneseKannadaKazakhKhmerKoreanKurdishKyrgyzLaoLatinLatvianLithuanianLuxembourgishMacedonianMalagasyMalayMalayalamMalteseMaoriMarathiMongolianMyanmar (Burmese)NepaliNorwegianPashtoPersianPolishPortuguesePunjabiRomanianRussianSamoanScots GaelicSerbianSesothoShonaSindhiSinhalaSlovakSlovenianSomaliSpanishSundaneseSwahiliSwedishTajikTamilTeluguThaiTurkishUkrainianUrduUzbekVietnameseWelshXhosaYiddishYorubaZulu
Text-to-speech function is limited to 200 characters
댓글 3
조회수 8,208
회로를 잘 모르는 사람이 작성했군요
아두이노 고장납니다.
Lami님의 댓글
Lami 댓글의 댓글 작성일
그런가요...?
어쩐지 안되더라...
질문 회로와 질문 소스가 정상적으로 동작하려면
12V LED바가 아닌 5V LED바를 사용하면 되지만
5V RGB LED바를 저는 아직 본 적이 없습니다.
공지 사이트 이용 안내댓글[24] master 17-10-29 29814
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 252
