질문게시판 > 손문일
TODAY275 TOTAL2,173,667
BASIC4MCU | 질문게시판 | 손문일
작성자 손문일 작성일2019-01-22 14:55 조회3,343회 댓글0건
#include <MP3Player_KT403A.h>
SoftwareSerial mp3(2,3);
#define  PIN      11
Adafruit_NeoPixel strip=Adafruit_NeoPixel(60,PIN,NEO_GRB+NEO_KHZ800);
  mp3.begin(9600);
  SelectPlayerDevice(0x02); // Select SD card as the player device.
  SetVolume(0x0E); // Set the volume,the range is 0x00 to 0x1E.
  strip.begin(); strip.show(); // Initialize all pixels to 'off'
  Serial.begin(9600); while(!Serial);
unsigned long t;
  t=millis();
  distanceneopixel_loop();
  distancemp3_loop();
  distancetriple_loop();
uint8_t  len=0,i,recv_cmd[8];
unsigned long t_mp3=0;
bool flag=0;
void distancemp3_loop(){
  if(digitalRead(13)){                                               // main 코드에서 불러옴 (거리30보다 작은 경우)
    if(flag==0){ flag=1;
    mp3.begin(9600);
  SetVolume(0x0E);
  PlayResume(); }
  else{                                                              // if(distance>30)// 거리30보다 큰 경우
    flag=0;
    if(t-t_mp3>1000){ t_mp3=t; DecreaseVolume(); }                  // 1초마다 볼륨 점점 작게
  if(Serial.available()){
    char chr=Serial.read();                                          // Serial.print(chr);
    if(chr=='\n'){
      switch(recv_cmd[0]){
        case 'P':{
          if(recv_cmd[1]=='m'){ /***Play music in "MP3" folder by index*example:*"Pm1"->./MP3/0001.mp3*/
            PlayMP3folder(recv_cmd[2]-'0');
            Serial.print("Play "); Serial.write(recv_cmd[2]); Serial.println(".mp3 in MP3 folder");
          else if(recv_cmd[1]=='f'){ /***Play specify folder and music*example:*"Pf11"->./01/001***.mp3*/
            SpecifyfolderPlay(recv_cmd[2]-'0',recv_cmd[3]-'0');
            Serial.print("Play "); Serial.write(recv_cmd[3]); Serial.print("xxx.mp3"); Serial.print(" in folder "); Serial.write(recv_cmd[2]); Serial.println();
          else{ /***Play music by default index*example:*"P1"->./***.mp3*/
            SpecifyMusicPlay(recv_cmd[1]-'0');
            Serial.print("Play xxx.MP3 by index "); Serial.write(recv_cmd[1]); Serial.println();
          // Serial.println("Specify the music index to play");
        case 'p': PlayPause();      Serial.println("Pause the MP3 player");        break;
        case 'R': PlayResume();     Serial.println("Resume the MP3 player");       break;
        case 'N': PlayNext();       Serial.println("Play the next song");          break;
        case 'L': PlayPrevious();   Serial.println("Play the previous song");      break;
        case 'l': PlayLoop();       Serial.println("Play loop for all the songs"); break;
        case 'I': IncreaseVolume(); Serial.println("Increase volume");             break;
        case 'D': DecreaseVolume(); Serial.println("Decrease volume");             break;
      len=0;
    else{ recv_cmd[len++]=chr; }
  // printReturnedData();
unsigned long t_neo=0;
unsigned int  neo_cnt=0,fade=0;
void distanceneopixel_loop(){
    if(t-t_neo>10){ t_neo=t;
      if(neo_cnt==0){
        strip.setPixelColor(0,strip.Color(0,50,255));
        strip.setPixelColor(1,strip.Color(0,100,255));
        strip.setPixelColor(2,strip.Color(0,150,255));
        strip.setPixelColor(3,strip.Color(0,200,255));
        strip.setPixelColor(4,strip.Color(0,255,255));
        strip.setPixelColor(5,strip.Color(0,255,255));
        strip.setPixelColor(6,strip.Color(0,255,255));
        strip.setPixelColor(7,strip.Color(0,255,255));
        strip.setPixelColor(8,strip.Color(255,255,0));                           //초록 //노랑
      else if(neo_cnt<=256){                                                     // for(int i=0; i<=255; i+=1)
        fade=neo_cnt-1;
        strip.setPixelColor(5,strip.Color(fade,255-fade,255-fade));
        strip.setPixelColor(6,strip.Color(fade,255,255-fade));
      else if(neo_cnt<=511){                                                     // for(int i=255; i>=0; i-=1)
        fade=511-neo_cnt;
      strip.show();
      if(++neo_cnt>511)neo_cnt=0;
      strip.setPixelColor(0,strip.Color(255,50,0));
      strip.setPixelColor(1,strip.Color(255,100,0));
      strip.setPixelColor(2,strip.Color(255,150,0));
      strip.setPixelColor(3,strip.Color(255,200,0));
      strip.setPixelColor(4,strip.Color(255,255,0));
      strip.setPixelColor(5,strip.Color(255,255,0));
      strip.setPixelColor(6,strip.Color(255,255,0));
      strip.setPixelColor(7,strip.Color(255,255,0));
      strip.show();
int fadingRGB_ledPin[3] = {5,6,};                         // 핀 위치 (G R B)
int fadeRGBValue[3] = {0,0,0};                             // 0부터 밝기 시작
int fadeRGBDir[3] = {1,1,1};                               // Led를 밝게함. 0으로하면 처음에 꺼져있는듯...
unsigned long fadingRGB_previousMillis[3] = {0,};         // millis 함수
unsigned long fadingRGB_interval[3] = {120,120,120};      // 작업 간격
void distancetriple_loop(){
  unsigned long currentMillis = millis();
 for(int i=0; i<3; i++){                                    //아래 millis 함수의 i에 해당
  if (currentMillis - fadingRGB_previousMillis[i] >= fadingRGB_interval[i]) {
    fadingRGB_previousMillis[i] = currentMillis;
if(fadeRGBDir[i] == 1) {                                    // led를 밝게함
  if(fadeRGBValue[i] <=255) {
    fadeRGBValue[i] += 5;
    if(fadeRGBValue[i] > 255){
      fadeRGBValue[i] = 255;
      fadeRGBDir[i] = 0;
} else {
  if(fadeRGBValue[i] >= 0) {
    fadeRGBValue[i] -= 5;
    if(fadeRGBValue[i] < 0){
      fadeRGBValue[i] = 0;
      fadeRGBDir[i] = 1;
analogWrite (fadingRGB_ledPin[i], fadeRGBValue[i]);
조회수 3,343
공지 사이트 이용 안내댓글[24] master 17-10-29 29813
질문 atmega128 GPS,블루투스 질문드립니다.댓글[1] 코딩초보1 22-05-24 41
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 251
