질문게시판 > 답변 : 손문일
TODAY324 TOTAL2,176,977
BASIC4MCU | 질문게시판 | 답변 : 손문일
작성자 master 작성일2019-01-22 15:07 조회3,245회 댓글0건
#include <SoftwareSerial.h>
#include <MP3Player_KT403A.h>
SoftwareSerial mp3(2,3);
#include <Adafruit_NeoPixel.h>
#define  PIN      11
Adafruit_NeoPixel strip=Adafruit_NeoPixel(60,PIN,NEO_GRB+NEO_KHZ800);
  mp3.begin(9600);
  SelectPlayerDevice(0x02); // Select SD card as the player device.
  SetVolume(0x0E); // Set the volume,the range is 0x00 to 0x1E.
  strip.begin(); strip.show(); // Initialize all pixels to 'off'
  Serial.begin(9600); while(!Serial);
unsigned long t;
  t=millis();
  distanceneopixel_loop(); distancemp3_loop(); distancetriple_loop();
uint8_t  len=0,i,recv_cmd[8];
unsigned long t_mp3=0;
bool flag=0;
void distancemp3_loop(){
  if(digitalRead(13)){ // main 코드에서 불러옴(거리30보다 작은 경우)
    if(flag==0){ flag=1;
      mp3.begin(9600); SelectPlayerDevice(0x02); SetVolume(0x0E); PlayResume();
  else// if(distance>30)// 거리30보다 큰 경우
    flag=0;
    if(t-t_mp3>1000){ t_mp3=tDecreaseVolume(); } // 1초마다 볼륨 점점 작게
  if(Serial.available()){
    char chr=Serial.read(); // Serial.print(chr);
    if(chr=='\n'){
      switch(recv_cmd[0]){
        case 'P':{
          if(recv_cmd[1]=='m'){ /***Play music in "MP3" folder by index*example:*"Pm1"->./MP3/0001.mp3*/
            PlayMP3folder(recv_cmd[2]-'0');
            Serial.print("Play "); Serial.write(recv_cmd[2]); Serial.println(".mp3 in MP3 folder");
          else if(recv_cmd[1]=='f'){ /***Play specify folder and music*example:*"Pf11"->./01/001***.mp3*/
            SpecifyfolderPlay(recv_cmd[2]-'0',recv_cmd[3]-'0');
            Serial.print("Play "); Serial.write(recv_cmd[3]); Serial.print("xxx.mp3"); Serial.print(" in folder "); Serial.write(recv_cmd[2]); Serial.println();
          else/***Play music by default index*example:*"P1"->./***.mp3*/
            SpecifyMusicPlay(recv_cmd[1]-'0');
            Serial.print("Play xxx.MP3 by index "); Serial.write(recv_cmd[1]); Serial.println();
          // Serial.println("Specify the music index to play");
        case 'p'PlayPause(); Serial.println("Pause the MP3 player"); break;
        case 'R'PlayResume(); Serial.println("Resume the MP3 player"); break;
        case 'N'PlayNext(); Serial.println("Play the next song"); break;
        case 'L'PlayPrevious(); Serial.println("Play the previous song"); break;
        case 'l'PlayLoop(); Serial.println("Play loop for all the songs"); break;
        case 'I'IncreaseVolume(); Serial.println("Increase volume"); break;
        case 'D'DecreaseVolume(); Serial.println("Decrease volume"); break;
      len=0;
    elserecv_cmd[len++]=chr; }
  // printReturnedData();
unsigned long t_neo=0;
unsigned int  neo_cnt=0,fade=0,c_cnt=0;
void distanceneopixel_loop(){
    if(t-t_neo>50){ t_neo=t;
      if(neo_cnt==0){
        if(++c_cnt>=10){ c_cnt=0;
          strip.setPixelColor(0,strip.Color(0,50,255));
          strip.setPixelColor(1,strip.Color(0,100,255));
          strip.setPixelColor(2,strip.Color(0,150,255));
          strip.setPixelColor(3,strip.Color(0,200,255));
          strip.setPixelColor(4,strip.Color(0,255,255));
          strip.setPixelColor(5,strip.Color(0,255,255));
          strip.setPixelColor(6,strip.Color(0,255,255));
          strip.setPixelColor(7,strip.Color(0,255,255));
          strip.setPixelColor(8,strip.Color(255,255,0)); //초록 //노랑
      else if(neo_cnt<=256){ // for(int i=0; i<=255; i+=1)
        fade=neo_cnt-1;
        strip.setPixelColor(5,strip.Color(fade,255-fade,255-fade));
        strip.setPixelColor(6,strip.Color(fade,255,255-fade));
      else if(neo_cnt<=511){ // for(int i=255; i>=0; i-=1)
        fade=511-neo_cnt;
      strip.show();
      if(++neo_cnt>511)neo_cnt=0;
    if(t-t_neo>10){ t_neo=t;
      strip.setPixelColor(0,strip.Color(255,50,0));
      strip.setPixelColor(1,strip.Color(255,100,0));
      strip.setPixelColor(2,strip.Color(255,150,0));
      strip.setPixelColor(3,strip.Color(255,200,0));
      strip.setPixelColor(4,strip.Color(255,255,0));
      strip.setPixelColor(5,strip.Color(255,255,0));
      strip.setPixelColor(6,strip.Color(255,255,0));
      strip.setPixelColor(7,strip.Color(255,255,0));
      strip.show();
int fadingRGB_ledPin[3]={ 5,6,}; // 핀 위치(G R B)
int fadeRGBValue[3]={0,0,0}; // 0부터 밝기 시작
int fadeRGBDir[3]={ 1,1,1}; // Led를 밝게함.0으로하면 처음에 꺼져있는듯...
unsigned long fadingRGB_previousMillis[3]={0,}; // millis 함수
unsigned long fadingRGB_interval[3]={ 120,120,120}; // 작업 간격
void distancetriple_loop(){
  unsigned long currentMillis=millis();
    for(int i=0i<3i++){ //아래 millis 함수의 i에 해당
      if(currentMillis-fadingRGB_previousMillis[i]>=fadingRGB_interval[i]){
        fadingRGB_previousMillis[i]=currentMillis;
        if(fadeRGBDir[i]==1){ // led를 밝게함
          if(fadeRGBValue[i]<=255){
            fadeRGBValue[i]+=5if(fadeRGBValue[i]>255){ fadeRGBValue[i]=255fadeRGBDir[i]=0; }
        } else{
          if(fadeRGBValue[i]>=0){
            fadeRGBValue[i]-=5if(fadeRGBValue[i]<0){ fadeRGBValue[i]=0fadeRGBDir[i]=1; }
        analogWrite(fadingRGB_ledPin[i],fadeRGBValue[i]);
조회수 3,245
질문 esp32를 이용한 피에조부저댓글[1] 이미지새글 ejdog 22-05-27 25
질문 ATmega128 1602A LCD 출력 질문입니다.댓글[2] 새글 444222a 22-05-27 51
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] master 22-05-26 92
