질문게시판 > 답변 : 답변 : 답변 : master님 스테핑 모터 3개 제어 관련 문의드립니다.
TODAY311 TOTAL2,176,964
BASIC4MCU | 질문게시판 | 답변 : 답변 : 답변 : master님 스테핑 모터 3개 제어 관련 문의드립니다.
작성자 master 작성일2019-01-22 16:30 조회3,241회 댓글1건
// DateTime : 2019-01-22 오후 4:35:20
#include <SoftwareSerial.h>
int a=A0,b=A1;
SoftwareSerial btSerial(a,b); //rx,tx
// Blue   A-28BYJ48 pin 1
// Pink   B-28BYJ48 pin 2
// Yellow A’-28BYJ48 pin 3
// Orange B’-28BYJ48 pin 4
// Red-28BYJ48 pin 5(VCC)
int M1A=10,M1B=11,M1C=12,M1D=13;
int M2A=6,M2B=7,M2C=8,M2D=9;
int M3A=2,M3B=3,M3C=4,M3D=5;
int s=2// 최소 2ms //(이게 최대값)
int mode=0;
  pinMode(M1A,OUTPUT); pinMode(M1B,OUTPUT); pinMode(M1C,OUTPUT); pinMode(M1D,OUTPUT);
  pinMode(M2A,OUTPUT); pinMode(M2B,OUTPUT); pinMode(M2C,OUTPUT); pinMode(M2D,OUTPUT);
  pinMode(M3A,OUTPUT); pinMode(M3B,OUTPUT); pinMode(M3C,OUTPUT); pinMode(M3D,OUTPUT);
  btSerial.begin(9600);
  if(btSerial.available()){
    char c=btSerial.read();
    if(c=='q')mode=c;
    if(c=='w')mode=c;
    if(c=='e')mode=c;
    if(c=='r')mode=c;
    if(c=='t')mode=c;
    if(c=='y')mode=c;
    if(c=='f')mode=0;
    digitalWrite(M3A,0); digitalWrite(M3B,0); digitalWrite(M3C,0); digitalWrite(M3D,0); delay(s);
  if(mode=='q'){
    digitalWrite(M1A,1); digitalWrite(M1B,0); digitalWrite(M1C,0); digitalWrite(M1D,0); delay(s);
    digitalWrite(M1A,1); digitalWrite(M1B,1); digitalWrite(M1C,0); digitalWrite(M1D,0); delay(s);
    digitalWrite(M1A,0); digitalWrite(M1B,1); digitalWrite(M1C,0); digitalWrite(M1D,0); delay(s);
    digitalWrite(M1A,0); digitalWrite(M1B,1); digitalWrite(M1C,1); digitalWrite(M1D,0); delay(s);
    digitalWrite(M1A,0); digitalWrite(M1B,0); digitalWrite(M1C,1); digitalWrite(M1D,0); delay(s);
    digitalWrite(M1A,0); digitalWrite(M1B,0); digitalWrite(M1C,1); digitalWrite(M1D,1); delay(s);
    digitalWrite(M1A,0); digitalWrite(M1B,0); digitalWrite(M1C,0); digitalWrite(M1D,1); delay(s);
    digitalWrite(M1A,1); digitalWrite(M1B,0); digitalWrite(M1C,0); digitalWrite(M1D,1); delay(s);
  if(mode=='w'){
  if(mode=='e'){
    digitalWrite(M2A,1); digitalWrite(M2B,0); digitalWrite(M2C,0); digitalWrite(M2D,0); delay(s);
    digitalWrite(M2A,1); digitalWrite(M2B,1); digitalWrite(M2C,0); digitalWrite(M2D,0); delay(s);
    digitalWrite(M2A,0); digitalWrite(M2B,1); digitalWrite(M2C,0); digitalWrite(M2D,0); delay(s);
    digitalWrite(M2A,0); digitalWrite(M2B,1); digitalWrite(M2C,1); digitalWrite(M2D,0); delay(s);
    digitalWrite(M2A,0); digitalWrite(M2B,0); digitalWrite(M2C,1); digitalWrite(M2D,0); delay(s);
    digitalWrite(M2A,0); digitalWrite(M2B,0); digitalWrite(M2C,1); digitalWrite(M2D,1); delay(s);
    digitalWrite(M2A,0); digitalWrite(M2B,0); digitalWrite(M2C,0); digitalWrite(M2D,1); delay(s);
  digitalWrite(M2A,1); digitalWrite(M2B,0); digitalWrite(M2C,0); digitalWrite(M2D,1); delay(s); }
  if(mode=='r'){
  if(mode=='t'){
    digitalWrite(M3A,1); digitalWrite(M3B,0); digitalWrite(M3C,0); digitalWrite(M3D,0); delay(s);
    digitalWrite(M3A,1); digitalWrite(M3B,1); digitalWrite(M3C,0); digitalWrite(M3D,0); delay(s);
    digitalWrite(M3A,0); digitalWrite(M3B,1); digitalWrite(M3C,0); digitalWrite(M3D,0); delay(s);
    digitalWrite(M3A,0); digitalWrite(M3B,1); digitalWrite(M3C,1); digitalWrite(M3D,0); delay(s);
    digitalWrite(M3A,0); digitalWrite(M3B,0); digitalWrite(M3C,1); digitalWrite(M3D,0); delay(s);
    digitalWrite(M3A,0); digitalWrite(M3B,0); digitalWrite(M3C,1); digitalWrite(M3D,1); delay(s);
    digitalWrite(M3A,0); digitalWrite(M3B,0); digitalWrite(M3C,0); digitalWrite(M3D,1); delay(s);
    digitalWrite(M3A,1); digitalWrite(M3B,0); digitalWrite(M3C,0); digitalWrite(M3D,1); delay(s);
  if(mode=='y'){
조회수 3,241
원스타님의 댓글
원스타 작성일
와 대박!!! 진짜 감사합니다. 이거로 해결이 됬네요!!!!
혹시 어떤 차이가 있는지 여쭤봐도 될까요?
아 진짜 너무너무 감사합니다 ㅠㅠㅠㅠ
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 9704
공지 사이트 이용 안내댓글[24] master 17-10-29 29878
질문 esp32를 이용한 피에조부저댓글[1] 이미지새글 ejdog 22-05-27 24
답변 답변글 답변 : 아두이노 서보모터 무한회전 문제 해결을 어떻게 해야할까요댓글[5] 새글 master 22-05-27 44
질문 아두이노 속도측정, 속도를 LCD에 표시, 가까워지면 부저 새글 wgtjdwls 22-05-27 26
답변 답변글 답변 : 블루투스 관련 코드 도와주세요 새글 master 22-05-27 24
질문 ATmega128 1602A LCD 출력 질문입니다.댓글[2] 새글 444222a 22-05-27 50
질문 초음파센싱을 통한 리니어벨트 (스텝모터사용) 조건문댓글[1] 아두이노대학 22-05-26 42
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. aasdw 22-05-26 79
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] master 22-05-26 90
질문 Atmega128 블루투스 오류 질문 yhj2644 22-05-26 74
답변 답변글 답변 : Atmega128 블루투스 오류 질문 master 22-05-26 54
