질문게시판 > 답변 : 네오픽셀 전체 컴파일
TODAY724 TOTAL1,451,161
BASIC4MCU | 질문게시판 | 답변 : 네오픽셀 전체 컴파일
작성자 master 작성일2019-02-05 10:16 조회1,566회 댓글3건
// DateTime : 2019-02-05 오전 10:22:33
#include <SoftwareSerial.h>
#include <MP3Player_KT403A.h>
SoftwareSerial mp3(2,3);
#include <Adafruit_NeoPixel.h>
#define  PIN      12
Adafruit_NeoPixel strip=Adafruit_NeoPixel(60,PIN,NEO_GRB+NEO_KHZ800);
int v_cnt=0;
  mp3.begin(9600);
  SelectPlayerDevice(0x02); // Select SD card as the player device.
  SetVolume(0x0E); // Set the volume,the range is 0x00 to 0x1E.
  strip.begin(); strip.show(); // Initialize all pixels to 'off'
  Serial.begin(9600); while(!Serial);
uint8_t  len=0,i,recv_cmd[8];
unsigned long t_mp3=0,t;
bool flag=0;
bool n_flag=0,m_flag=0,l_flag=0,mp3_flag=0,t_flag=0//n_flag=0,m_flag=0,l_flag=0,mp3_flag=0,t_flag=0;(distancetriple1에 적용)
void distancemp3_loop(){
  if(digitalRead(13)==0){
    if(mp3_flag){
      if(t-t_mp3>1000){ t_mp3=t;
        if(--v_cnt==0){ mp3_flag=0; }
        DecreaseVolume(); // 1초마다 볼륨 점점 작게
  if(Serial.available()){
    char chr=Serial.read(); // Serial.print(chr);
    if(chr=='\n'){
      switch(recv_cmd[0]){
        case 'P':{
          if(recv_cmd[1]=='m'){ /***Play music in "MP3" folder by index*example:*"Pm1"->./MP3/0001.mp3*/
            PlayMP3folder(recv_cmd[2]-'0');
            Serial.print("Play "); Serial.write(recv_cmd[2]); Serial.println(".mp3 in MP3 folder");
          else if(recv_cmd[1]=='f'){ /***Play specify folder and music*example:*"Pf11"->./01/001***.mp3*/
            SpecifyfolderPlay(recv_cmd[2]-'0',recv_cmd[3]-'0');
            Serial.print("Play "); Serial.write(recv_cmd[3]); Serial.print("xxx.mp3"); Serial.print(" in folder "); Serial.write(recv_cmd[2]); Serial.println();
          else/***Play music by default index*example:*"P1"->./***.mp3*/
            SpecifyMusicPlay(recv_cmd[1]-'0');
            Serial.print("Play xxx.MP3 by index "); Serial.write(recv_cmd[1]); Serial.println();
          // Serial.println("Specify the music index to play");
        case 'p'PlayPause(); Serial.println("Pause the MP3 player"); break;
        case 'R'PlayResume(); Serial.println("Resume the MP3 player"); break;
        case 'N'PlayNext(); Serial.println("Play the next song"); break;
        case 'L'PlayPrevious(); Serial.println("Play the previous song"); break;
        case 'l'PlayLoop(); Serial.println("Play loop for all the songs"); break;
        case 'I'IncreaseVolume(); Serial.println("Increase volume"); break;
        case 'D'DecreaseVolume(); Serial.println("Decrease volume"); break;
      len=0;
    elserecv_cmd[len++]=chr; }
  // printReturnedData();
unsigned long t_neo=0;
unsigned int  neo_cnt=0,fade=0,c0_cnt=0,c1_cnt=0,c2_cnt=0,c3_cnt=0;
void distanceneopixel_loop(){
  if(n_flag){
    if(t-t_neo>50){ t_neo=t//Millis 함수
      if(neo_cnt<=255){ //0부터 255까지의 구간
        if(++c0_cnt>=1){ c0_cnt=0//++c0_cnt>=1 의 숫자 1을 올릴수록 느려짐
          fade=neo_cnt;
          strip.setPixelColor(0,strip.Color(0,fade/8,fade)); //fade/2는 255를 2로 나눈 수까지 fade시킨다
          strip.setPixelColor(1,strip.Color(0,fade/6,fade)); //fade/4는 255를 4로 나눈 수,즉 63까지 fade시킨다
          strip.setPixelColor(2,strip.Color(0,fade/4,fade));
          strip.setPixelColor(3,strip.Color(0,fade/2,fade));
          strip.setPixelColor(4,strip.Color(0,fade,fade));
          strip.setPixelColor(5,strip.Color(0,fade,fade));
          strip.setPixelColor(6,strip.Color(0,fade,fade));
          strip.setPixelColor(7,strip.Color(0,fade,fade));
          strip.setPixelColor(8,strip.Color(0,fade,fade));
      else if(neo_cnt<=510){ //255부터 510까지의 구간
        if(++c1_cnt>=1){ c1_cnt=0;
          strip.setPixelColor(0,strip.Color(0,50,255));
          strip.setPixelColor(1,strip.Color(0,100,255));
          strip.setPixelColor(2,strip.Color(0,150,255));
          strip.setPixelColor(3,strip.Color(0,200,255));
          strip.setPixelColor(4,strip.Color(0,255,255));
          strip.setPixelColor(5,strip.Color(0,255,255));
          strip.setPixelColor(6,strip.Color(0,255,255));
          strip.setPixelColor(7,strip.Color(0,255,255));
          strip.setPixelColor(8,strip.Color(255,255,0)); //초록 //노랑
      else if(neo_cnt<=765){ //510부터 765까지의 구간
        if(++c2_cnt>=1){ c2_cnt=0;
          fade=neo_cnt-510//fade=neo_cnt-510는 증가
          strip.setPixelColor(5,strip.Color(fade,255-fade,255-fade)); //fade(증가),255-fade(감소),255-fade(감소)
          strip.setPixelColor(6,strip.Color(fade,255,255-fade));
      else// if(neo_cnt<=767)
        if(++c3_cnt>=1){ c3_cnt=0;
          fade=765-neo_cnt//fade=neo_cnt-765는 감소
          strip.setPixelColor(5,strip.Color(fade,255-fade,255-fade)); //fade(감소),255-fade(증가),255-fade(증가)
      if(++neo_cnt>1020){ neo_cnt=0//-----------------------------------------//
        if(digitalRead(13)==0){ n_flag=0;
          strip.setPixelColor(0,strip.Color(255,50,0));
          strip.setPixelColor(1,strip.Color(255,100,0));
          strip.setPixelColor(2,strip.Color(255,150,0));
          strip.setPixelColor(3,strip.Color(255,200,0));
          for(int z=4z<=8z++)strip.setPixelColor(z,strip.Color(255,255,0)); //4번부터 8번까지
      strip.show();
unsigned long t_tri[3]={0,};
unsigned int  tri_cnt=0,t_fade=0,t0_cnt=0,t1_cnt=0,t2_cnt=0,t3_cnt=0;
int fadingRGB_ledPin[3]={ 5,6,9}; // 핀 위치(G R B)
int fadeRGBValue[3]={0,0,0}; // 0부터 밝기 시작
int fadeRGBDir[3]={ 1,1,1}; // Led를 밝게함.0으로하면 처음에 꺼져있는듯...
void distancetriple_loop(){
  if(t_flag){
    for(int i=0i<3i++){
      if(t-t_tri[i]>50){ t_tri[i]=t//t는 currentmillis임    해석: if(currentmillis-previousmillis[i]>50)previousmillis[i]=currentmillis;
        if(tri_cnt<256){ //0부터 255까지의 구간
          if(++t0_cnt>=1){ t0_cnt=0//++c0_cnt>=1 의 숫자 1을 올릴수록 느려짐
            t_fade=tri_cnt;
            if(fadeRGBDir[i]==1){ // led를 밝게함
              if(fadeRGBValue[i]==255){
                if(++fadeRGBValue[i]==255)fadeRGBDir[i]=0;
        else if(tri_cnt<512){ //256부터 511까지의 구간
          if(++t1_cnt>=1){ t1_cnt=0;
            t_fade=tri_cnt-256//fade=511-neo_cnt는 감소
            if(fadeRGBValue[i]>0){
              if(--fadeRGBValue[i]==0){
                fadeRGBValue[i]=0fadeRGBDir[i]=1;
                if(digitalRead(13)==0)t_flag=0;
        else if(tri_cnt<764){ //512부터 763까지의 구간
          if(++t2_cnt>=1){ t2_cnt=0t_fade=tri_cnt-512; } //fade=neo_cnt-512는 증가
        else// if(neo_cnt<1024)
          if(++t3_cnt>=1){ t3_cnt=0t_fade=1023-tri_cnt; } //fade=neo_cnt-765는 감소
        if(++tri_cnt>=1024)tri_cnt=0//-----------------------------------------//
      if(i==2)analogWrite(fadingRGB_ledPin[i],fadeRGBValue[i]/8); // 해설: if(i==1)...../4  1번핀을 /4정도만 증가 시킨다.(i=0은 5번핀 i=1은 6번 핀 i=2는 9번핀임)
      else    analogWrite(fadingRGB_ledPin[i],fadeRGBValue[i]);
  t=millis();
  if(digitalRead(13)){ // 13번 핀으로 다른 아두이노 제어,main 코드에서 불러옴(거리30보다 작은 경우)
    if(flag==0){ flag=1;
      n_flag=1m_flag=1l_flag=1mp3_flag=1t_flag=1//각 탭에 하나씩 적용됨
      mp3.begin(9600); SelectPlayerDevice(0x02); v_cnt=0x0ESetVolume(v_cnt); PlayResume();
  else// if(distance>30)// 거리30보다 큰 경우
    flag=0;
  distanceneopixel_loop();
  distancemp3_loop();
  distancetriple_loop();
댓글 3
조회수 1,566
손문일님의 댓글
손문일 작성일
감사합니다. 선생님
코드를 새파일로 만들어서 붙여 넣으니깐 완료가 되네요...
근데 트리플 엘이디가 불이 안들어 옵니다...
TT..TT
복잡한 것은 남이 분석해서 작성하기도 어렵고
타인은 동작시켜볼 수가 없으니 디버깅도 안됩니다.
본인이 고민해서 만드셔야지
디버깅도 본인이 할 수 있습니다.^^
손문일님의 댓글
손문일 작성일
넵 최대한 해보겠습니다.
감사합니다. ^^
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 2679
공지 사이트 이용 안내댓글[16] master 17-10-29 14848
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 5678
질문 블루투스와 터치센서 질문드립니다~!!!! YMKIM 21-01-15 24
답변 답변글 답변 : 블루투스와 터치센서 질문드립니다~!!!! 새글 master 21-01-16 12
질문 ATmega128 LED 탑쌓기 반대방향 질문입니다.댓글[2] 쩡쩡쭁 21-01-15 41
질문 아두이노 if에서 다른 버튼으로 else if 혹은 else로 넘어갔을때 오류입니다.댓글[5] 이미지첨부파일 LoadRian 21-01-14 22
질문 센싱 데이터 sd카드 저장 관련 코드 질문 드립니다.댓글[1] 첨부파일 우끼우기 21-01-13 24
질문 아두이노 서보모터 다중제어 질문드립니다.댓글[1] 서보모토능력자 21-01-12 48
질문 아두이노 MCP2515 CAN Module 을 통한 CAN data 전송댓글[1] 이미지첨부파일 흠압지 21-01-11 29
질문 유아전동차 블루트스 컨트롤+MP3댓글[2] kenneth 21-01-09 34
질문 디버깅하는데 입출력 코드에서 자꾸 멈춰요댓글[1] 이미지첨부파일 한입만 21-01-07 43
질문 UV LED 를 제어하는 함수는 없나요???댓글[1] 한입만 21-01-06 52
질문 네오픽셀 버튼 조합댓글[7] 지수 21-01-04 65
질문 아두이노 블루투스 모듈이랑 연결을 시도했을 때 안되요.댓글[3] 첨부파일 ONCE원스 20-12-31 120
질문 아두이노 for문에 random함수 가능한지 질문입니다!댓글[3] 호식이 20-12-30 87
질문 조도센서에 millis()로 특정부분 반복가능한가요?댓글[2] 그릇 20-12-29 80
질문 아트메가168 업로드 문제 아두이노배우기 20-12-29 58
질문 아두이노 조도센서와 RGB 3색 LED 4핀센서댓글[1] 해위 20-12-29 82
질문 아두이노 온습도센서 질문입니다.댓글[1] 랩돌이 20-12-28 94
질문 아두이노 깨짐현상댓글[3] 이미지첨부파일 ginnie92 20-12-28 102
질문 nodemcu 와이파이연결 질문입니다 !댓글[1] 꿈꾸는자 20-12-27 65
질문 millis()함수로 led와 버튼 제어가능할까요?댓글[4] 요식 20-12-23 140
질문 버튼과 led 제어 질문있습니다..댓글[3] 지우개 20-12-21 136
질문 led제어질문 있습니다..댓글[2] 이미지첨부파일 핑핑 20-12-19 112
질문 초음파 센서 질문입니다.댓글[1] 슬레이브 20-12-19 105
질문 코드 해석에 관한 질문입니다.댓글[1] 슬레이브 20-12-19 79
질문 atmega128 질문입니다!댓글[1] 슬레이브 20-12-19 125
질문 atmega128 질문드립니다.댓글[3] 하늘하늘 20-12-19 185
질문 아두이노 코딩 수정 질문입니다댓글[1] 이미지 붉은돼지 20-12-18 95
