질문게시판 > 답변 : 아두이노 소스 합치기
TODAY1,159 TOTAL1,448,403
BASIC4MCU | 질문게시판 | 답변 : 아두이노 소스 합치기
작성자 master 작성일2019-02-11 00:48 조회1,196회 댓글1건
// DateTime : 2019-02-11 오전 12:54:02
//----------------------------------------소스 1.
#include <SoftwareSerial.h>
int   T=2,R=3;
SoftwareSerial my_blue(T,R);
#include <DHT.h>
int temp_sensor=4;
DHT my_sensor(temp_sensor,DHT11);
#include <Servo.h>
Servo servo;
int   CDS_sensor  =A0// 조도센서
int   RAIN_sensor =A1
int   flame_sensor=A2;
int   SOUND_sensor=A3;
int   vibration_sensor=A4;
int   motor=A5;
int   ledPower=5;
int   sensor=6;
int   vibration_sensor=7;
int   red=10,green=9,blue=8;
int   RELAY=11;
int   PIR_sensor=12;
int   buzzer=13;
char  color;
int   flame=0,angle=0,freq=200;
  my_blue.begin(9600);
  my_sensor.begin();
  pinMode(ledPower,OUTPUT);
  pinMode(red,OUTPUT); pinMode(green,OUTPUT); pinMode(blue,OUTPUT);
  pinMode(buzzer,OUTPUT);
  pinMode(PIR_sensor,INPUT);       // 인체감지센서
  pinMode(vibration_sensor,INPUT); // 진동센서
  pinMode(sensor,INPUT);
  servo.attach(motor); servo.write(angle);
int getdust(){
  digitalWrite(ledPower,0);                 delayMicroseconds280); // samplingTime
  float voMeasured=analogRead(DUST_output); delayMicroseconds(  40); // deltaTime
  digitalWrite(ledPower,1);                 delayMicroseconds(9680); // sleepTime
  float calcVoltage=voMeasured*(3.3/1024);
  float dustDensity=100*calcVoltage-0.1;
  return(dustDensity);
void redFunction()   { digitalWrite(blue,  0); digitalWrite(green,  0); digitalWrite(red,  1); }
void blueFunction()  { digitalWrite(blue,  1); digitalWrite(green,  0); digitalWrite(red,  0); }
void greenFunction() { digitalWrite(blue,  0); digitalWrite(green,  1); digitalWrite(red,  0); }
void yellowFunction(){ digitalWrite(blue,  0); digitalWrite(green50); digitalWrite(red,255); }
void violetFunction(){ digitalWrite(blue,255); digitalWrite(green,  0); digitalWrite(red,255); }
void whiteFunction() { digitalWrite(blue,110); digitalWrite(green,220); digitalWrite(red,255); }
void cyanFunction()  { digitalWrite(blue,255); digitalWrite(green,255); digitalWrite(red,  0); }
  if(Serial.available()){
    color=Serial.read();
    if(color=='r'){ redFunction();    }
    if(color=='b'){ blueFunction();   }
    if(color=='g'){ greenFunction();  }
    if(color=='y'){ yellowFunction(); }
    if(color=='v'){ violetFunction(); }
    if(color=='w'){ whiteFunction();  }
    if(color=='c'){ cyanFunction();   }
  if(++count>=10){ count=0// 1초마다 측정
    int a=map(getdust(),8,133,10,100);
    char b[4]="";
    sprintf(b,"%03d",a); Serial.print("dust: "); Serial.println(b); delay(250);
    int readingSensor=analogRead(RAIN_sensor);
    Serial.print("rain: "); Serial.println(readingSensor); Serial.println();
    int temp=my_sensor.readTemperature();
    int humi=my_sensor.readHumidity();
    my_blue.print("temp: ");  my_blue.print(temp);
    my_blue.print("/humi: "); my_blue.println(humi);
    int sensor=analogRead(CDS_sensor); // 조도센서의 데이터 받아오기
    if(sensor>1000){           // 주위가 어둡다면
      if(angle<180)servo.write(++angle); // 서보 모터의 각도를 180도로
    else// 주위가 밝다면
      if(angle>0)servo.write(--angle); // 서보 모터의 각도를 180도로
    flame=analogRead(flame_sensor);
    Serial.print("Flame="); Serial.println(flame); // 시리얼통신 화면에 변수에 저장된 값을 출력
    if(flame>0){
      Serial.println(" Flame is around you ");
      if(freq!=1000)tone(buzzer,1000,50); else tone(buzzer,200,50);
  int vibration_data=digitalRead(vibration_sensor);
  Serial.print("vib: "); Serial.println(vibration_data);
  int value=digitalRead(PIR_sensor);
  Serial.println(value);
  digitalWrite(RELAY,value); // 인체 감지되면 2번에 전류를 흘려라 // 인체감지가 안되면 전류를 끊어라
  int Val=analogRead(SOUND_sensor); // 사운드센서 소음 측정
  if(Val>40)Serial.println(Val);
  delay(100); noTone(buzzer);
남는 핀이 없겠습니다.
참고해서 완성시켜보세요
조회수 1,196
열심히하자님의 댓글
열심히하자 작성일
감사합니다. 참고해서 완성시키겠습니다!
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 2677
공지 사이트 이용 안내댓글[16] master 17-10-29 14822
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 5663
질문 블루투스와 터치센서 질문드립니다~!!!! 새글 YMKIM 21-01-15 19
답변 답변글 답변 : 블루투스와 터치센서 질문드립니다~!!!! 새글 master 05:40 4
질문 ATmega128 LED 탑쌓기 반대방향 질문입니다.댓글[1] 새글 쩡쩡쭁 21-01-15 26
질문 아두이노 if에서 다른 버튼으로 else if 혹은 else로 넘어갔을때 오류입니다.댓글[5] 이미지새글첨부파일 LoadRian 21-01-14 19
질문 센싱 데이터 sd카드 저장 관련 코드 질문 드립니다.댓글[1] 첨부파일 우끼우기 21-01-13 21
질문 아두이노 서보모터 다중제어 질문드립니다.댓글[1] 서보모토능력자 21-01-12 45
질문 아두이노 MCP2515 CAN Module 을 통한 CAN data 전송댓글[1] 이미지첨부파일 흠압지 21-01-11 26
질문 유아전동차 블루트스 컨트롤+MP3댓글[2] kenneth 21-01-09 33
질문 디버깅하는데 입출력 코드에서 자꾸 멈춰요댓글[1] 이미지첨부파일 한입만 21-01-07 43
질문 UV LED 를 제어하는 함수는 없나요???댓글[1] 한입만 21-01-06 50
질문 네오픽셀 버튼 조합댓글[7] 지수 21-01-04 64
질문 아두이노 블루투스 모듈이랑 연결을 시도했을 때 안되요.댓글[3] 첨부파일 ONCE원스 20-12-31 120
질문 아두이노 for문에 random함수 가능한지 질문입니다!댓글[3] 호식이 20-12-30 87
질문 조도센서에 millis()로 특정부분 반복가능한가요?댓글[2] 그릇 20-12-29 78
질문 아트메가168 업로드 문제 아두이노배우기 20-12-29 57
질문 아두이노 조도센서와 RGB 3색 LED 4핀센서댓글[1] 해위 20-12-29 82
질문 아두이노 온습도센서 질문입니다.댓글[1] 랩돌이 20-12-28 92
질문 아두이노 깨짐현상댓글[3] 이미지첨부파일 ginnie92 20-12-28 102
질문 nodemcu 와이파이연결 질문입니다 !댓글[1] 꿈꾸는자 20-12-27 65
질문 millis()함수로 led와 버튼 제어가능할까요?댓글[4] 요식 20-12-23 139
질문 버튼과 led 제어 질문있습니다..댓글[3] 지우개 20-12-21 132
질문 led제어질문 있습니다..댓글[2] 이미지첨부파일 핑핑 20-12-19 109
질문 초음파 센서 질문입니다.댓글[1] 슬레이브 20-12-19 102
질문 코드 해석에 관한 질문입니다.댓글[1] 슬레이브 20-12-19 76
질문 atmega128 질문입니다!댓글[1] 슬레이브 20-12-19 120
질문 atmega128 질문드립니다.댓글[3] 하늘하늘 20-12-19 178
질문 아두이노 코딩 수정 질문입니다댓글[1] 이미지 붉은돼지 20-12-18 92
