질문게시판 > 답변 : 아두이노 소스 합치기
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 질문게시판
답변 : 아두이노 소스 합치기
작성자 master 작성일19-02-11 00:48 조회168회 댓글1건
// DateTime : 2019-02-11 오전 12:54:02
//----------------------------------------소스 1.
#include <SoftwareSerial.h>
int   T=2,R=3;
SoftwareSerial my_blue(T,R);
#include <DHT.h>
int temp_sensor=4;
DHT my_sensor(temp_sensor,DHT11);
#include <Servo.h>
Servo servo;
int   CDS_sensor  =A0// 조도센서
int   RAIN_sensor =A1
int   flame_sensor=A2;
int   SOUND_sensor=A3;
int   vibration_sensor=A4;
int   motor=A5;
int   ledPower=5;
int   sensor=6;
int   vibration_sensor=7;
int   red=10,green=9,blue=8;
int   RELAY=11;
int   PIR_sensor=12;
int   buzzer=13;
char  color;
int   flame=0,angle=0,freq=200;
  my_blue.begin(9600);
  my_sensor.begin();
  pinMode(ledPower,OUTPUT);
  pinMode(red,OUTPUT); pinMode(green,OUTPUT); pinMode(blue,OUTPUT);
  pinMode(buzzer,OUTPUT);
  pinMode(PIR_sensor,INPUT);       // 인체감지센서
  pinMode(vibration_sensor,INPUT); // 진동센서
  pinMode(sensor,INPUT);
  servo.attach(motor); servo.write(angle);
int getdust(){
  digitalWrite(ledPower,0);                 delayMicroseconds280); // samplingTime
  float voMeasured=analogRead(DUST_output); delayMicroseconds(  40); // deltaTime
  digitalWrite(ledPower,1);                 delayMicroseconds(9680); // sleepTime
  float calcVoltage=voMeasured*(3.3/1024);
  float dustDensity=100*calcVoltage-0.1;
  return(dustDensity);
void redFunction()   { digitalWrite(blue,  0); digitalWrite(green,  0); digitalWrite(red,  1); }
void blueFunction()  { digitalWrite(blue,  1); digitalWrite(green,  0); digitalWrite(red,  0); }
void greenFunction() { digitalWrite(blue,  0); digitalWrite(green,  1); digitalWrite(red,  0); }
void yellowFunction(){ digitalWrite(blue,  0); digitalWrite(green50); digitalWrite(red,255); }
void violetFunction(){ digitalWrite(blue,255); digitalWrite(green,  0); digitalWrite(red,255); }
void whiteFunction() { digitalWrite(blue,110); digitalWrite(green,220); digitalWrite(red,255); }
void cyanFunction()  { digitalWrite(blue,255); digitalWrite(green,255); digitalWrite(red,  0); }
  if(Serial.available()){
    color=Serial.read();
    if(color=='r'){ redFunction();    }
    if(color=='b'){ blueFunction();   }
    if(color=='g'){ greenFunction();  }
    if(color=='y'){ yellowFunction(); }
    if(color=='v'){ violetFunction(); }
    if(color=='w'){ whiteFunction();  }
    if(color=='c'){ cyanFunction();   }
  if(++count>=10){ count=0// 1초마다 측정
    int a=map(getdust(),8,133,10,100);
    char b[4]="";
    sprintf(b,"%03d",a); Serial.print("dust: "); Serial.println(b); delay(250);
    int readingSensor=analogRead(RAIN_sensor);
    Serial.print("rain: "); Serial.println(readingSensor); Serial.println();
    int temp=my_sensor.readTemperature();
    int humi=my_sensor.readHumidity();
    my_blue.print("temp: ");  my_blue.print(temp);
    my_blue.print("/humi: "); my_blue.println(humi);
    int sensor=analogRead(CDS_sensor); // 조도센서의 데이터 받아오기
    if(sensor>1000){           // 주위가 어둡다면
      if(angle<180)servo.write(++angle); // 서보 모터의 각도를 180도로
    else// 주위가 밝다면
      if(angle>0)servo.write(--angle); // 서보 모터의 각도를 180도로
    flame=analogRead(flame_sensor);
    Serial.print("Flame="); Serial.println(flame); // 시리얼통신 화면에 변수에 저장된 값을 출력
    if(flame>0){
      Serial.println(" Flame is around you ");
      if(freq!=1000)tone(buzzer,1000,50); else tone(buzzer,200,50);
  int vibration_data=digitalRead(vibration_sensor);
  Serial.print("vib: "); Serial.println(vibration_data);
  int value=digitalRead(PIR_sensor);
  Serial.println(value);
  digitalWrite(RELAY,value); // 인체 감지되면 2번에 전류를 흘려라 // 인체감지가 안되면 전류를 끊어라
  int Val=analogRead(SOUND_sensor); // 사운드센서 소음 측정
  if(Val>40)Serial.println(Val);
  delay(100); noTone(buzzer);
남는 핀이 없겠습니다.
참고해서 완성시켜보세요
  • 카카오톡으로 보내기
댓글 : 1
조회수 : 168
열심히하자님의 댓글
열심히하자 작성일
감사합니다. 참고해서 완성시키겠습니다!
BASIC4MCU > 질문게시판 목록
제목 날짜
공지 사이트 이용 안내 댓글[8] master  17-10-29
질문 1개 아두이노 보드에서 2개 HC-06을 사용하려는데 … 댓글[6] 신입 새글 19-08-22
질문 아두이노로 구동가능한지 궁금합니다. 댓글[1] 산업맨 새글 19-08-22
질문 atmega128 소스결합 오류 댓글[1] 첨부파일일본인호ㅈ두 새글 19-08-21
질문 임베디드 시스템에 대한 궁금증 master  19-08-21
질문 atmega128a 스위치 질문이요 댓글[1] 초짜  19-08-21
질문 아두이노 일사량 센서 댓글[1] 첨부파일아두이노배우기  19-08-20
질문 ATmega128 소스 합치기 첨부파일gksl  19-08-20
답변 답변 : ATmega128 소스 합치기 master  19-08-20
답변 답변 : 답변 : ATmega128 소스 합치기 첨부파일gksl  19-08-20
답변 답변 : 답변 : 답변 : ATmega128 소스 합치… 댓글[1] master  19-08-21
질문 아두이노 질문입니다! 댓글[2] M4E2A8  19-08-19
질문 atmega128a 카운터/타이머 출력비교 질문이요 댓글[1] 초짜  19-08-17
질문 모터드라이버 병렬 연결 댓글[3] 박준2  19-08-16
질문 서로 다른전원(5v 12v) 제어방법 질문 master  19-08-16
질문 모터드라이버 관련 질문 드립니다. 댓글[4] 박준이  19-08-15
질문 Atmega128, 초음파센서 ,부저 gksl  19-08-14
답변 답변 : Atmega128, 초음파센서 ,부저 댓글[1] master  19-08-15
질문 led 전력소모에 관하여,,, 댓글[11] 슬레a  19-08-14
질문 알고리즘 문의 댓글[1] 벅바  19-08-13
질문 블루투스가 한번 작동하고 그 다음부터 작동을 하지 않습… 댓글[1] 아야어여  19-08-13
질문 아두이노 코딩 질문입니다 너무 급해요 ㅠㅠ 댓글[3] 전민결  19-08-12
질문 코딩 작성좀 부탁드립니다. 너무 급합니다 ㅠㅠ 댓글[1] 아두이노보초  19-08-10
질문 stm32f1 계열에서 USB로 스마트폰 연결 방법(C… 댓글[2] 에르테르  19-08-08
질문 코딩을 합치고 싶습니다.. 알려주세요  19-08-08
답변 답변 : 코딩을 합치고 싶습니다.. master  19-08-08
질문 금속센서를 이용한 서보모터 돌리기 댓글[1] 후우  19-08-07
질문 아두이노로 빛 파장 계산하기 master  19-08-07
PC버전
