질문게시판 > 어떤분이 올린 소스를 활용하려고 하는데요. 질문좀 드려요
TODAY1,144 TOTAL1,448,388
BASIC4MCU | 질문게시판 | 어떤분이 올린 소스를 활용하려고 하는데요. 질문좀 드려요
작성자 스캉이 작성일2019-02-14 18:24 조회1,046회 댓글0건
어떤분이 피아노 소리를 나오게 하는 소스가 있어서 활용을 좀 해보려고 하는데요.
악기변경 버튼을 누리지 않고 wave2로 도레미파솔라시도를 연속으로 동작시키려면
어떻게 해야 하는지요?
#include <arduino.h>
#include "pitches.h"
int buzzer_pin = 6;
int music[8] = {NOTE_C4, NOTE_D4, NOTE_E4, NOTE_F4, NOTE_G4, NOTE_A4, NOTE_B4, NOTE_C5};
void dac_analog_write(unsigned char value);
int (*wave_function)(int millis_pos) = NULL;
unsigned long note_start_millis;
void note_on(unsigned int frequency);
void note_off();
  tone(buzzer_pin, frequency);
  note_start_millis = millis();
void note_off()
  noTone(buzzer_pin);
void update_adc_wave()
  unsigned int gap = millis() - note_start_millis;
  int value = wave_function(gap);
  dac_analog_write(value);
int wave1(int pos) // ding
  if ( pos < 100 )
    return 15;
    return max((15-(pos-100)/30),1);
int wave2(int pos) // slow_up
  return max(min(pos/30,15),1);
int wave3(int pos) // zi zic
  int val = pos%14;
  if ( val > 7 ) return 15;
  else return 7;
int wave4(int pos)
  if ( pos < 150 )
    return max((15-pos/30),1);
    return min(max(((pos-150)/30),1),15);
  value = 16 - value;
  unsigned char val = 0b00000001;
  for ( int i = 0; i < 4; i++)
    digitalWrite(i + 2, ( 0b00000001 & ( value >> i ) ));
int prev_btn_status1 = LOW;
int prev_btn_status2 = LOW;
int prev_btn_status3 = LOW;
int prev_btn_status4 = LOW;
int prev_btn_status5 = LOW;
int prev_btn_status6 = LOW;
int prev_btn_status7 = LOW;
int prev_btn_status8 = LOW;
int prev_btn_status9 = LOW;
int instrument_index = 0;
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(7,INPUT_PULLUP);
  pinMode(8,INPUT_PULLUP);
  pinMode(9,INPUT_PULLUP);
  pinMode(10,INPUT_PULLUP);
  pinMode(11,INPUT_PULLUP);
  pinMode(12,INPUT_PULLUP);
  pinMode(13,INPUT_PULLUP);
  pinMode(14,INPUT_PULLUP);
  pinMode(15,INPUT_PULLUP);
  wave_function = wave1;
// 도
  int btn_status1 = digitalRead(7);
  if ( (prev_btn_status1 == HIGH) && (btn_status1 == LOW) )
    note_on(NOTE_C6);
  if ( (prev_btn_status1 == LOW ) && (btn_status1 == HIGH ) )
    note_off();
// 레
  int btn_status2 = digitalRead(8);
  if ( (prev_btn_status2 == HIGH) && (btn_status2 == LOW) )
    note_on(NOTE_D6);
  if ( (prev_btn_status2 == LOW ) && (btn_status2 == HIGH ) )
    note_off();
// 미
  int btn_status3 = digitalRead(9);
  if ( (prev_btn_status3 == HIGH) && (btn_status3 == LOW) )
    note_on(NOTE_E6);
  if ( (prev_btn_status3 == LOW ) && (btn_status3 == HIGH ) )
    note_off();
// 파
  int btn_status4 = digitalRead(10);
  if ( (prev_btn_status4 == HIGH) && (btn_status4 == LOW) )
    note_on(NOTE_F6);
  if ( (prev_btn_status4 == LOW ) && (btn_status4 == HIGH ) )
    note_off();
// 솔
  int btn_status5 = digitalRead(11);
  if ( (prev_btn_status5 == HIGH) && (btn_status5 == LOW) )
    note_on(NOTE_G6);
  if ( (prev_btn_status5 == LOW ) && (btn_status5 == HIGH ) )
    note_off();
// 라
  int btn_status6 = digitalRead(12);
  if ( (prev_btn_status6 == HIGH) && (btn_status6 == LOW) )
    note_on(NOTE_A6);
  if ( (prev_btn_status6 == LOW ) && (btn_status6 == HIGH ) )
    note_off();
// 시
  int btn_status7 = digitalRead(13);
  if ( (prev_btn_status7 == HIGH) && (btn_status7 == LOW) )
    note_on(NOTE_B6);
  if ( (prev_btn_status7 == LOW ) && (btn_status7 == HIGH ) )
    note_off();
// 도
  int btn_status8 = digitalRead(14);
  if ( (prev_btn_status8 == HIGH) && (btn_status8 == LOW) )
    note_on(NOTE_C7);
  if ( (prev_btn_status8 == LOW ) && (btn_status8 == HIGH ) )
    note_off();
// 악기 변경
  int btn_status9 = digitalRead(15);
  if ( (prev_btn_status9 == HIGH) && (btn_status9 == LOW) )
    instrument_index++;
    if ( instrument_index > 3 ) instrument_index = 0;
    if ( instrument_index == 0 )
    if ( instrument_index == 1 )
      wave_function = wave2;
    if ( instrument_index == 2 )
      wave_function = wave3;
    if ( instrument_index == 3 )
      wave_function = wave4;
  update_adc_wave();
  prev_btn_status1 = btn_status1;
  prev_btn_status2 = btn_status2;
  prev_btn_status3 = btn_status3;
  prev_btn_status4 = btn_status4;
  prev_btn_status5 = btn_status5;
  prev_btn_status6 = btn_status6;
  prev_btn_status7 = btn_status7;
  prev_btn_status8 = btn_status8;
  prev_btn_status9 = btn_status9;
  delay(5);
조회수 1,046
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 2677
공지 사이트 이용 안내댓글[16] master 17-10-29 14822
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 5663
질문 블루투스와 터치센서 질문드립니다~!!!! 새글 YMKIM 21-01-15 19
답변 답변글 답변 : 블루투스와 터치센서 질문드립니다~!!!! 새글 master 05:40 4
질문 ATmega128 LED 탑쌓기 반대방향 질문입니다.댓글[1] 새글 쩡쩡쭁 21-01-15 26
질문 아두이노 if에서 다른 버튼으로 else if 혹은 else로 넘어갔을때 오류입니다.댓글[5] 이미지새글첨부파일 LoadRian 21-01-14 19
질문 센싱 데이터 sd카드 저장 관련 코드 질문 드립니다.댓글[1] 첨부파일 우끼우기 21-01-13 21
질문 아두이노 서보모터 다중제어 질문드립니다.댓글[1] 서보모토능력자 21-01-12 44
질문 아두이노 MCP2515 CAN Module 을 통한 CAN data 전송댓글[1] 이미지첨부파일 흠압지 21-01-11 26
질문 유아전동차 블루트스 컨트롤+MP3댓글[2] kenneth 21-01-09 32
질문 디버깅하는데 입출력 코드에서 자꾸 멈춰요댓글[1] 이미지첨부파일 한입만 21-01-07 42
질문 UV LED 를 제어하는 함수는 없나요???댓글[1] 한입만 21-01-06 49
질문 네오픽셀 버튼 조합댓글[7] 지수 21-01-04 63
질문 아두이노 블루투스 모듈이랑 연결을 시도했을 때 안되요.댓글[3] 첨부파일 ONCE원스 20-12-31 119
질문 아두이노 for문에 random함수 가능한지 질문입니다!댓글[3] 호식이 20-12-30 86
질문 조도센서에 millis()로 특정부분 반복가능한가요?댓글[2] 그릇 20-12-29 78
질문 아트메가168 업로드 문제 아두이노배우기 20-12-29 57
질문 아두이노 조도센서와 RGB 3색 LED 4핀센서댓글[1] 해위 20-12-29 81
질문 아두이노 온습도센서 질문입니다.댓글[1] 랩돌이 20-12-28 92
질문 아두이노 깨짐현상댓글[3] 이미지첨부파일 ginnie92 20-12-28 101
질문 nodemcu 와이파이연결 질문입니다 !댓글[1] 꿈꾸는자 20-12-27 64
질문 millis()함수로 led와 버튼 제어가능할까요?댓글[4] 요식 20-12-23 138
질문 버튼과 led 제어 질문있습니다..댓글[3] 지우개 20-12-21 131
질문 led제어질문 있습니다..댓글[2] 이미지첨부파일 핑핑 20-12-19 108
질문 초음파 센서 질문입니다.댓글[1] 슬레이브 20-12-19 102
질문 코드 해석에 관한 질문입니다.댓글[1] 슬레이브 20-12-19 76
질문 atmega128 질문입니다!댓글[1] 슬레이브 20-12-19 120
질문 atmega128 질문드립니다.댓글[3] 하늘하늘 20-12-19 178
질문 아두이노 코딩 수정 질문입니다댓글[1] 이미지 붉은돼지 20-12-18 92
