질문게시판 > 답변 : 안녕하세요 ! 코드를 합치는 것좀 도와주실 수 있으신가요?
TODAY594 TOTAL1,456,403
BASIC4MCU | 질문게시판 | 답변 : 안녕하세요 ! 코드를 합치는 것좀 도와주실 수 있으신가요?
작성자 master 작성일2019-02-26 21:29 조회1,092회 댓글0건
이 글의 소스코드와 동일하겠죠?
// DateTime : 2019-02-26 오후 9:34:06
#define BAUDRATE          57600
#define Theshold_Eyeblink 110
#define EEG_AVG           70
#define DEBUGOUTPUT       0
bool         flag=0,bigPacket=0,On_Flag=0,Off_Flag=1,Eye_Enable=0;
byte         payloadData[64]={0},poorQuality=0,generatedChecksum=0,checksum=0;
byte         attention=0,blinkstrenth=0,meditation=0,delta=0,low_gamma=0;
int          payloadLength=0;
unsigned int j,n=0,Raw_data,Poorquality;
long         lastReceivedPacket=0,Temp,Avg_Raw,Temp_Avg,payloadDataS[5]={0},payloadDataB[32]={0};
float        high_alpha=0;
byte ReadOneByte(){
  int ByteRead;
  while(!Serial.available());
  ByteRead=Serial.read();
  return ByteRead;
void Small_Packet(){
  generatedChecksum=0;
  for(int i=0i<payloadLengthi++){
    payloadDataS[i]=ReadOneByte();
    generatedChecksum+=payloadDataS[i];
  generatedChecksum=255-generatedChecksum;
  checksum=ReadOneByte();
  if(checksum==generatedChecksum){
    if(j<512){
      Raw_data=((payloadDataS[2]<<8)|payloadDataS[3]);
      if(Raw_data&0xF000){ Raw_data=(((~Raw_data)&0xFFF)+1); }
      else               { Raw_data=(Raw_data&0xFFF);        }
      Temp+=Raw_data;
      j++;
    elseOnesec_Rawval_Fun(); }
void Big_Packet(){
    payloadDataB[i]=ReadOneByte();
    generatedChecksum+=payloadDataB[i];
    Poorquality=payloadDataB[1];
    if(Poorquality==0)Eye_Enable=1else Eye_Enable=0;
void Onesec_Rawval_Fun(){
  Avg_Raw=Temp/512;
  if(On_Flag==0&&Off_Flag==1){
    if(n<3){ Temp_Avg+=Avg_Raw;   n++; }
    else   { Temp_Avg=Temp_Avg/3n=0if(Temp_Avg<EEG_AVG){ On_Flag=1Off_Flag=0; } Temp_Avg=0; }
  Eye_Blink();
  j=0Temp=0;
void Eye_Blink(){
  if(Eye_Enable){
    if(On_Flag==1&&Off_Flag==0){
      if((Avg_Raw>Theshold_Eyeblink)&&(Avg_Raw<350)){   Serial.println("On_Flag==1"); }
      elseif(Avg_Raw>350){ On_Flag==0Off_Flag==1; } Serial.println("On_Flag==0"); }
    elseSerial.println("On_Flag==0"); }
  Serial.begin(BAUDRATE);
  if(ReadOneByte()==170){
      payloadLength=ReadOneByte();
      if(payloadLength>169)return;
      if     (payloadLength== 4){ Small_Packet(); } // Small Packet
      else if(payloadLength==32){ Big_Packet();   } // Big Packet
      for(int i=0i<payloadLengthi++){ payloadData[i]=ReadOneByte(); generatedChecksum+=payloadData[i]; }
        poorQuality=200attention=0meditation=0blinkstrenth=0;
          switch(payloadData[i]){
            case 0x02i++;   poorQuality=payloadData[i];  bigPacket=true;         break;
            case 0x04i++;   attention=payloadData[i];                            break;
            case 0x05i++;   meditation=payloadData[i];                           break;
            case 0x16i++;   blinkstrenth=payloadData[i]; if(blinkstrenth)flag=1break;
            case 0x80i+= 3;                                                      break;
            case 0x83i+=25;                                                      break;
        if(bigPacket){
          Serial.print("PoorQuality: "); Serial.print(poorQuality,DEC);
          Serial.print(" Attention: ");  Serial.print(attention,DEC);
          Serial.print(" meditation: "); Serial.print(meditation,DEC);
          Serial.print(" Time: ");       Serial.println(millis()-lastReceivedPacket,DEC);
          lastReceivedPacket=millis();
        bigPacket=false;
LED가 필요 없으면 삭제하면 됩니다.
두 소스의 유사한 부분을 체크해서 중복되는 것을 제거하고
매끄럽게 동작하도록 수정하셔야합니다.
디버깅은 동작시키면서 증상을 봐가면서 수정해야 하므로
다른 사람은 돌려보지 못하므로 스스로 하셔야합니다.
조회수 1,092
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 2711
공지 사이트 이용 안내댓글[16] master 17-10-29 14939
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 5714
질문 아두이노 interrupt 스위치 워터펌프 제어댓글[1] 새글 뱅이주인 21-01-20 17
질문 컴파일시 에러가 발생합니다.댓글[1] 새글 같치 21-01-20 24
질문 거리센서 질문 좀 드리겠습니다..댓글[3] 새글 코딩공부하자 21-01-19 35
답변 답변글 답변 : 거리센서 질문 좀 드리겠습니다..댓글[2] 새글 코딩공부하자 21-01-19 45
질문 블루투스와 터치센서 질문드립니다~!!!! YMKIM 21-01-15 49
답변 답변글 답변 : 블루투스와 터치센서 질문드립니다~!!!! master 21-01-16 36
질문 ATmega128 LED 탑쌓기 반대방향 질문입니다.댓글[2] 쩡쩡쭁 21-01-15 77
질문 아두이노 if에서 다른 버튼으로 else if 혹은 else로 넘어갔을때 오류입니다.댓글[5] 이미지첨부파일 LoadRian 21-01-14 50
질문 센싱 데이터 sd카드 저장 관련 코드 질문 드립니다.댓글[1] 첨부파일 우끼우기 21-01-13 45
질문 아두이노 서보모터 다중제어 질문드립니다.댓글[1] 서보모토능력자 21-01-12 75
질문 아두이노 MCP2515 CAN Module 을 통한 CAN data 전송댓글[1] 이미지첨부파일 흠압지 21-01-11 56
질문 유아전동차 블루트스 컨트롤+MP3댓글[2] kenneth 21-01-09 53
질문 디버깅하는데 입출력 코드에서 자꾸 멈춰요댓글[1] 이미지첨부파일 한입만 21-01-07 67
질문 UV LED 를 제어하는 함수는 없나요???댓글[1] 한입만 21-01-06 72
질문 네오픽셀 버튼 조합댓글[7] 지수 21-01-04 91
답변 답변글 답변 : 네오픽셀 버튼 조합댓글[1] 이미지첨부파일 지수 21-01-18 26
질문 아두이노 블루투스 모듈이랑 연결을 시도했을 때 안되요.댓글[3] 첨부파일 ONCE원스 20-12-31 143
질문 아두이노 for문에 random함수 가능한지 질문입니다!댓글[3] 호식이 20-12-30 106
질문 조도센서에 millis()로 특정부분 반복가능한가요?댓글[2] 그릇 20-12-29 103
질문 아트메가168 업로드 문제 아두이노배우기 20-12-29 81
질문 아두이노 조도센서와 RGB 3색 LED 4핀센서댓글[1] 해위 20-12-29 111
질문 아두이노 온습도센서 질문입니다.댓글[1] 랩돌이 20-12-28 118
질문 아두이노 깨짐현상댓글[3] 이미지첨부파일 ginnie92 20-12-28 127
질문 nodemcu 와이파이연결 질문입니다 !댓글[1] 꿈꾸는자 20-12-27 85
질문 millis()함수로 led와 버튼 제어가능할까요?댓글[4] 요식 20-12-23 160
질문 버튼과 led 제어 질문있습니다..댓글[3] 지우개 20-12-21 156
질문 led제어질문 있습니다..댓글[2] 이미지첨부파일 핑핑 20-12-19 133
