질문게시판 > 아두이노 소스코드 합치기 질문
TODAY1,060 TOTAL430,660
BASIC4MCU | 질문게시판 | 아두이노 소스코드 합치기 질문
작성자 master 작성일2019-03-08 18:11 조회23회 댓글0건
두 개의 코딩을 하나로 합쳐야 하는데요...
각각의 코딩은 잘 작동됩니다. 그런데 합치려고하니 어떻게 할지 막막해서 질문드려봅니다.
고수님들 부탁드립니다.ㅠㅠ
1번 코딩
#define LED 13
#define BAUDRATE 57600
#define DEBUGOUTPUT 0
// checksum variables
byte generatedChecksum = 0;
byte checksum = 0;
int flag=0;
int payloadLength = 0;
byte payloadData[64] = {0};
byte poorQuality = 0;
byte attention = 0;
byte blinkstrenth =0;
byte meditation = 0;
byte delta =0;
float high_alpha = 0;
byte low_gamma = 0;
// system variables
long lastReceivedPacket = 0;
boolean bigPacket = false;
// Microprocessor Setup //
  Serial.begin(BAUDRATE);           // USB
// Read data from Serial UART //
byte ReadOneByte()
  int ByteRead;
  while(!Serial.available());
  ByteRead = Serial.read();
  return ByteRead;
  // Look for sync bytes
  if(ReadOneByte() == 170)
        payloadLength = ReadOneByte();
        if(payloadLength > 169)          //Payload length can not be greater than 169
        return;
        for(int i = 0; i < payloadLength; i++)
        payloadData[i] = ReadOneByte();            //Read payload into memory
        generatedChecksum += payloadData[i];
         checksum = ReadOneByte();         //Read checksum byte from stream
        generatedChecksum = 255 - generatedChecksum;   //Take one's compliment of generated checksum
        if(checksum == generatedChecksum)
          poorQuality = 200;
          attention = 0;
          meditation = 0;
          blinkstrenth = 0;
{ // Parse the payload
          switch (payloadData[i])
          case 2:
            i++;
            poorQuality = payloadData[i];
            bigPacket = true;
          case 4:
            i++;
attention = payloadData[i];
          case 5:
            i++;
            meditation = payloadData[i];
          case 0x16: //Blink
            i++;
            blinkstrenth = payloadData[i];
            if(blinkstrenth)
            flag=1;
          case 0x80:
            i = i + 3;
          case 0x83:
          // eight big-endian 3-byte unsigned integer values representing
          // delta(0~2), theta(3~5), low-alpha(6~8),high-alpha(9~11), low-beta(12~14), high-beta(15~17)
          // low-gamma(18~20), and mid-gamma(21~23)
          //These values have no units and therefore are only meaningful compared to each other and to themselves, to consider relative quantity and temporal fluctuations.
          i=i+25;
          } // switch
        } // for loop
       if(bigPacket)
          Serial.print("PoorQuality: ");
          Serial.print(poorQuality, DEC);
          Serial.print(" Attention: ");
          Serial.print(attention, DEC);
          Serial.print(" meditation: ");
          Serial.print(meditation, DEC);
          Serial.print(" Time : ");
          Serial.print(millis() - lastReceivedPacket, DEC);
          lastReceivedPacket = millis();
          Serial.print("\n");
          switch(attention / 10)
          case 0:
          case 1:
          case 2:
          case 3:
          case 4:
          case 5:
          case 6:
          case 7:
          case 8:
          case 9:
          case 10:
        bigPacket = false;
      else {
        // Checksum Error
      }  // end if else for checksum
    } // end if read 0xAA byte
2번 코딩
#define LED 8
#define Theshold_Eyeblink 110
#define EEG_AVG 70
long payloadDataS[5]={0};
long payloadDataB[32]={0};
byte checksum=0,generatedchecksum=0;
unsigned int Raw_data,Poorquality,Plength,Eye_Enable=0,On_Flag=0,Off_Flag=1;
unsigned int j,n=0;
long Temp,Avg_Raw,Temp_Avg;
  pinMode(LED,OUTPUT);
byte ReadOneByte(){ // One Byte Read Function
  int ByteRead;
  ByteRead=Serial.read();
  return ByteRead;
  if(ReadOneByte()==170){ // AA 1 st Sync data
    if(ReadOneByte()==170){ // AA 2 st Sync data
      Plength=ReadOneByte();
      if(Plength==4){ Small_Packet(); } // Small Packet
      else if(Plength==32){ Big_Packet(); } // Big Packet
void Small_Packet(){
  for(int i=0; i<Plength; i++){
    payloadDataS[i]=ReadOneByte(); //Read payload into memory
    generatedchecksum+=payloadDataS[i];
  generatedchecksum=255-generatedchecksum;
  checksum=ReadOneByte();
  if(checksum==generatedchecksum){ // Varify Checksum
    if(j<512){
      Raw_data=((payloadDataS[2]<<8)|payloadDataS[3]);
      if(Raw_data&0xF000){ Raw_data=(((~Raw_data)&0xFFF)+1); }
      else{ Raw_data=(Raw_data&0xFFF); }
      Temp+=Raw_data;
      j++;
    else{ Onesec_Rawval_Fun(); }
void Big_Packet(){
    payloadDataB[i]=ReadOneByte(); //Read payload into memory
    generatedchecksum+=payloadDataB[i];
    Poorquality=payloadDataB[1];
    if(Poorquality==0){ Eye_Enable=1; } else{ Eye_Enable=0; }
void Onesec_Rawval_Fun(){
  Avg_Raw=Temp/512;
  if(On_Flag==0&&Off_Flag==1){
    if(n<3){ Temp_Avg+=Avg_Raw; n++; }
      Temp_Avg=Temp_Avg/3;
      if(Temp_Avg<EEG_AVG){ On_Flag=1; Off_Flag=0; }
      n=0; Temp_Avg=0;
  Eye_Blink();
  j=0;
  Temp=0;
 void Eye_Blink ()
   if (Eye_Enable)
     if (On_Flag==1 && Off_Flag==0)
       if ((Avg_Raw>Theshold_Eyeblink) && (Avg_Raw<350))
         digitalWrite(LED,HIGH);
         Serial.println("On_Flag==1");
         if (Avg_Raw>350)
           On_Flag==0;Off_Flag==1;
         digitalWrite(LED,LOW);
         Serial.println("On_Flag==0");
// DateTime : 2019-02-26 오전 11:30:03
#define EEG_AVG           70
#define LED               13
byte  generatedChecksum=0,checksum=0;
byte  payloadData[64]={0},poorQuality=0,attention=0,blinkstrenth=0,meditation=0,delta=0,low_gamma=0;
int   flag=0,payloadLength=0;
float high_alpha=0;
long  lastReceivedPacket=0;
bool  bigPacket=false;
unsigned int j,n=0,Raw_data,Poorquality,Eye_Enable=0,On_Flag=0,Off_Flag=1;
long         Temp,Avg_Raw,Temp_Avg,payloadDataS[5]={0},payloadDataB[32]={0};
byte ReadOneByte(){
  int ByteRead;
  return ByteRead;
  for(int i=0i<payloadLengthi++){
    if(j<512){
      else               { Raw_data=(Raw_data&0xFFF); }
      Temp+=Raw_data;
      j++;
    elseOnesec_Rawval_Fun(); }
void Big_Packet(){
    if(Poorquality==0){ Eye_Enable=1; } elseEye_Enable=0; }
  Avg_Raw=Temp/512;
    if(n<3){ Temp_Avg+=Avg_Rawn++; }
      if(Temp_Avg<EEG_AVG){ On_Flag=1Off_Flag=0; }
      n=0Temp_Avg=0;
  Eye_Blink();
  j=0Temp=0;
void Eye_Blink(){
  if(Eye_Enable){
    if(On_Flag==1&&Off_Flag==0){
      if((Avg_Raw>Theshold_Eyeblink)&&(Avg_Raw<350)){ digitalWrite(LED,HIGH); Serial.println("On_Flag==1"); }
        if(Avg_Raw>350){ On_Flag==0Off_Flag==1; }
    elsedigitalWrite(LED,LOW); Serial.println("On_Flag==0"); }
      payloadLength=ReadOneByte();
      if(payloadLength>169)return;
      if     (payloadLength== 4){ Small_Packet(); } // Small Packet
      else if(payloadLength==32){ Big_Packet(); } // Big Packet
      generatedChecksum=0;
      for(int i=0i<payloadLengthi++){ payloadData[i]=ReadOneByte(); generatedChecksum+=payloadData[i]; }
      generatedChecksum=255-generatedChecksum;
      if(checksum==generatedChecksum){
        poorQuality=200attention=0meditation=0blinkstrenth=0;
          switch(payloadData[i]){
            case 0x02i++;   poorQuality=payloadData[i];  bigPacket=truebreak;
            case 0x04i++;   attention=payloadData[i];    break;
            case 0x05i++;   meditation=payloadData[i];   break;
            case 0x16i++;   blinkstrenth=payloadData[i]; if(blinkstrenth)flag=1break;
            case 0x80i+= 3break;
            case 0x83i+=25break;
        if(bigPacket){
          Serial.print("PoorQuality: "); Serial.print(poorQuality,DEC);
          Serial.print(" Attention: "); Serial.print(attention,DEC);
          Serial.print(" meditation: "); Serial.print(meditation,DEC);
          Serial.print(" Time: "); Serial.print(millis()-lastReceivedPacket,DEC);
          lastReceivedPacket=millis();
          Serial.print("\n");
          switch(attention/10){
            case 0: break;
            case 1: break;
            case 2: break;
            case 3: break;
            case 4: break;
            case 5: break;
            case 6: break;
            case 7: break;
            case 8: break;
            case 9: break;
            case 10: break;
        bigPacket=false;
      else{ } // end if else for checksum
합치는 것은 어렵지 않으나
문제가 없도록 코드를 손보는 것은 직접하셔야합니다.
조회수 23
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 129
공지 사이트 이용 안내 댓글[5] master 17-10-29 5121
질문 AVR STUDIO 4.19 & AVRISP MKII USB 댓글[1] 새글 오박사 19-03-18 12
질문 예제 코드 구합니다 댓글[1] 새글첨부파일 오박사 19-03-18 10
질문 마스터님! 고생하십니다! 인터럽트 질문좀 드리겠습니다. 새글 닷모드 19-03-18 8
답변 답변글 답변 : 마스터님! 고생하십니다! 인터럽트 질문좀 드리겠습니다. 새글 master 10:36 4
질문 시리얼 통신 키보드 질문드립니다. 댓글[1] 새글 이이제이 19-03-18 15
질문 스텝모터 제어 역방향 회전시 힘이 약하게 돌아가는 현상 궁금합니다 19-03-16 13
답변 답변글 답변 : 스텝모터 제어 역방향 회전시 힘이 약하게 돌아가는 현상 댓글[2] master 19-03-16 20
질문 아두이노시리얼 0xff가 available 사용해도 계속 뜨네요ㅠㅠ yangty01 19-03-16 8
답변 답변글 답변 : 아두이노시리얼 0xff가 available 사용해도 계속 뜨네요ㅠㅠ master 19-03-16 6
질문 atmega128 Switch를 이용한 FND제어 질문 master 19-03-16 6
질문 아두이노 시리얼통신 질문합니다. 댓글[3] 이이제이 19-03-16 25
질문 ATmega128에 대해서... 댓글[2] YDyd 19-03-15 24
질문 프로세싱 RFID 태그시 색변화.. 댓글[1] ksyh2030 19-03-14 23
질문 avr i2c eeprom 코드관련해서요 댓글[1] 이미지첨부파일 남이 19-03-14 21
질문 avr에 대해서... 댓글[3] YDyd 19-03-14 34
질문 초음파 용착기에 대해 질문드립니다! ! 댓글[2] 닷모드 19-03-12 30
질문 Pir센서 감지 후 rf433 송신기 A반장 19-03-12 18
답변 답변글 답변 : Pir센서 감지 후 rf433 송신기 댓글[13] master 19-03-12 40
답변 답변글 답변 : 답변 : Pir센서 감지 후 rf433 송신기 댓글[11] master 19-03-14 42
질문 레오나르도 시리얼통신 마우스 질문드립니다. 댓글[1] 이이제이 19-03-11 20
답변 답변글 답변 : 레오나르도 시리얼통신 마우스 질문드립니다. 댓글[5] master 19-03-12 36
답변 답변글 답변 : 답변 : 레오나르도 시리얼통신 마우스 질문드립니다. 댓글[4] master 19-03-12 29
답변 답변글 답변 : 답변 : 답변 : 레오나르도 시리얼통신 마우스 질문드립니다. 댓글[18] master 19-03-13 85
답변 답변글 답변 : 답변 : 답변 : 답변 : 레오나르도 시리얼통신 마우스 질문드립니다. 댓글[2] master 19-03-14 26
질문 아두이노 스텝모터 제어에 대해 질문드립니다. 닷모드 19-03-11 26
답변 답변글 답변 : 아두이노 스텝모터 제어에 대해 질문드립니다. 댓글[6] master 19-03-12 39
답변 답변글 답변 : 답변 : 아두이노 스텝모터 제어에 대해 질문드립니다. 댓글[2] master 19-03-14 29
질문 ATmega에 대하여 궁금합니다. YDyd 19-03-11 15
