BASIC4MCU | 질문게시판 | 코딩 수정문의입니다
작성자 오토의반란 작성일2019-04-28 15:31 조회3,786회 댓글0건본문
기본적인 동작은 하는데
업체에서 원하는 동작으로 수정 해줘야하는데
현장방문해서 해주실수 있는게 가능한지 여쭤봅니다
이게 난이도가 그나마 높은 편입니다
#include "Functions.h"
// 0 -> LEFT BOTTOM A0
// 1 -> LEFT MIDDLE A1
// 2 -> LEFT TOP A2
// 4 -> RIGHT BOTTOM A4
// 5 -> RIGHT MIDDLE A5
// 6 -> RIGHT TOP A6
ISR(TIMER1_COMPA_vect) {
if (Flag1) {
TCNT1 = 0;
switch (STEP[0]) {
case 0: //1
if (step_motor0.steps() != ((Step90 / 9) * 7)) SELECT_MOTOR(0, INCREASE);
else {
step_motor0.step_to(0);
SELECT_MOTOR(0, STOP);
if (step_motor6.steps() != Step90) SELECT_MOTOR(6, INCREASE);
else {
RIGHT_ACTIVE;
RIGHT_COUNT_UP; //0
RIGHT_COUNT_UP; //1
step_motor6.step_to(0);
SELECT_MOTOR(6, STOP);
LEFT_DEACTIVE;
case 1:
if (step_motor0.steps() != ((Step90 / 9) * 5)) SELECT_MOTOR(0, DECREASE);
else {
GOTO_HOME_ACTIVE;
LEFT_CLEAR;
RIGHT_CLEAR;
LEFT_DEACTIVE;
RIGHT_DEACTIVE;
ISR(TIMER1_COMPB_vect) {
if (Flag2) {
TCNT1 = 0;
switch (STEP[1]) {
case 0: //2
else {
RIGHT_COUNT_UP;
case 1: //3
if (step_motor4.steps() != Step90 / 2) SELECT_MOTOR(4, INCREASE);
else {
RIGHT_COUNT_UP;
step_motor4.step_to(0);
SELECT_MOTOR(4, STOP);
case 2: //4
if (step_motor5.steps() != Step90 / 2) SELECT_MOTOR(5, INCREASE);
else {
LEFT_ACTIVE;
LEFT_COUNT_UP;
step_motor5.step_to(0);
SELECT_MOTOR(5, STOP);
RIGHT_DEACTIVE;
RIGHT_CLEAR;
//#define MOTOR_TEST //////////////////////////////////////////////////
step_motor0.attach(2, 0, 3, 1);
step_motor1.attach(2, 0, 3, 1);
step_motor2.attach(6, 4, 7, 5);
step_motor3.attach(2, 0, 3, 1);
step_motor4.attach(2, 0, 3, 1);
step_motor5.attach(6, 4, 7, 5);
step_motor6.attach(6, 4, 7, 5);
while (0) {
Serial.println(SW_STATUS(6));
#ifdef MOTOR_TEST
SW_init();
int i = 10;
Serial.setTimeout(10);
while (1) {
Serial.println("Wating");
if (Serial.available()) {
if (Serial.read() == 's') {
Serial.println("Start");
while (1) {
if (Serial.available()) i = Serial.parseInt();
if (1 <= i and i <= 7) {
if (SW_STATUS(i - 1)) break;
SELECT_MOTOR(i - 1, INCREASE);
} else if (-7 <= i and i <= -1) {
if (SW_STATUS(abs(i) - 1)) break;
SELECT_MOTOR(abs(i) - 1, DECREASE);
} else {
for (uint8_t n = 0; n < 7; n++) SELECT_MOTOR(n, STOP);
_delay_us(1000);
Serial.println("Done");
while (1);
#endif
#ifndef MOTOR_TEST
SW_init();
Serial.println("Stepper motor init start");
for (uint8_t i = 0; i < 7; i++) SELECT_MOTOR(i, INCREASE);
for (uint8_t i = 0; i < 7; i++) SELECT_MOTOR(i, STOP);
Serial.println("Stepper motor init done");
Serial.println("Left Stepper motor go to home");
while (1) {
for (uint8_t i = 0; i <= 2; i++) {
if (!SW_STATUS(i) && (flag[i] == 0)) SELECT_MOTOR(i, DECREASE); //DE
else {
flag[i] = 1;
_delay_us(800); //800
if ((flag[0]*flag[1]*flag[2]) != 0) break;
Serial.println("Left Stepper motor stop");
Serial.println("Right Stepper motor go to home");
while (1) {
for (uint8_t i = 4; i <= 6; i++) {
else {
flag[i] = 1;
_delay_us(800);
if ((flag[4]*flag[5]*flag[6]) != 0) break;
Serial.println("Right Stepper motor stop");
delayMicroseconds(1000);
Serial.println("All Stepper motor steps clear");
step_motor1.step_to(0);
step_motor2.step_to(0);
step_motor3.step_to(0);
Serial.println("STEP[0] = 0");
LEFT_COUNT_UP;
delay(500);
#endif
Serial.println("Left Timer Counter active");
LEFT_ACTIVE;
Serial.println("Right Timer Counter deactive");
RIGHT_DEACTIVE;
GOTO_HOME_DEACTIVE;
interrupt_init(0b10);
sei();
if (Flag4) {
_delay_ms(1000);
Serial.println("*************Homing");
for (uint8_t i = 0; i < 7; i++) flag[i] = 0;
LEFT_CLEAR;
RIGHT_CLEAR;
Serial.println("All Stepper motor go to home");
while (1) {
for (uint8_t i = 0; i <= 6; i++) {
if(i == 3) continue;
else {
flag[i] = 1;
_delay_us(1000);
/* while (1) {
else {
flag[i] = 1;
_delay_us(1000);
LEFT_COUNT_UP;//STEP[0] = 0;
LEFT_DEACTIVE;
RIGHT_DEACTIVE;
TIMSK1 |= (1 << OCIE1A);
GOTO_HOME_DEACTIVE;
Serial.println("*************Done");
조회수 3,786등록된 댓글이 없습니다.
