BASIC4MCU | 질문게시판 | 답변 : 코딩 수정문의입니다
작성자 master 작성일2019-04-28 16:06 조회5,892회 댓글2건
https://www.basic4mcu.com/bbs/board.php?bo_table=gac&wr_id=8359
작성일
// MCU BASIC: https://www.basic4mcu.com// DateTime : 2019-04-28 오후 4:12:14// by Ok-Hyun Park//#include "Functions.h"// 0->LEFT BOTTOM A0// 1->LEFT MIDDLE A1// 2->LEFT TOP A2// 4->RIGHT BOTTOM A4// 5->RIGHT MIDDLE A5// 6->RIGHT TOP A6ISR(TIMER1_COMPA_vect){if(Flag1){TCNT1=0;switch(STEP[0]){case 0: //1if(step_motor0.steps()!=((Step90/9)*7)){ SELECT_MOTOR(0,INCREASE); }else { step_motor0.step_to(0); SELECT_MOTOR(0,STOP); }//if(step_motor6.steps()!=Step90)SELECT_MOTOR(6,INCREASE);else{RIGHT_ACTIVE; RIGHT_COUNT_UP; RIGHT_COUNT_UP; //0 //1step_motor6.step_to(0); SELECT_MOTOR(6,STOP); LEFT_DEACTIVE;}break;case 1:if(step_motor0.steps()!=((Step90/9)*5))SELECT_MOTOR(0,DECREASE);else{GOTO_HOME_ACTIVE; LEFT_CLEAR; RIGHT_CLEAR; step_motor0.step_to(0);SELECT_MOTOR(0,STOP); LEFT_DEACTIVE; RIGHT_DEACTIVE;}break;}}}//ISR(TIMER1_COMPB_vect){if(Flag2){TCNT1=0;switch(STEP[1]){case 0: //2if(step_motor6.steps()!=Step90){ SELECT_MOTOR(6,INCREASE); }else { RIGHT_COUNT_UP; step_motor6.step_to(0); SELECT_MOTOR(6,STOP); }break;case 1: //3if(step_motor4.steps()!=Step90/2){ SELECT_MOTOR(4,INCREASE); }else { RIGHT_COUNT_UP; step_motor4.step_to(0); SELECT_MOTOR(4,STOP); }break;case 2: //4if(step_motor5.steps()!=Step90/2)SELECT_MOTOR(5,INCREASE);else{LEFT_ACTIVE; LEFT_COUNT_UP; step_motor5.step_to(0);SELECT_MOTOR(5,STOP); RIGHT_DEACTIVE; RIGHT_CLEAR;}break;}}}////#define MOTOR_TEST----------------------------------------------------------//void setup(){step_motor0.attach(2,0,3,1); step_motor1.attach(2,0,3,1); step_motor2.attach(6,4,7,5); step_motor3.attach(2,0,3,1);step_motor4.attach(2,0,3,1); step_motor5.attach(6,4,7,5); step_motor6.attach(6,4,7,5);Serial.begin(9600);while(0){ Serial.println(SW_STATUS(6)); }#ifdef MOTOR_TEST //----------------------------------------------------------SW_init();int i=10;Serial.setTimeout(10);while(1){Serial.println("Wating");if(Serial.available()){if(Serial.read()=='s'){Serial.println("Start"); delay(1000);while(1){if(Serial.available())i=Serial.parseInt();if ( 1<=i and i<= 7){ if(SW_STATUS( i -1))break; SELECT_MOTOR( i -1,INCREASE); }else if(-7<=i and i<=-1){ if(SW_STATUS(abs(i)-1))break; SELECT_MOTOR(abs(i)-1,DECREASE); }else { for(uint8_t n=0; n<7; n++)SELECT_MOTOR(n,STOP); }delay(1);}Serial.println("Done");}}}while(1);#endif //----------------------------------------------------------#ifndef MOTOR_TEST //----------------------------------------------------------SW_init();Serial.println("Stepper motor init start");for(uint8_t i=0; i<7; i++)SELECT_MOTOR(i,INCREASE);for(uint8_t i=0; i<7; i++)SELECT_MOTOR(i,STOP);delay(1000);Serial.println("Stepper motor init done"); Serial.println("Left Stepper motor go to home");while(1){for(uint8_t i=0; i<=2; i++){if(!SW_STATUS(i)&&(flag[i]==0)){ SELECT_MOTOR(i,DECREASE); } //DEelse { flag[i]=1; SELECT_MOTOR(i,STOP); }}delayMicroseconds(800); //800if((flag[0]*flag[1]*flag[2])!=0)break;}Serial.println("Left Stepper motor stop"); Serial.println("Right Stepper motor go to home");while(1){for(uint8_t i=4; i<=6; i++){if(!SW_STATUS(i)&&(flag[i]==0)){ SELECT_MOTOR(i,DECREASE); }else { flag[i]=1; SELECT_MOTOR(i,STOP); }}delayMicroseconds(800);if((flag[4]*flag[5]*flag[6])!=0)break;}Serial.println("Right Stepper motor stop"); delay(1); Serial.println("All Stepper motor steps clear");step_motor0.step_to(0); step_motor1.step_to(0); step_motor2.step_to(0); step_motor3.step_to(0);step_motor4.step_to(0); step_motor5.step_to(0); step_motor6.step_to(0);Serial.println("STEP[0]=0"); LEFT_COUNT_UP; delay(500);#endif //----------------------------------------------------------Serial.println("Left Timer Counter active"); LEFT_ACTIVE;Serial.println("Right Timer Counter deactive"); RIGHT_DEACTIVE;GOTO_HOME_DEACTIVE; interrupt_init(0b10);sei();};//void loop(){if(Flag4){delay(1000);Serial.println("*************Homing");for(uint8_t i=0; i<7; i++)flag[i]=0;LEFT_CLEAR;RIGHT_CLEAR;Serial.println("All Stepper motor go to home");while(1){for(uint8_t i=0; i<=6; i++){if(i==3)continue;if(!SW_STATUS(i)&&(flag[i]==0)){ SELECT_MOTOR(i,DECREASE); }else { flag[i]=1; SELECT_MOTOR(i,STOP); }}delay(1);if((flag[0]*flag[1]*flag[2])!=0)break;}Serial.println("Left Stepper motor stop"); Serial.println("Right Stepper motor go to home");/*while(1){for(uint8_t i=4; i<=6; i++){if(!SW_STATUS(i)&&(flag[i]==0)){ SELECT_MOTOR(i,DECREASE); }else { flag[i]=1; SELECT_MOTOR(i,STOP); }}delay(1);if((flag[4]*flag[5]*flag[6])!=0)break;}*/Serial.println("Right Stepper motor stop");step_motor0.step_to(0); step_motor1.step_to(0); step_motor2.step_to(0); step_motor3.step_to(0);step_motor4.step_to(0); step_motor5.step_to(0); step_motor6.step_to(0);LEFT_COUNT_UP; LEFT_DEACTIVE; RIGHT_DEACTIVE; //STEP[0]=0;TIMSK1|=(1<<OCIE1A);GOTO_HOME_DEACTIVE;Serial.println("*************Done");}}
소스를 분석하려면 실제로 동작시켜봐야지 이해가 가능합니다.
현장에서 분석해서 이해 한 후에 수정을 해준다는 것은 어려울 것 같습니다.
댓글 2
조회수 5,892오토의반란님의 댓글
오토의반란 작성일수정이 아닌 새로 짜야한다면 비용은 어느정도 예상을 해야하는지요?
작업 기간이 짧은 경우도 있고, 긴 경우도 있습니다.
심각한 경우는 사용자가 계속해서 수정을 원하기도 하므로 몇일이 연장되거나 수 개월씩 연장되는 경우도 있습니다.
따라서 구체적인 작업 내용 없이는 개발비용을 추정하지 못합니다.
