질문게시판 > 마이크로웨이브 모션감지 센서
TODAY260 TOTAL502,709
BASIC4MCU | 질문게시판 | 마이크로웨이브 모션감지 센서
작성자 야채왕 작성일2019-05-13 22:13 조회27회 댓글0건
마이크로웨이브 모션감지 센서인데 이게 주변 물체의 가속도가 클수록 큰 값이 나오거든요 그래서 일정 값이 상 나올때
led불이 켜지는 방식으로 만들어 보고싶어서 코딩좀 부탁드립니다. 일정값의 세팅은 55로 부탁드립니다.
#include <MsTimer2.h>           //Timer interrupt function library
int pbIn = 0;                    // Define interrupt 0 that is digital pin 2
int ledOut = 13;                 // Define the indicator LED pin digital pin 13
int number=0;                    //Interrupt times
volatile int state = LOW;         // Defines the indicator LED state, the default is not bright
     pinMode(ledOut, OUTPUT);//
     attachInterrupt(pbIn, stateChange, FALLING); // Set the interrupt function, interrupt pin is digital pin D2, interrupt service function is stateChange (), when the D2 power change from high to low , the trigger interrupt.
     MsTimer2::set(1000, Handle); // Set the timer interrupt function, running once Handle() function per 1000ms
     MsTimer2::start();//Start timer interrupt function
Serial.println(number); // Printing the number of times of interruption, which is convenient for debugging.
    delay(1);
    if(state == HIGH)  //When a moving object is detected, the ledout is automatically closed after the light 2S, the next trigger can be carried out, and No need to reset. Convenient debugging.
        delay(2000);
        state = LOW;
        digitalWrite(ledOut, state);    //turn off led
void stateChange()  //Interrupt service function
  number++;  //Interrupted once, the number + 1
void Handle()   //Timer service function
    if(number>1)  //If in the set of the interrupt time the number more than 1 times, then means have detect moving objects,This value can be adjusted according to the actual situation, which is equivalent to adjust the threshold of detection speed of moving objects.
                   state = HIGH;
                   digitalWrite(ledOut, state);    //light led
                   number=0;   //Cleare the number, so that it does not affect the next trigger
              number=0;   //If in the setting of the interrupt time, the number of the interrupt is not reached the threshold value, it is not detected the moving objects, Cleare the number.
조회수 27
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 316
공지 사이트 이용 안내댓글[7] master 17-10-29 6389
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 2480
질문 무게감지센서+동작감지센서를 사용하려 합니다 새글 아두이노ㅊㅂ 03:14 4
질문 더 이상 늘릴수가 없어요 이미지새글첨부파일 지니아삐 02:10 6
질문 블루투스 모듈 두개 통신 오류 도와주세용댓글[3] 이미지새글 조심해조 19-05-21 15
질문 ATMEGA328P 질문 새글 햇반은3분 19-05-21 9
질문 가스센서를이용한 모터가 두바퀴 이상 돌아가질 않습니다댓글[2] 이미지새글첨부파일 지따따 19-05-21 16
질문 여러개의 아두이노 ADC 데이터를 PC로 전송하는 방법 문의댓글[1] 새글 용냄 19-05-21 11
질문 아두이노 MQ-7과 블루투스 통신 및 앱 인벤터 이용 새글 아쿠아맨 19-05-21 10
답변 답변글 답변 : 아두이노 MQ-7과 블루투스 통신 및 앱 인벤터 이용 새글 master 19-05-21 12
질문 아두이노 코딩 새글 대구간 19-05-20 20
답변 답변글 답변 : 아두이노 코딩 새글 master 19-05-21 9
질문 아두이노 블루투스 통신에서 데이터를 읽어오는 속도 질문댓글[1] 새글 11223344 19-05-20 14
질문 마이크로웨이브 질문합니다~댓글[1] 새글 야채왕 19-05-20 11
질문 초음파센서로 측정 시간 값 저장댓글[1] 뜧횽닝 19-05-19 16
질문 자동출석프로그램 (Arduino ide) 이미지첨부파일 1651561asdg 19-05-19 16
질문 압력센서댓글[1] 이미지첨부파일 빙빙 19-05-19 22
질문 라즈베리파이와 3x4 matrix keypad 연결을 하려고 합니다댓글[1] 테오데디 19-05-19 15
질문 아두이노 신호등 및 추가센서 코딩 질문드립니다.댓글[1] KKID 19-05-18 24
질문 아두이노 연주중에 쉼표구현하기댓글[1] 기벡장인 19-05-18 26
질문 압력센서 4개 출력댓글[1] 이미지첨부파일 빙빙 19-05-18 21
질문 AVR studio의 코딩을 codevision에서 실행하고 싶습니다 그리고 AVR studio에서 코드가 … Chan2 19-05-18 14
답변 답변글 답변 : AVR studio의 코딩을 codevision에서 실행하고 싶습니다 그리고 AVR studio에서… master 19-05-18 18
질문 블루투스와 시리얼 모니터댓글[1] 상오 19-05-18 19
질문 Cleanflight블루투스 모듈 HC06, HM10 도와주세요ㅠㅠ 고랩 19-05-17 15
질문 avr studio 4 전자시계 프로그램질문! 첨부파일 거동쓰 19-05-17 22
질문 마스터님 LCD구동 질문드립니다.댓글[1] nicefo 19-05-17 19
질문 가변저항으로 LCD에 남은 시간을 조정하고 시간이 다되면 서브모터를 닫으려고 합니다. 교황제 19-05-17 12
질문 아두이노 가스센서를 통해, 스텝모터를 작동시키려 합니다. 푸링이 19-05-17 20
