질문게시판 > 아두이노 전자 금고 컴파일 오류 질문
TODAY235 TOTAL2,691,612
BASIC4MCU | 질문게시판 | 아두이노 전자 금고 컴파일 오류 질문
작성자 master 작성일2019-05-16 21:26 조회6,363회 댓글0건
#include<LiquidCrystal.h>
#include<EEPROM.h>
LiquidCrystal_I2C lcd(0x3F,16,2);
char password[4];
char initial_password[4],new_password[4];
int i=0;
int relay_pin = 10;
char key_pressed=0;
const byte rows = 4;
const byte columns = 4;
char hexaKeys[rows][columns] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte row_pins[rows] = {A0,A1,A2,A3};
byte column_pins[columns] = {5,4,3,2};
Keypad keypad_key = Keypad( makeKeymap(hexaKeys), row_pins, column_pins, rows, columns);
  pinMode(relay_pin, OUTPUT);
  liquid_crystal_display.begin(16,2);
  liquid_crystal_display.print(" DIYhacking.com");
  liquid_crystal_display.setCursor(0,1);
  liquid_crystal_display.print("Electronic Lock ");
  delay(2000);
  liquid_crystal_display.clear();
  liquid_crystal_display.print("Enter Password");
  initialpassword();
  digitalWrite(relay_pin, HIGH);
  key_pressed = keypad_key.getKey();
  if(key_pressed=='#')
    change();
  if (key_pressed)
    password[i++]=key_pressed;
    liquid_crystal_display.print(key_pressed);
  if(i==4)
    delay(200);
    for(int j=0;j<4;j++)
      initial_password[j]=EEPROM.read(j);
    if(!(strncmp(password, initial_password,4)))
      liquid_crystal_display.print("Pass Accepted");
      digitalWrite(relay_pin, LOW);
      delay(2000);
      liquid_crystal_display.print("Pres # to change");
      delay(2000);
      liquid_crystal_display.print("Enter Password:");
      i=0;
      liquid_crystal_display.print("Wrong Password");
      liquid_crystal_display.print("Pres # to Change");
      delay(2000);
      i=0;
void change()
  int j=0;
  liquid_crystal_display.print("Current Password");
  while(j<4)
    char key=keypad_key.getKey();
    if(key)
      new_password[j++]=key;
      liquid_crystal_display.print(key);
    key=0;
  delay(500);
  if((strncmp(new_password, initial_password, 4)))
    liquid_crystal_display.print("Try Again");
    j=0;
    liquid_crystal_display.print("New Password:");
    while(j<4)
      if(key)
        initial_password[j]=key;
        EEPROM.write(j,key);
        j++;
    liquid_crystal_display.print("Pass Changed");
  key_pressed=0;
void initialpassword(){
    EEPROM.write(j, j+49);
여기까지 짰는데 오류가 밑에 처럼 떴습니다. 해결책 좀 알려주세요.
C:\Users\zobab\Documents\Arduino\sketch_oct31a\sketch_oct31a.ino: In function 'void setup()':
sketch_oct31a:50:3: error: 'liquid_crystal_I2C' was not declared in this scope
   liquid_crystal_I2C display.begin(16,2);
sketch_oct31a:52:22: error: expected ';' before 'display'
   liquid_crystal_I2C display.print(" DIYhacking.com");
sketch_oct31a:54:22: error: expected ';' before 'display'
   liquid_crystal_I2C display.setCursor(0,1);
sketch_oct31a:56:22: error: expected ';' before 'display'
   liquid_crystal_I2C display.print("Electronic Lock ");
sketch_oct31a:60:22: error: expected ';' before 'display'
   liquid_crystal_I2C display.clear();
sketch_oct31a:62:22: error: expected ';' before 'display'
   liquid_crystal_I2C display.print("Enter Password");
sketch_oct31a:64:22: error: expected ';' before 'display'
C:\Users\zobab\Documents\Arduino\sketch_oct31a\sketch_oct31a.ino: In function 'void loop()':
sketch_oct31a:91:5: error: 'liquid_crystal_I2C' was not declared in this scope
     liquid_crystal_I2C display.print(key_pressed);
sketch_oct31a:109:7: error: 'liquid_crystal_I2C' was not declared in this scope
sketch_oct31a:111:26: error: expected ';' before 'display'
       liquid_crystal_I2C display.print("Pass Accepted");
sketch_oct31a:117:26: error: expected ';' before 'display'
sketch_oct31a:119:26: error: expected ';' before 'display'
       liquid_crystal_I2C display.print("Pres # to change");
sketch_oct31a:123:26: error: expected ';' before 'display'
sketch_oct31a:125:26: error: expected ';' before 'display'
       liquid_crystal_I2C display.print("Enter Password:");
sketch_oct31a:127:26: error: expected ';' before 'display'
sketch_oct31a:145:7: error: 'liquid_crystal_I2C' was not declared in this scope
sketch_oct31a:147:26: error: expected ';' before 'display'
       liquid_crystal_I2C display.print("Wrong Password");
sketch_oct31a:149:26: error: expected ';' before 'display'
sketch_oct31a:151:26: error: expected ';' before 'display'
       liquid_crystal_I2C display.print("Pres # to Change");
sketch_oct31a:155:26: error: expected ';' before 'display'
sketch_oct31a:157:26: error: expected ';' before 'display'
sketch_oct31a:159:26: error: expected ';' before 'display'
C:\Users\zobab\Documents\Arduino\sketch_oct31a\sketch_oct31a.ino: In function 'void change()':
sketch_oct31a:178:3: error: 'liquid_crystal_I2C' was not declared in this scope
   liquid_crystal_I2C; display.lear();
sketch_oct31a:178:23: error: 'display' was not declared in this scope
sketch_oct31a:196:26: error: expected ';' before 'display'
       liquid_crystal_I2C display.print(key);
sketch_oct31a:215:24: error: expected ';' before 'display'
sketch_oct31a:217:24: error: expected ';' before 'display'
sketch_oct31a:219:24: error: expected ';' before 'display'
sketch_oct31a:221:24: error: expected ';' before 'display'
     liquid_crystal_I2C display.print("Try Again");
sketch_oct31a:233:24: error: expected ';' before 'display'
sketch_oct31a:235:24: error: expected ';' before 'display'
     liquid_crystal_I2C display.print("New Password:");
sketch_oct31a:237:24: error: expected ';' before 'display'
sketch_oct31a:251:28: error: expected ';' before 'display'
sketch_oct31a:263:24: error: expected ';' before 'display'
     liquid_crystal_I2C display.print("Pass Changed");
sketch_oct31a:269:22: error: expected ';' before 'display'
sketch_oct31a:271:22: error: expected ';' before 'display'
sketch_oct31a:273:22: error: expected ';' before 'display'
exit status 1
// DateTime : 2018-11-15 오전 4:11:33
#include <Keypad.h>
#include <EEPROM.h>
char password[4];
int i=0;
int relay_pin=10;
char key_pressed=0;
const byte rows=4;
const byte columns=4;
char hexaKeys[rows][columns]={
  { '1','2','3','A'},
  { '4','5','6','B'},
  { '7','8','9','C'},
  { '*','0','#','D'}
byte row_pins[rows]={ A0,A1,A2,A3};
byte column_pins[columns]={ 5,4,3,2};
Keypad keypad_key=Keypad(makeKeymap(hexaKeys),row_pins,column_pins,rows,columns);
  pinMode(relay_pin,OUTPUT);
  lcd.begin(16,2); lcd.print(" DIYhacking.com");
  lcd.setCursor(0,1); lcd.print("Electronic Lock ");
  delay(2000);
  lcd.clear(); lcd.print("Enter Password");
  lcd.setCursor(0,1);
  initialpassword();
  digitalWrite(relay_pin,HIGH);
  key_pressed=keypad_key.getKey();
  if(key_pressed=='#')change();
  if(key_pressed){ password[i++]=key_pressedlcd.print(key_pressed); }
  if(i==4){
    delay(200);
    for(int j=0j<4j++)initial_password[j]=EEPROM.read(j);
    if(!(strncmp(password,initial_password,4))){
      digitalWrite(relay_pin,LOW);
      lcd.clear();        lcd.print("Pass Accepted");  delay(2000);
      lcd.setCursor(0,1); lcd.print("Pres#to change"); delay(2000);
      lcd.clear();        lcd.print("Enter Password: ");
      lcd.setCursor(0,1);
      i=0;
      lcd.clear();        lcd.print("Wrong Password");
      lcd.setCursor(0,1); lcd.print("Pres#to Change");
      delay(2000);
      lcd.setCursor(0,1);
      i=0;
void change(){
  int j=0;
  lcd.clear(); lcd.print("Current Password");
  lcd.setCursor(0,1);
  while(j<4){
    if(key){ new_password[j++]=keylcd.print(key); }
    key=0;
  delay(500);
  if((strncmp(new_password,initial_password,4))){
    lcd.setCursor(0,1); lcd.print("Try Again");
    j=0;
    lcd.clear(); lcd.print("New Password: ");
    lcd.setCursor(0,1);
    while(j<4){
      if(key){ initial_password[j]=keylcd.print(key); EEPROM.write(j,key); j++; }
    lcd.print("Pass Changed");
  lcd.setCursor(0,1);
  key_pressed=0;
  for(int j=0j<4j++)EEPROM.write(j,j+49);
조회수 6,363
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 19417
공지 사이트 이용 안내댓글[28] master 17-10-29 34131
질문 stm32f767을 이용해서 자이로가속도 센서의 값 받아오기 새글 rlchwjswk 23-06-03 7
질문 아두이노 모터제어 관련해서 질문드립니다!댓글[1] 이미지새글첨부파일 아두이노어렵잖아 23-06-03 21
질문 atmega128 디지털조도센서 코드오류댓글[1] 이미지새글 까미 23-06-02 25
질문 atmega128 디지털 조도 센서댓글[1] 새글 까미 23-06-02 25
질문 적외선리모콘으로 부저를제어 하는방법 질문입니다.댓글[4] 새글 Tell 23-06-02 18
질문 lora 무선 모듈에 관한 질문입니다.댓글[1] 로이스10 23-06-01 18
질문 적외선 송수신기 DC모터2개 제어 질문입니다.댓글[5] Tell 23-06-01 31
질문 스텝모터 제어 코드 질문댓글[4] pmh11 23-05-31 32
질문 초음파 센서를 이용한 인원 카운팅댓글[1] 초음파야 23-05-31 26
질문 모터 Hall 스위치 연결 문의댓글[1] 오후 23-05-31 21
질문 아두이노 lcd 문자 스크롤디스플레이 wnion 23-05-31 22
답변 답변글 답변 : 아두이노 lcd 문자 스크롤디스플레이댓글[1] master 23-05-31 28
질문 아두이노 타이머 인터럽트 미ㅏㄴㅇ 23-05-30 37
답변 답변글 답변 : 아두이노 타이머 인터럽트댓글[6] master 23-05-30 44
질문 THC-Soil Sensor with TTL 모듈 아두이노 센서값 받아오기댓글[1] ppiickle 23-05-30 30
질문 stm32 psd센서구동 질문댓글[2] 수포자 23-05-29 28
질문 앱인벤터 아두이노 보드 LCD 글씨 나타내기 질문댓글[7] 이미지 당찬병아리 23-05-29 41
질문 atmega128 led와 fan댓글[3] 이라 23-05-28 44
질문 stm32f767 스텝모터 속도 질문있습니다 123132 23-05-27 34
답변 답변글 답변 : stm32f767 스텝모터 속도 질문있습니다 master 23-05-28 30
질문 아트메가 128 코딩 오류 질문입니다.댓글[1] 태태킴 23-05-27 31
질문 스텝모터 제어하는 소스파일인데 질문있습니다. Bs드리프터 23-05-27 38
답변 답변글 답변 : 스텝모터 제어하는 소스파일인데 질문있습니다. master 23-05-27 35
질문 모터 컨트롤러와 웜기어 모터 연결 문의 드립니다댓글[1] 오후에 23-05-27 28
답변 답변글 답변 : 모터 컨트롤러와 웜기어 모터 연결 문의 드립니다댓글[1] 첨부파일 오후에 23-05-27 33
질문 아두이노 스텝모터 초음파 결합댓글[2] 결합기원 23-05-26 55
답변 답변글 답변 : 아두이노 스텝모터 초음파 결합 master 23-05-27 28
질문 piezo부저 연결 방법댓글[2] 이미지첨부파일 djwb 23-05-26 34
