질문게시판 > 마스터님 도와주세요!!라인트레이서 소스 질문입니다.
TODAY1,321 TOTAL2,176,629
BASIC4MCU | 질문게시판 | 마스터님 도와주세요!!라인트레이서 소스 질문입니다.
작성자 Song 작성일2019-05-22 14:50 조회3,766회 댓글1건
리모컨으로 누르고 있는 동안에 로봇이 전진하고 리모컨을 떼면 움직인 길이만큼 후진해서 처음 위치로 되돌아오는 프로그램을 만들고 있습니다.
아래 소스를 통해 앞으로 구동하는것은 만들었는데 떼는 순간 되돌아오게 하는 방법을 모르겠어서 질문합니다.
사용한 소스입니다.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity rf_robot is
Port ( rstb : in std_logic;
clk_4m : in std_logic;
rf_data : in std_logic_vector(2 downto 0);
mtl : out std_logic_vector(3 downto 0);
mtr : out std_logic_vector(3 downto 0));
end rf_robot;
architecture Behavioral of rf_robot is
signal forward : std_logic;
signal mtl_speed : std_logic_vector(1 downto 0);
signal mtr_speed : std_logic_vector(1 downto 0);
signal speed_l : integer range 0 to 250000;
signal speed_r : integer range 0 to 250000;
signal motor_lcnt : integer range 0 to 250000;
signal phase_lclk : std_logic;
signal motor_rcnt : integer range 0 to 250000;
signal phase_rclk : std_logic;
signal phase_lcnt : std_logic_vector(1 downto 0);
signal phase_lout : std_logic_vector(3 downto 0);
signal phase_rcnt : std_logic_vector(1 downto 0);
signal phase_rout : std_logic_vector(3 downto 0);
begin
process(rf_data)
begin
forward <= '1';
case rf_data is
when "100" =>
mtl_speed <= "11";
mtr_speed <= "11";
when "001" =>
mtl_speed <= "11";
mtr_speed <= "11";
forward <= '0';
when others =>
mtl_speed <= "00";
mtr_speed <= "00";
end case;
end process;
process(mtl_speed)
begin
case mtl_speed is
when "00" =>
speed_l <= 1;
when "01" =>
speed_l <= 124999;
when "10" =>
speed_l <= 62500;
when "11" =>
speed_l <= 50000;
when others =>
speed_l <= 50000;
end case;
end process;
process(mtr_speed)
begin
case mtr_speed is
when "00" =>
speed_r <= 1;
when "01" =>
speed_r <= 124999;
when "10" =>
speed_r <= 62500;
when "11" =>
speed_r <= 50000;
when others =>
speed_r <= 50000;
end case;
end process;
process(rstb, speed_l, clk_4m, motor_lcnt)
begin
if rstb = '0' or speed_l = 0 then
motor_lcnt <= 0;
phase_lclk <= '0';
elsif rising_edge(clk_4m) then
if motor_lcnt >= speed_l then
motor_lcnt <= 0;
phase_lclk <= not phase_lclk;
motor_lcnt <= motor_lcnt + 1;
end if;
end if;
end process;
process(rstb, speed_r, clk_4m, motor_rcnt)
begin
if rstb = '0' or speed_r = 0 then
motor_rcnt <= 0;
phase_rclk <= '0';
if motor_rcnt >= speed_r then
motor_rcnt <= 0;
phase_rclk <= not phase_rclk;
motor_rcnt <= motor_rcnt + 1;
end if;
end if;
end process;
process(rstb, phase_lclk, phase_lcnt)
begin
if rstb = '0' then
phase_lcnt <= (others => '0');
elsif rising_edge(phase_lclk) then
phase_lcnt <= phase_lcnt + 1;
end if;
end process;
process(rstb, phase_lcnt)
begin
if rstb = '0' then
phase_lout <= (others => '0');
case phase_lcnt is
when "00" => phase_lout <= "1000";
when "01" => phase_lout <= "0100";
when "10" => phase_lout <= "0010";
when "11" => phase_lout <= "0001";
when others => phase_lout <= "0000";
end case;
end if;
end process;
process(rstb, phase_rclk, phase_rcnt)
begin
if rstb = '0' then
phase_rcnt <= (others => '0');
elsif rising_edge(phase_rclk) then
phase_rcnt <= phase_rcnt + 1;
end if;
end process;
process(rstb, phase_rcnt)
begin
if rstb = '0' then
phase_rout <= (others => '0');
case phase_rcnt is
when "00" => phase_rout <= "1000";
when "01" => phase_rout <= "0100";
when "10" => phase_rout <= "0010";
when "11" => phase_rout <= "0001";
when others => phase_rout <= "0000";
end case;
end if;
end process;
mtl(0) <= phase_lout(0) when forward = '1' else phase_lout(3);
mtl(1) <= phase_lout(1) when forward = '1' else phase_lout(2);
mtl(2) <= phase_lout(2) when forward = '1' else phase_lout(1);
mtl(3) <= phase_lout(3) when forward = '1' else phase_lout(0);
mtr(0) <= phase_rout(3) when forward = '1' else phase_rout(0);
mtr(1) <= phase_rout(2) when forward = '1' else phase_rout(1);
mtr(2) <= phase_rout(1) when forward = '1' else phase_rout(2);
mtr(3) <= phase_rout(0) when forward = '1' else phase_rout(3);
end Behavioral;
조회수 3,766
좌우측 펄스 수를 카운트 해서 저장 해두었다가
떼면 0이 될 때까지 역회전 시키도록 만들어보세요
답변 답변글 답변 : 아두이노 서보모터 무한회전 문제 해결을 어떻게 해야할까요댓글[5] 새글 master 22-05-27 39
질문 모터 엔코더 제어 질문드립니다. 새글 oreoreo 22-05-27 24
답변 답변글 답변 : 아두이노 속도측정, 속도를 LCD에 표시, 가까워지면 부저 새글 master 22-05-27 22
질문 블루투스 관련 코드 도와주세요 새글 scape 22-05-27 22
답변 답변글 답변 : 블루투스 관련 코드 도와주세요 새글 master 22-05-27 21
질문 ATmega128 1602A LCD 출력 질문입니다.댓글[2] 새글 444222a 22-05-27 45
질문 적외선 거리 센서로 블루투스 알람 설정 코딩...댓글[1] ededed 22-05-26 30
질문 atmega128 키패드 입력 오류에 대하여 질문 있습니다.댓글[2] 마프하나 22-05-26 65
질문 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 아트메가넘어려워 22-05-26 38
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. aasdw 22-05-26 75
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] master 22-05-26 75
