BASIC4MCU | 질문게시판 | Atmega128a 디지털시계 관련해서 질문드립니다
작성자 아트메가잘하고싶다 작성일2019-05-22 19:53 조회3,556회 댓글0건본문
폰트 0~9랑 세미콜론을 직접 코딩했는데..
문제는 LCD파일에 폰트 출력을 하는 함수를 헤더파일에서 찾고 연구를 하였지만
도저히 방법을 모르겠어서 질문드립니다...
void TFT_binary(U16 number, U08 digit) /* display 8 or 16 bit binary number */
unsigned char i, shift;if((digit == 0) || (digit > 16)) return;
shift = digit - 1;
for(i = 0; i < digit; i++ )
{ TFT_English(((number >> shift) & 0x01) + '0');
shift--;
}void TFT_unsigned_decimal(U32 number, U08 zerofill, U08 digit) /* display unsigned decimal number */
unsigned char zero_flag, character;
unsigned long div;if((digit == 0) || (digit > 9)) return;
div = 1;
while(--digit) div *= 10;zero_flag = zerofill;
while(div > 0) // display number
{ character = number / div;
if((character == 0) && (zero_flag == 0) && (div != 1))
TFT_English(character + ' ');
{ zero_flag = 1;
TFT_English(character + '0');
number %= div;
div /= 10;
}void TFT_signed_decimal(S32 number, U08 zerofill, U08 digit) /* display signed decimal number */
if(number >= 0) // display sign
TFT_English('+');
{ TFT_English('-');
number = -number;
}div = 1;
{ zero_flag = 1;
number %= div;
div /= 10;
}void TFT_hexadecimal(U32 number, U08 digit) /* display hexadecimal number */
unsigned char i, character;if((digit == 0) || (digit > 8)) return;
for(i = digit; i > 0; i--)
{ character = (number >> 4*(i-1)) & 0x0F;
if(character < 10) TFT_English(character + '0');
else TFT_English(character - 10 + 'A');
}void TFT_0x_hexadecimal(U32 number, U08 digit) /* display hexadecimal number with 0x */
TFT_English('0');
TFT_English('x');for(i = digit; i > 0; i--)
}void TFT_unsigned_float(float number, U08 integral, U08 fractional) /* display unsigned floating-point number */
unsigned char zero_flag, digit, character; // integral = digits of integral part
unsigned long div, integer; // fractional = digits of fractional partdigit = integral + fractional;
if((integral == 0) || (fractional == 0) || (digit > 9)) return;div = 1;
while(--digit) div *= 10;while(fractional--) number *= 10.;
integer = (U32)(number + 0.5);zero_flag = 0;
digit = 1;
{ character = integer / div;
if((character == 0) && (zero_flag == 0) && (digit != integral))
{ zero_flag = 1;
integer %= div;
div /= 10;if(digit == integral)
TFT_English('.');
digit++;
}void TFT_signed_float(float number, U08 integral, U08 fractional) /* display signed floating-point number */
unsigned long div, integer;digit = integral + fractional;
if((integral == 0) || (fractional == 0) || (digit > 9)) return;if(number >= 0) // display sign
TFT_English('+');
{ TFT_English('-');
number = -number;
}div = 1;
digit = 1;
{ zero_flag = 1;
integer %= div;
TFT_English('.');
digit++;
위의 헤더파일에 관련하여 제가 짠 폰트 코딩은
prog_uchar S_font_large[128][210] ={
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00, //0
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //1
0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00, //2
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFE,0xFE,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0E,0x0F,0x0F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,
0X00,0X00,0X00,0X00,0X00,0X00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0x00,0x00,0x00,0x00,0x00,0x00
0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00, //3
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00, //4
0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x00, //5
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0xFC,0xFC,0xFC,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //6
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0xFC,0xFC,0xFC,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00
0x00,0x00,0x00,0x00,0x00,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00, //7
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00, //8
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0x1C,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00, //9
prog_uchar X_font_large[128][168] =
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //:
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
};입니다..
조회수 3,556등록된 댓글이 없습니다.
