질문게시판 > 답변 : 마스터님께(창문소스코드 의문점)
TODAY1,293 TOTAL2,176,601
BASIC4MCU | 질문게시판 | 답변 : 마스터님께(창문소스코드 의문점)
작성자 master 작성일2019-05-23 17:51 조회3,323회 댓글0건
// DateTime : 2019-05-23 오후 5:56:49
#include <Stepper.h>
const int stepsPerRevolution=200//회전수 200/한바퀴
Stepper myStepper(stepsPerRevolution,8,9,10,11);
const int gasPin=A0;    // 가스
const int TMP36_pin=A1// 온도
int ENA=2,ENB=5;
int ondo1=30,ondo2=28,gas1=200,gas2=150;
boolean window=false//false->닫혀있는상태 //true->열려있는상태
  pinMode(ENA,OUTPUT); digitalWrite(ENA,HIGH);
  pinMode(ENB,OUTPUT); digitalWrite(ENB,HIGH);
  myStepper.setSpeed(10);
  int    gas_val=analogRead(gasPin);
  int    sensorRain=analogRead(TMP36_pin);
  float  mVoltage=sensorRain*5000.0/1024.0;
  float  temperatureC=(mVoltage-500)/10.0;
  Serial.print("Now: ");         Serial.print(temperatureC);         Serial.println(" C"); Serial.println();
  Serial.print("current gas: "); Serial.println(analogRead(gasPin)); Serial.println();
  int Rain=digitalRead(2);
  Serial.print("Rain: ");        Serial.println(Rain);
  Serial.print("Window: ");
  if(window==false)Serial.println("Close");
  else             Serial.println("Open");
  Serial.println("==============================================="); Serial.println();
  if(window==false&&Rain==1){ //창문이 닫혀있고 비가 안오는 상태
    if     (temperatureC<=ondo2 && gas_val>=gas1){ sensor_open(); }
    else if(temperatureC>=ondo1 && gas_val>=gas1){ sensor_open(); }
    else if(temperatureC<=ondo2 && gas_val<=gas2){                } //동작안함
    else if(temperatureC>=ondo1 && gas_val<=gas2){ sensor_open(); }
  else if(window==false&&Rain==0){ //창문이 닫혀있고 비가 오는 상태
    else if(temperatureC>=ondo1 && gas_val<=gas2){                } //동작안함
    else                                         {                } //동작안함
  else if(window==true&&Rain==1){ //창문이열려있고 비가 안오는 상태
    if     (temperatureC<=ondo2 && gas_val>=gas1){                 } //동작안함
    else if(temperatureC>=ondo1 && gas_val>=gas1){                 } //동작안함
    else if(temperatureC<=ondo2 && gas_val<=gas2){ sensor_close(); }
  else if(window==true&&Rain==0){ //창문이열려있고 비가 오는 상태
    else if(temperatureC>=ondo1 && gas_val<=gas2){ sensor_close(); }
    else                                         { sensor_close(); }
  delay(5000);
void sensor_open(){
  window=true;
  Serial.println("open");          myStepper.step(stepsPerRevolution); Serial.println("stop");
  Serial.print("Window Status: "); Serial.println(window); Serial.println();
void sensor_close(){
  window=false;
  Serial.println("Close");         myStepper.step(-stepsPerRevolution);
이 코드입니다.
그런데 온도가 자꾸 35~40도 사이로 뜨는 것도 있으며 , 넘어가도 코드가 open으로 작동을 하지 않습니다.
온도 체크는 가장 나중에 체크합니다.
창문 과 비를 먼저 체크하고
그 조건에 따라서 온도를 체크합니다.
아래 링크를 작동해보려하는데
int ENA=8;
int ENB=5;
int enablePin = 11;
int in1Pin = 10;
int in2Pin = 9;
여기서 enblePin는 무엇인지 잘 모르겠고 in1Pin in2Pin은 이미 89에 연결되있는 상태아닌가요?
질문 소스와는 핀이 다르군요?
각각의 핀이 어디에 연결되어 있는지 체크해보세요
조회수 3,323
답변 답변글 답변 : 아두이노 서보모터 무한회전 문제 해결을 어떻게 해야할까요댓글[5] 새글 master 22-05-27 39
질문 모터 엔코더 제어 질문드립니다. 새글 oreoreo 22-05-27 24
답변 답변글 답변 : 아두이노 속도측정, 속도를 LCD에 표시, 가까워지면 부저 새글 master 22-05-27 22
질문 ATmega128 1602A LCD 출력 질문입니다.댓글[2] 새글 444222a 22-05-27 45
질문 적외선 거리 센서로 블루투스 알람 설정 코딩...댓글[1] ededed 22-05-26 30
질문 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 아트메가넘어려워 22-05-26 38
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. aasdw 22-05-26 74
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] master 22-05-26 74
