질문게시판 > 아두이노 블루투스 전송
TODAY919 TOTAL2,585,091
BASIC4MCU | 질문게시판 | 아두이노 블루투스 전송
작성자 으아아악 작성일2019-05-27 02:33 조회9,509회 댓글2건
#define PROCESSING_VISUALIZER 1
#define SERIAL_PLOTTER  2
//  Variables
int pulsePin = 0;                 // Pulse Sensor purple wire connected to analog pin 0
// Volatile Variables, used in the interrupt service routine!
volatile int BPM;                   // int that holds raw Analog in 0. updated every 2mS
volatile int Signal;                // holds the incoming raw data
volatile int IBI = 600;             // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false;     // "True" when User's live heartbeat is detected. "False" when not a "live beat".
volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
SoftwareSerial BTSerial(2, 3);
// SET THE SERIAL OUTPUT TYPE TO YOUR NEEDS
// PROCESSING_VISUALIZER works with Pulse Sensor Processing Visualizer
//      https://github.com/WorldFamousElectronics/PulseSensor_Amped_Processing_Visualizer
// SERIAL_PLOTTER outputs sensor data for viewing with the Arduino Serial Plotter
//      run the Serial Plotter at 115200 baud: Tools/Serial Plotter or Command+L
static int outputType = SERIAL_PLOTTER;
  BTSerial.begin(9600);
  Serial.begin(9600);             // we agree to talk fast!
  interruptSetup();                 // sets up to read Pulse Sensor signal every 2mS
   // IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
   // UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
//   analogReference(EXTERNAL);
//  Where the Magic Happens
    serialOutput() ;
    BTSerial.print(BPM );
  if (QS == true){     // A Heartbeat Was Found
                       // BPM and IBI have been Determined
                       // Quantified Self "QS" true when arduino finds a heartbeat
                                // Set 'fadeRate' Variable to 255 to fade LED with pulse
        serialOutputWhenBeatHappens();   // A Beat Happened, Output that to serial.
        QS = false;                      // reset the Quantified Self flag for next time
위처럼 심박 측정 코드를 작성하고 앱인벤터로 앱을 만들어 실행시켜 보았는데 측정된 심박수가 일정하게 한개 씩 나오다가(ex: BPM:90) 갑자기 두개가 겹쳐서 나오는 현상이 발생합니다.(ex: BPM:9091) 원인이 무엇인지 알 수 있을까요?
조회수 9,509
당연히 소스를 분석하셔야하고
소스를 분석하면 오동작 원인을 파악할 수 있습니다.
원인을 잘 찾아보세요
으아아악님의 댓글
으아아악 댓글의 댓글 작성일
앱인벤터 코딩 상의 문제일까요? 위의 소스 코드는 질문게시판을 통해 답변해주신 분이 가르쳐 주신 코드라서 제가 아무리 봐도 원인이 위의 코드에는 없는 것 같다는 생각이 들어서요.
공지 사이트 이용 안내댓글[28] master 17-10-29 33560
질문 아두이노 코딩 에러 질문댓글[1] 이미지새글첨부파일 박무농 23-03-25 27
질문 아두이노를 이용한 타이머, 태양전지 제어댓글[2] 새글 박무농 23-03-25 29
질문 초음파센서를 이용한 모터제어 질문있습니다.댓글[3] 이미지첨부파일 뉴비에오 23-03-24 39
질문 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 그렇찌 23-03-22 33
답변 답변글 답변 : 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 master 23-03-23 22
질문 HC06을 마스터로 설정하면 HC06끼리만 통신되나요?댓글[4] 비차 23-03-21 36
질문 아두이노 테트리스 게임댓글[1] 첨부파일 지욱애 23-03-02 160
질문 아두이노우노 블루투스 2개 연결댓글[1] dsfadfs 23-02-28 117
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 81
질문 아두이노 블루투스 관련 질문입니다. 생물공학도 23-02-21 107
답변 답변글 답변 : 아두이노 블루투스 관련 질문입니다. master 23-02-21 108
질문 자율주행 로봇을 만드는데 질문있습니다.댓글[2] 뉴비에오 23-02-18 176
