BASIC4MCU | 질문게시판 | 아두이노 앱인벤터
작성자 으아아악 작성일2019-05-29 01:21 조회9,207회 댓글4건본문
#define PROCESSING_VISUALIZER 1
#define SERIAL_PLOTTER 2
// Variables
int pulsePin = 0; // Pulse Sensor purple wire connected to analog pin 0
// Volatile Variables, used in the interrupt service routine!
volatile int BPM; // int that holds raw Analog in 0. updated every 2mS
volatile int Signal; // holds the incoming raw data
volatile int IBI = 600; // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false; // "True" when User's live heartbeat is detected. "False" when not a "live beat".
volatile boolean QS = false; // becomes true when Arduoino finds a beat.
SoftwareSerial BTSerial(2, 3);
// SET THE SERIAL OUTPUT TYPE TO YOUR NEEDS
// PROCESSING_VISUALIZER works with Pulse Sensor Processing Visualizer
// https://github.com/WorldFamousElectronics/PulseSensor_Amped_Processing_Visualizer
// SERIAL_PLOTTER outputs sensor data for viewing with the Arduino Serial Plotter
// run the Serial Plotter at 115200 baud: Tools/Serial Plotter or Command+L
static int outputType = SERIAL_PLOTTER;
Serial.begin(9600); // we agree to talk fast!
BTSerial.begin(9600);
interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
// IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
// UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
// analogReference(EXTERNAL);
// Where the Magic Happens
serialOutput() ;
BTWerial.print(BPM);
if (QS == true){ // A Heartbeat Was Found
// BPM and IBI have been Determined
// Quantified Self "QS" true when arduino finds a heartbeat
// Set 'fadeRate' Variable to 255 to fade LED with pulse
serialOutputWhenBeatHappens(); // A Beat Happened, Output that to serial.
QS = false; // reset the Quantified Self flag for next time
현재 심박센서를 사용하여 BPM을 구해 앱인벤터로 만든 앱에 디스플레이 하고있습니다.
앱인벤터에서 clock time interval을 1000으로 설정하고 위의 소스코드에서도 delay(1000)을 써서 시간을 맞춰줬는데
앱에서 BPM이 디스플레이 될 때 하나씩 나오다가(예: 90BPM) 가끔 두 값이 겹쳐서 나올 때가 있는데(예: 9091BPM) 원인이 무엇일까요?
댓글 4
조회수 9,207master님의 댓글
전체 소스가 아니죠?
올리지 않은 부분을 제가 어떻게 알 수 있을까요?
serialOutput() ;
if (QS == true){ QS = false;
루프문에서는 모두 3라인의 시리얼 출력 코드가 있습니다.
이 중에서 간헐적으로 동작하는 것은 if(QS==true) 문입니다.
QS가 true 될 때에 출력이 달라지는 것이죠
조금만 집중해서 분석하면 원인을 알 수 있습니다.
으아아악님의 댓글
으아아악
SoftwareSerial mySerial(2,3); //블루투스의 Tx, Rx핀을 2번 3번핀으로 설정
int pulsePin=A0;
int initCounter=0,initBPM=0;
volatile int BPM;
volatile int IBI=600;
volatile bool Pulse=false;
volatile bool QS=false;
static int outputType=SERIAL_PLOTTER;
char str[100];
pinMode(3,OUTPUT);
mySerial.begin(9600);
interruptSetup();
serialOutput();
if(QS==true){serialOutputWhenBeatHappens(); QS=false; }
void serialOutput(){
switch(outputType){
case PROCESSING_VISUALIZER: sprintf(str,"Signal: %d\r\n",Signal); Serial.print(str); break;
case SERIAL_PLOTTER: sprintf(str,"BPM: %d,IBI: %d,Signal: %d\r\n",BPM,IBI,Signal); Serial.print(str); mySerial.print(BPM); break;
void serialOutputWhenBeatHappens(){
switch(outputType){
case PROCESSING_VISUALIZER: sprintf(str,"BPM: %d,IBI: %d\r\n",BPM,IBI); Serial.print(str); mySerial.print(BPM); break;
volatile int rate[10];
volatile unsigned long sampleCounter=0;
volatile unsigned long lastBeatTime=0;
volatile int P=512;
volatile int T=512;
volatile int thresh=530;
volatile int amp=0;
volatile boolean firstBeat=true;
volatile boolean secondBeat=false;
void interruptSetup(){
TCCR2A=0x02; TCCR2B=0x06; OCR2A=0X7C; TIMSK2=0x02; sei();
ISR(TIMER2_COMPA_vect){
cli();
Signal=analogRead(pulsePin);
sampleCounter+=2;
int N=sampleCounter-lastBeatTime;
if(Signal<thresh&&N>(IBI/5)*3){ if(Signal<T)T=Signal; }
if(Signal>thresh&&Signal>P){ P=Signal; }
if(N>250){
if((Signal>thresh)&&(Pulse==false)&&(N>(IBI/5)*3)){
Pulse=true;
IBI=sampleCounter-lastBeatTime;
lastBeatTime=sampleCounter;
if(secondBeat){ secondBeat=false; for(int i=0; i<=9; i++)rate[i]=IBI; }
if(firstBeat){ firstBeat=false; secondBeat=true; sei(); return; }
word runningTotal=0;
for(int i=0; i<=8; i++){ rate[i]=rate[i+1]; runningTotal+=rate[i]; }
rate[9]=IBI;
runningTotal+=rate[9]; runningTotal/=10;
BPM=60000/runningTotal;
if(initCounter==0){ initBPM=BPM; initCounter=1; }
QS=true;
if(Signal<thresh&&Pulse==true){
Pulse=false; amp=P-T; thresh=amp/2+T; P=thresh; T=thresh;
if(N>2500){
thresh=530; P=512; T=512; lastBeatTime=sampleCounter; firstBeat=true; secondBeat=false;
sei();
다른 소스 코드를 참고하여 바꾸어 보았는데도 시리얼 모니터 상에서는 제대로 나오지만 앱 디스플레이 상에서만 BPM값이 겹쳐 나오는 현상이 발생합니다. 이건 앱인벤터 상 문제일까요? 같은 질문을 반복하게 된 것 같아 죄송합니다.
으아아악님의 댓글
으아아악
이곳 질문게시판에서 같은 주제로 진행하신 분이 있는것 같아 그 소스 코드를 사용해봤는데도 똑같은 문제점이 발생하네요ㅠㅠ
운영상의 사소한 문제점은 직접 찾아서 해결하셔야합니다.
(포기하고 사용하시든지..)
