질문게시판 > 아두이노 질문입니다
TODAY1,302 TOTAL2,176,610
BASIC4MCU | 질문게시판 | 아두이노 질문입니다
작성자 야채왕 작성일2019-05-29 13:13 조회3,551회 댓글0건
구현하고자 하는 바는 이렇습니다
하나의 아두이노에 마이크로웨이브모션감지 센서와 초음파 센서와 LED를 같이 사용합니다.
마이크로웨이브 센서에 물체의 움직임이 감지되면  LED에 불이 들어옵니다.
이때 초음파 센서에서 특정거리보다 더 가까워질 경우 불이 들어와있는 LED가 깜박 거리는 방식입니다.
두개가 독립적으로 있을때는 어떻게 하겠는데 두개를 묶어서 하려니 어렵네요 ㅠㅠ
부탁드립니다.
마이크로 웨이브 코딩
#include <MsTimer2.h>           //Timer interrupt function library
int pbIn = 0;                    // Define interrupt 0 that is digital pin 2
int ledOut = 13;                 // Define the indicator LED pin digital pin 13
int number=0;                    //Interrupt times
volatile int state = LOW;         // Defines the indicator LED state, the default is not bright
     pinMode(ledOut, OUTPUT);//
     attachInterrupt(pbIn, stateChange, FALLING); // Set the interrupt function, interrupt pin is digital pin D2, interrupt service function is stateChange (), when the D2 power change from high to low , the trigger interrupt.
     MsTimer2::set(1000, Handle); // Set the timer interrupt function, running once Handle() function per 1000ms
     MsTimer2::start();//Start timer interrupt function
Serial.println(number); // Printing the number of times of interruption, which is convenient for debugging.
    delay(1);
    if(state == HIGH)  //When a moving object is detected, the ledout is automatically closed after the light 2S, the next trigger can be carried out, and No need to reset. Convenient debugging.
        delay(2000);
        state = LOW;
        digitalWrite(ledOut, state);    //turn off led
void stateChange()  //Interrupt service function
  number++;  //Interrupted once, the number + 1
void Handle()   //Timer service function
    if(number>1)  //If in the set of the interrupt time the number more than 1 times, then means have detect moving objects,This value can be adjusted according to the actual situation, which is equivalent to adjust the threshold of detection speed of moving objects.
                   state = HIGH;
                   digitalWrite(ledOut, state);    //light led
                   number=0;   //Cleare the number, so that it does not affect the next trigger
              number=0;   //If in the setting of the interrupt time, the number of the interrupt is not reached the threshold value, it is not detected the moving objects, Cleare the number.
초음파 센서 입니다.
#define TRIG_PIN 2
#define ECHO_PIN 3
#define LED_PIN 4
pinMode(TRIG_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(LED_PIN, OUTPUT);
int distance = 0;
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
digitalWrite(TRIG_PIN, HIGH)/58.2;
/*10cm 이내로 접근시 LED를 켠다*/
 if(distance <= 10)
 digitalWrite(LED_PIN, HIGH);
 digitalWrite(LED_PIN, LOW);
제가 아직 실력이 안돼서 코딩이 조금 어렵네요 그래서 질문드리고 답변해주신 코드를 보며 공부를 하곤 합니당,,,
번거롭고 귀찮으시겠지만.. 부탁드려요 ㅠㅠㅠ
조회수 3,551
답변 답변글 답변 : 아두이노 서보모터 무한회전 문제 해결을 어떻게 해야할까요댓글[5] 새글 master 22-05-27 39
질문 모터 엔코더 제어 질문드립니다. 새글 oreoreo 22-05-27 24
답변 답변글 답변 : 아두이노 속도측정, 속도를 LCD에 표시, 가까워지면 부저 새글 master 22-05-27 22
질문 ATmega128 1602A LCD 출력 질문입니다.댓글[2] 새글 444222a 22-05-27 45
질문 적외선 거리 센서로 블루투스 알람 설정 코딩...댓글[1] ededed 22-05-26 30
질문 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 아트메가넘어려워 22-05-26 38
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. aasdw 22-05-26 75
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] master 22-05-26 74
