질문게시판 > atmega128 하이퍼터미널 질문..
TODAY1,315 TOTAL2,176,623
BASIC4MCU | 질문게시판 | atmega128 하이퍼터미널 질문..
작성자 아트메가요오 작성일2019-05-29 23:09 조회7,084회 댓글2건
	하이퍼 터미널에 숫자 1을 치면 led 불이 켜졋다 꺼지고 숫자 2를 치면 fnd가 작동 되는 코딩인데 주석을 달고 싶은데 책만 보고 베낀거라 하나두 몰라서요.. 혹시 큰 틀만이라도 주석 달아주실수 있는분 계신가요? ㅠㅠ
#include <stdio.h>
#define DDR_LED DDRB
#define PORT_LED PORTB
#define DDR_FND DDRA
#define PORT_FND PORTA
#define UART_RX_BUFLEN 128
#define BS 0x08
#define CR 0x0D
volatile unsigned int tic_time;
ISR(TIMER0_OVF_vect,ISR_NOBLOCK)
tic_time++;
TCNT0 = 6;
void uart_send_byte(unsigned char byte)
while(!(UCSR0A & (1<<UDRE0)));
  UDR0 = byte;
void uart_send_string(unsigned char *str, unsigned char len)
int i;
for(i=0;i<len;i++)
if(!(*(str + i)))
uart_send_byte(*(str + i));
unsigned char uart_recv_byte(void)
while(!(UCSR0A & (1<<RXC0)));
return UDR0;
void uart_recv_string(unsigned char *str)
unsigned char len = 0;
unsigned char byte;
for(;;)
if(len>= UART_RX_BUFLEN - 1)
byte = uart_recv_byte();
if(byte==CR)
uart_send_byte('\n');
uart_send_byte('\r');
else if(byte==BS)
if(len)
len--;
uart_send_byte(byte);
uart_send_byte(' ');
str[len++] = byte;
str[len] = 0;
return len;
void menu_display(void)
uart_send_string("\n\r 1. LED test", 15);
uart_send_string("\n\r 2. FND test", 15);
uart_send_string("\n\r Input number(1-2) : ", 25);
void Putch1(unsigned char data)
while (!(UCSR0A & (1 << UDRE0)));
UDR0 = data;
char Getch1(void)
while(!(UCSR0A & (1 << RXC0)));
return UDR0;
unsigned char fnd[10] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x27,0x7F,0x6F};
FILE *fp;
fp = fdevopen(Putch1, Getch1);
unsigned char buf[UART_RX_BUFLEN];
unsigned int i;
DDR_LED = 0xFF;
PORT_LED = 0xFF;
DDR_FND = 0xFF;
DDRC = 0x0F;
PORT_FND = 0xFF;
TCCR0 = (1<<CS02) | (0<<CS01) | (0<<CS00);
TCNT0 = 6;
TIMSK = (1<<OCIE0) | (1<<TOIE0);
UBRR0L = 103;
UBRR0H = 0;
UCSR0C = (0<<UPM1) | (0<<UPM0) | (0<<USBS) | (1<<UCSZ1) | (1<<UCSZ0);
UCSR0B = (1<<TXEN) | (1<<RXEN) | (0<<UCSZ2);
sei();
for(;;)
menu_display();
uart_recv_string(buf);
switch(atoi(buf))
case 1:
for(i=0;i<8;i++)
PORT_LED = ~(1 << i);
_delay_ms(10000);
PORT_LED = 0xFF;
uart_send_string("OK.\r\n",5);
case 2:
for(i=0;i<10;i++)
PORT_FND = fnd[i];
_delay_ms(500);
PORTC = 0xFC;
PORT_FND = 0xFF;
default:
uart_send_string("Invalidarguments.\r\n",20);
return 1;
 마지막으로 하이퍼터미널에서 1을 입력하면 OK가 나오던데 OK가 출력되는 원리가 뭔가요?
조회수 7,084
주석 달아달라는 요구를 들어줄 사람은 없을겁니다.
공부해서 직접 적으세요
아트메가요오님의 댓글
아트메가요오 댓글의 댓글 작성일
네네~
답변 답변글 답변 : 아두이노 서보모터 무한회전 문제 해결을 어떻게 해야할까요댓글[5] 새글 master 22-05-27 39
질문 모터 엔코더 제어 질문드립니다. 새글 oreoreo 22-05-27 24
답변 답변글 답변 : 아두이노 속도측정, 속도를 LCD에 표시, 가까워지면 부저 새글 master 22-05-27 22
답변 답변글 답변 : 블루투스 관련 코드 도와주세요 새글 master 22-05-27 21
질문 ATmega128 1602A LCD 출력 질문입니다.댓글[2] 새글 444222a 22-05-27 45
질문 적외선 거리 센서로 블루투스 알람 설정 코딩...댓글[1] ededed 22-05-26 30
질문 atmega128 키패드 입력 오류에 대하여 질문 있습니다.댓글[2] 마프하나 22-05-26 65
질문 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 아트메가넘어려워 22-05-26 38
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. aasdw 22-05-26 75
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] master 22-05-26 75
