질문게시판 > 아두이노 심박센서와 블루투스 연결
TODAY1,461 TOTAL2,172,660
BASIC4MCU | 질문게시판 | 아두이노 심박센서와 블루투스 연결
작성자 이채희 작성일2019-05-30 14:07 조회6,838회 댓글2건
밑에 코드는 지식인에서 옥현님께서 올려주신 코드입니다.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3); //블루투스의 Tx, Rx핀을 2번 3번핀으로 설정
#define PROCESSING_VISUALIZER 1
#define SERIAL_PLOTTER        2
int pulsePin=A0,blinkPin=13,fadePin=5;
int fadeRate=0,initCounter=0,initBPM=0;
volatile int  BPM,difference;
volatile int  Signal;
volatile int  IBI=600;
volatile bool Pulse=false;
volatile bool QS=false;
static int outputType=SERIAL_PLOTTER;
char str[100];
  pinMode(3,OUTPUT);
  pinMode(blinkPin,OUTPUT);
  pinMode(fadePin,OUTPUT);
  mySerial.begin(9600);
  interruptSetup();
  serialOutput();
  if(QS==true){ fadeRate=255; serialOutputWhenBeatHappens(); QS=false; }
  ledFadeToBeat();
  Serial.print("difference: "); Serial.println(difference);
  if(difference>15){ digitalWrite(3,HIGH); delay(1000); }
  else             { digitalWrite(3,LOW); }
  delay(200);
void ledFadeToBeat(){
  fadeRate-=15; fadeRate=constrain(fadeRate,0,255); analogWrite(fadePin,fadeRate);
void serialOutput(){
  switch(outputType){
    case PROCESSING_VISUALIZER: sprintf(str,"Signal: %d\r\n",Signal); Serial.print(str); mySerial.print(str); break;
    case SERIAL_PLOTTER: sprintf(str,"BPM: %d,IBI: %d,Signal: %d\r\n",BPM,IBI,Signal); Serial.print(str); mySerial.print(str); break;
void serialOutputWhenBeatHappens(){
  switch(outputType){
    case PROCESSING_VISUALIZER: sprintf(str,"BPM: %d,IBI: %d\r\n",BPM,IBI); Serial.print(str); mySerial.print(str); break;
volatile int rate[10];
volatile unsigned long sampleCounter=0;
volatile unsigned long lastBeatTime=0;
volatile int P=512;
volatile int T=512;
volatile int thresh=530;
volatile int amp=0;
volatile boolean firstBeat=true;
volatile boolean secondBeat=false;
void interruptSetup(){
  TCCR2A=0x02; TCCR2B=0x06; OCR2A=0X7C; TIMSK2=0x02; sei();
ISR(TIMER2_COMPA_vect){
  cli();
  Signal=analogRead(pulsePin);
  sampleCounter+=2;
  int N=sampleCounter-lastBeatTime;
  if(Signal<thresh&&N>(IBI/5)*3){ if(Signal<T)T=Signal; }
  if(Signal>thresh&&Signal>P){ P=Signal; }
  if(N>250){
    if((Signal>thresh)&&(Pulse==false)&&(N>(IBI/5)*3)){
      Pulse=true;
      digitalWrite(blinkPin,HIGH);
      IBI=sampleCounter-lastBeatTime;
      lastBeatTime=sampleCounter;
      if(secondBeat){ secondBeat=false; for(int i=0; i<=9; i++)rate[i]=IBI; }
      if(firstBeat){ firstBeat=false; secondBeat=true; sei(); return; }
      word runningTotal=0;
      for(int i=0; i<=8; i++){ rate[i]=rate[i+1]; runningTotal+=rate[i]; }
      rate[9]=IBI;
      runningTotal+=rate[9]; runningTotal/=10;
      BPM=60000/runningTotal;
      if(initCounter==0){ initBPM=BPM; initCounter=1; }
      difference=initBPM-BPM;
      QS=true;
  if(Signal<thresh&&Pulse==true){
    digitalWrite(blinkPin,LOW); Pulse=false; amp=P-T; thresh=amp/2+T; P=thresh; T=thresh;
  if(N>2500){
    thresh=530; P=512; T=512; lastBeatTime=sampleCounter; firstBeat=true; secondBeat=false;
  sei();
위 코드에서 블루투스에 관한 코드가 무엇인지 궁금합니다!
그리고 코드 실행결과 BPM값이 이상한 특수문자로 나옵니다ㅠㅠ
조회수 6,838
이채희님의 댓글
이채희 작성일
그리고 추가적으로,,, BPM값이 0부터 250까지 계속 뒤바뀌면서 나옵니다... 센서의 문제인가요? 새 센서로 해도 값이 계속 불안정하네요.... ㅠㅠㅠㅠ
mySerial이라는 이름을 사용하는 코드가 블루투스 코드입니다.
특수문자나 값이 뒤바뀌면서 나오는 것에 대해서는 잘 모르겠습니다.
모듈 제조사에서 제공하는 예제로 공부하세요
공지 사이트 이용 안내댓글[24] master 17-10-29 29798
질문 atmega128 키패드 입력 오류에 대하여 질문 있습니다.댓글[1] 새글 마프하나 16:07 14
질문 초음파센싱을 통한 리니어벨트 (스텝모터사용) 조건문댓글[1] 새글 아두이노대학 15:01 15
질문 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 새글 아트메가넘어려워 14:10 16
답변 답변글 답변 : 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 새글 master 14:56 13
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. 새글 aasdw 06:28 31
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. 새글 master 14:09 20
질문 atmega128 타이머 작성시 키패트 입력으로 인터럽트 사용에 대하여 질문이 있습니다.댓글[1] 이미지새글 마프하나 22-05-25 31
질문 로드셀 무게 센서 질문드립니다.댓글[2] 새글 제비고기 22-05-25 30
질문 adc, uart dma댓글[3] 새글첨부파일 hiㅡO3O 22-05-25 26
질문 아두이노 스텝모터 리미트 문의드립니다.댓글[3] 이미지새글첨부파일 스트렌져 22-05-24 32
질문 atmega128 GPS,블루투스 질문드립니다.댓글[1] 코딩초보1 22-05-24 32
질문 서보모터 제어에 관하여 궁금합니다댓글[3] 이미지첨부파일 오소로롯 22-05-24 51
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[8] 이미지 마프하나 22-05-23 66
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 220
답변 답변글 답변 : 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 … 새글 master 22-05-24 28
질문 atmega 128 블루투스 질문 입니다댓글[1] yhj2644 22-05-23 51
답변 답변글 답변 : 아두이노의 지속 시간에 대해 질문합니다. master 22-05-23 38
질문 초음파+스텝모터 도꺼비 22-05-22 39
