질문게시판 > 답변 : atmega128 7segment 에 딜레이 주기
TODAY386 TOTAL2,169,336
BASIC4MCU | 질문게시판 | 답변 : atmega128 7segment 에 딜레이 주기
작성자 master 작성일2019-06-03 15:32 조회3,397회 댓글0건
// DateTime : 2019-06-03 오후 3:40:01
//자판기 동작을 나타낸 마이크로프로세서
// PA: 7segment Data
// PB: LED I/O
// PC: LCD Data
// PD: LCD Control
// PE: Switch Intrrupt
// PF: 7segment Scan
#include <avr/io.h>
#include <avr/interrupt.h>
#define   F_CPU 16000000UL // 16 MHz
#include <util/delay.h>
#include <stdio.h>
#define E_LCD  {PORTD|=0x40;_delay_us(1);PORTD&=~0x40;}
volatile unsigned char SegDEC[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
volatile unsigned char SegData[4]={0,};
volatile unsigned char mode=0;
volatile          int  money=0;
void cmd_LCD (char c){ PORTD&=~0x10PORTC=cE_LCD_delay_ms3); }
void data_LCD(char d){ PORTD|= 0x10PORTC=dE_LCD_delay_us(40); }
void str_LCD(char *s){ while(*s)data_LCD(*s++); }
void clear_LCD(){ cmd_LCD(1); }
void gotoxy_LCD(unsigned char x,unsigned char y){ cmd_LCD (0x80+x+0x40*y); }
void init_LCD(){
  _delay_ms(100);
  cmd_LCD(0x30); cmd_LCD(0x30); cmd_LCD(0x30); cmd_LCD(0x38);
  cmd_LCD(0x0C); cmd_LCD(0x01); cmd_LCD(0x06);
void conv(int m){
  SegData[0]=m/1000SegData[1]=m/100%10SegData[2]=m/10%10SegData[3]=m%10;
ISR(TIMER0_COMP_vect){
  static char CntScan=0;
  PORTF|=0x0F;
  PORTA=SegDEC[SegData[CntScan]];
  PORTF&=~(1<<CntScan);
  if(++CntScan>3)CntScan=0;
ISR(INT4_vect){ mode=1money+=1000if(money>9999)money=9999conv(money); }
ISR(INT5_vect){ if(money>=600){ mode=2money-=600conv(money); } }
ISR(INT6_vect){ if(money>=100){ mode=3money-=100conv(money); } }
int main(){
  char i,str[20];
  DDRC=0xFF;                // LCD Data
  PORTD&=~0x70DDRD|=0x70// LCD Control(PD4: RS,PD5: R/W,PD6: E)
  PORTA=0xFF;   DDRA=0xFF;  // 7segment Data
  PORTF|=0x0F;  DDRF|=0x0F// 7segment Scan
  PORTB=0xFF;   DDRB=0xFF;  // LED
  init_LCD();
  TCCR0=0x0DOCR0=124;  TIMSK=0x02;  // 1ms
  EICRB=0xAAEIFR=0xFFEIMSK|=0x70// INT6,5,4: Interrupt Enable
  SREG=0x80;
    if(mode==0){
      gotoxy_LCD(0,0); str_LCD("Welcome Bro !");
      gotoxy_LCD(0,1); str_LCD("On Sale . .  ");
      for(i=0i<5i++){ PORTB=0xFFPORTB>>=i*2PORTB<<=i_delay_ms(300); }
      for(i=3i>0i--){ PORTB=0xFFPORTB>>=i*2PORTB<<=i_delay_ms(300); }
    else if(mode==1){ // INT4
      PORTB=0x00;
      sprintf(str,"%4d won left ..",);
      gotoxy_LCD(0,0); str_LCD(str);
      gotoxy_LCD(0,1); str_LCD("1000won thanks !");
    else if(mode==2){ // INT5
      PORTB=0xFF;
      gotoxy_LCD(0,1); str_LCD("Take the charge?");
      if(money==0)mode=0;
    else if(mode==3){ // INT6
      gotoxy_LCD(0,1); str_LCD("your service !  ");
      if(money==0)mode=0;
    _delay_ms(100);
조회수 3,397
공지 사이트 이용 안내댓글[24] master 17-10-29 29742
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 새글 졸작부수다 22-05-23 110
질문 초음파+스텝모터 도꺼비 22-05-22 23
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 24
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 49
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 30
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 35
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 35
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지첨부파일 오소로롯 22-05-21 51
질문 아두이노 에러질문댓글[1] 이미지첨부파일 리니어 22-05-21 45
질문 아두이노 DRV2605 헵틱 모터 드라이버댓글[4] gano 22-05-21 50
