질문게시판 > 답변 : atmega128 7segment 에 딜레이 주기
TODAY2,157 TOTAL685,027
BASIC4MCU | 질문게시판 | 답변 : atmega128 7segment 에 딜레이 주기
작성자 master 작성일2019-06-03 15:32 조회165회 댓글0건
// DateTime : 2019-06-03 오후 3:40:01
//자판기 동작을 나타낸 마이크로프로세서
// PA: 7segment Data
// PB: LED I/O
// PC: LCD Data
// PD: LCD Control
// PE: Switch Intrrupt
// PF: 7segment Scan
#include <avr/io.h>
#include <avr/interrupt.h>
#define   F_CPU 16000000UL // 16 MHz
#include <util/delay.h>
#include <stdio.h>
#define E_LCD  {PORTD|=0x40;_delay_us(1);PORTD&=~0x40;}
volatile unsigned char SegDEC[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
volatile unsigned char SegData[4]={0,};
volatile unsigned char mode=0;
volatile          int  money=0;
void cmd_LCD (char c){ PORTD&=~0x10PORTC=cE_LCD_delay_ms3); }
void data_LCD(char d){ PORTD|= 0x10PORTC=dE_LCD_delay_us(40); }
void str_LCD(char *s){ while(*s)data_LCD(*s++); }
void clear_LCD(){ cmd_LCD(1); }
void gotoxy_LCD(unsigned char x,unsigned char y){ cmd_LCD (0x80+x+0x40*y); }
void init_LCD(){
  _delay_ms(100);
  cmd_LCD(0x30); cmd_LCD(0x30); cmd_LCD(0x30); cmd_LCD(0x38);
  cmd_LCD(0x0C); cmd_LCD(0x01); cmd_LCD(0x06);
void conv(int m){
  SegData[0]=m/1000SegData[1]=m/100%10SegData[2]=m/10%10SegData[3]=m%10;
ISR(TIMER0_COMP_vect){
  static char CntScan=0;
  PORTF|=0x0F;
  PORTA=SegDEC[SegData[CntScan]];
  PORTF&=~(1<<CntScan);
  if(++CntScan>3)CntScan=0;
ISR(INT4_vect){ mode=1money+=1000if(money>9999)money=9999conv(money); }
ISR(INT5_vect){ if(money>=600){ mode=2money-=600conv(money); } }
ISR(INT6_vect){ if(money>=100){ mode=3money-=100conv(money); } }
int main(){
  char i,str[20];
  DDRC=0xFF;                // LCD Data
  PORTD&=~0x70DDRD|=0x70// LCD Control(PD4: RS,PD5: R/W,PD6: E)
  PORTA=0xFF;   DDRA=0xFF;  // 7segment Data
  PORTF|=0x0F;  DDRF|=0x0F// 7segment Scan
  PORTB=0xFF;   DDRB=0xFF;  // LED
  init_LCD();
  TCCR0=0x0DOCR0=124;  TIMSK=0x02;  // 1ms
  EICRB=0xAAEIFR=0xFFEIMSK|=0x70// INT6,5,4: Interrupt Enable
  SREG=0x80;
    if(mode==0){
      gotoxy_LCD(0,0); str_LCD("Welcome Bro !");
      gotoxy_LCD(0,1); str_LCD("On Sale . .  ");
      for(i=0i<5i++){ PORTB=0xFFPORTB>>=i*2PORTB<<=i_delay_ms(300); }
      for(i=3i>0i--){ PORTB=0xFFPORTB>>=i*2PORTB<<=i_delay_ms(300); }
    else if(mode==1){ // INT4
      PORTB=0x00;
      sprintf(str,"%4d won left ..",);
      gotoxy_LCD(0,0); str_LCD(str);
      gotoxy_LCD(0,1); str_LCD("1000won thanks !");
    else if(mode==2){ // INT5
      PORTB=0xFF;
      gotoxy_LCD(0,1); str_LCD("Take the charge?");
      if(money==0)mode=0;
    else if(mode==3){ // INT6
      gotoxy_LCD(0,1); str_LCD("your service !  ");
      if(money==0)mode=0;
    _delay_ms(100);
조회수 165
질문 다시한번 더 올립니다ㅠㅠ (ATMEGA128,도트매트릭스)댓글[1] 이미지첨부파일 길짱 19-10-20 23
질문 프로그램 작성좀 도와주세요 ㅠ (ATMEGA128,도트매트릭스)댓글[4] 이미지첨부파일 길짱 19-10-17 27
질문 atmega128 인터럽트를 활용해서 State 출력하기 이미지첨부파일 jjw332 19-10-17 17
답변 답변글 답변 : atmega128 인터럽트를 활용해서 State 출력하기댓글[2] 이미지 master 19-10-17 23
질문 Atmega128 입니다댓글[2] 찐덕 19-10-13 36
질문 ATmega128코드 질문입니다. 코딩하는대딩 19-10-12 28
답변 답변글 답변 : ATmega128코드 질문입니다.댓글[1] master 19-10-13 29
질문 ATmega128 프로테우스 소스코드 알고싶습니다 ㅜㅜ댓글[4] 이미지첨부파일 찐덕 19-10-11 44
답변 답변글 답변 : ATmega128 프로테우스 소스코드 알고싶습니다 ㅜㅜ 이미지 master 19-10-11 36
질문 Atmega128댓글[1] 이미지첨부파일 공학러 19-10-11 40
답변 답변글 답변 : Atmega128 이미지 master 19-10-11 32
질문 atmega128a DHT11질문이요 ㅠㅠ댓글[9] 초짜 19-10-10 91
질문 atmega128 Led 쉬프트 코딩 오류댓글[2] 이미지첨부파일 jjw332 19-10-08 69
질문 ATmega128 사거리신호등 소스 질문.. July 19-10-08 46
답변 답변글 답변 : ATmega128 사거리신호등 소스 질문.. master 19-10-08 53
질문 atmega128 led 불빛 코드댓글[2] jjw332 19-10-07 70
질문 ATmega128 인공호흡 질문 이미지 master 19-10-06 41
질문 atmega128a UCSRnA 질문있어요 ㅠㅠ 초짜 19-10-04 46
답변 답변글 답변 : atmega128a UCSRnA 질문있어요 ㅠㅠ댓글[2] master 19-10-04 65
질문 atmega128 기반 avr 프로그래밍 코드 질문 master 19-10-02 65
질문 atmega128a SPI 공부중인데 잘 이해가 안가네요..댓글[4] 초짜 19-09-26 80
답변 답변글 답변 : atmega128a SPI 공부중인데 잘 이해가 안가네요.. master 19-09-29 51
질문 atmega128 의 PWM 모드 질문이요댓글[6] 초짜 19-09-06 161
질문 atmega128a 질문이요댓글[1] 초짜 19-08-30 129
질문 atmega128을 배우고 싶은 고등학생입니다. 고딩 19-08-28 130
답변 답변글 답변 : atmega128을 배우고 싶은 고등학생입니다. master 19-08-28 166
질문 atmega128a 질문 조금만 더하겠습니다 ㅠㅠ댓글[1] 초짜 19-08-27 110
질문 atmega128a FOC 질문이요댓글[3] 초짜 19-08-27 122
질문 atmega128 소스결합 오류댓글[1] 첨부파일 일본인호ㅈ두 19-08-21 140
질문 atmega128a 스위치 질문이요댓글[1] 초짜 19-08-21 130
