질문게시판 > 답변 : 아두이노 블루투스 연결방법
TODAY395 TOTAL2,169,345
BASIC4MCU | 질문게시판 | 답변 : 아두이노 블루투스 연결방법
작성자 master 작성일2019-06-09 21:44 조회3,380회 댓글0건
// DateTime : 2019-06-09 오후 9:51:19
#include <SoftwareSerial.h>
int blueTx=6;
int blueRx=7;
SoftwareSerial mySerail(blueTx,blueRx);
#include <Stepper.h>
const int TMP36_pin=A1//온도
const int stepsPerRevolution=200//회전수  200/한바퀴
Stepper myStepper(stepsPerRevolution,8,9,10,11);
int ENA=2,ENB=3;
int ondo1=37,ondo2=35;
int gas1=250,gas2=200;
boolean window=false//false->닫혀있는상태
//true->열려있는상태
const int gasPin=A0// 가스
int mode=1;
void sensor_open(){
  if(window==0){ window=1;
    Serial.println("open"); myStepper.step(stepsPerRevolution); Serial.println("stop");
    Serial.print("Window Status: "); Serial.println(window);    Serial.println();
void sensor_close(){
  if(window){ window=0;
    Serial.println("Close"); myStepper.step(-stepsPerRevolution); Serial.println("stop");
  myStepper.setSpeed(60);
  pinMode(ENA,OUTPUT); digitalWrite(ENA,HIGH);
  pinMode(ENB,OUTPUT); digitalWrite(ENB,HIGH);
  pinMode(2,INPUT); pinMode(3,INPUT);
  if(mode){
    int   sensorValue=analogRead(TMP36_pin);
    float mVoltage=sensorValue*5000.0/1024.0;
    float temperatureC=(mVoltage-500)/10.0;
    int   value=digitalRead(5);
    Serial.print("Now: ");         Serial.print(temperatureC); Serial.println(" C"); Serial.println();
    Serial.print("current gas: "); Serial.println(analogRead(gasPin));               Serial.println();
    Serial.print("Rain: ");        Serial.println(value); Serial.print("Window: ");
    if     (window==false)Serial.println("Close");
    else if(window==true )Serial.println("Open");
    Serial.println("==============================================="); Serial.println();
    if(window==false&&value==1){                               //창문이 닫혀있고 비가 안오는 상태
      if     (temperatureC<=ondo2&&analogRead(gasPin)>=gas1){ sensor_open(); }
      else if(temperatureC>=ondo1&&analogRead(gasPin)>=gas1){ sensor_open(); }
      else if(temperatureC<=ondo2&&analogRead(gasPin)<=gas2){ } //동작안함
      else if(temperatureC>=ondo1&&analogRead(gasPin)<=gas2){ sensor_open(); }
    else if(window==false&&value==0){                           //창문이 닫혀있고 비가 오는 상태
      else if(temperatureC>=ondo1&&analogRead(gasPin)<=gas2){ } //동작안함
      else                                                  { } //동작안함
    else if(window==true&&value==1){                            //창문이열려있고 비가 안오는 상태
      if     (temperatureC<=ondo2&&analogRead(gasPin)>=gas1){ } //동작안함
      else if(temperatureC>=ondo1&&analogRead(gasPin)>=gas1){ } //동작안함
      else if(temperatureC<=ondo2&&analogRead(gasPin)<=gas2){ sensor_close(); }
    else if(window==true&&value==0){                            //창문이열려있고 비가 오는 상태
      else if(temperatureC>=ondo1&&analogRead(gasPin)<=gas2){ sensor_close(); }
      else                                                  { sensor_close(); }
  if(Serial.available()){
    char in_data=Serial.read();
    btSerial.write(in_data);
    if(in_data=='0'){ mode=0// 정지
      digitalWrite(in1,LOW); digitalWrite(in2,LOW);
      digitalWrite(in3,LOW); digitalWrite(in4,LOW);
    if(in_data=='1'){ mode=0// 오픈
      digitalWrite(in1,HIGH); digitalWrite(in2,LOW);
      digitalWrite(in3,HIGH); digitalWrite(in4,LOW);
    if(in_data=='2'){ mode=0// 클로우즈
      digitalWrite(in1,LOW); digitalWrite(in2,HIGH);
      digitalWrite(in3,LOW); digitalWrite(in4,HIGH);
    if(in_data=='3'){ mode=1; } // 센서로 동작
조회수 3,380
공지 사이트 이용 안내댓글[24] master 17-10-29 29743
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 새글 졸작부수다 22-05-23 111
질문 초음파+스텝모터 도꺼비 22-05-22 23
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 25
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 50
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 30
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 35
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 35
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지첨부파일 오소로롯 22-05-21 51
질문 아두이노 에러질문댓글[1] 이미지첨부파일 리니어 22-05-21 45
질문 아두이노 DRV2605 헵틱 모터 드라이버댓글[4] gano 22-05-21 51
