질문게시판 > 아두이노와 스피커 재질문
TODAY402 TOTAL2,169,352
BASIC4MCU | 질문게시판 | 아두이노와 스피커 재질문
작성자 이채희 작성일2019-06-10 12:25 조회4,567회 댓글1건
옥현님의 심박센서 코드
SoftwareSerial mySerial(2,3); //블루투스의 Tx, Rx핀을 2번 3번핀으로 설정
#define PROCESSING_VISUALIZER 1
#define SERIAL_PLOTTER        2
int pulsePin=A6,blinkPin=13,fadePin=5;
int fadeRate=0,initCounter=0,initBPM=0;
volatile int  BPM,difference;
volatile int  Signal;
volatile int  IBI=600;
volatile bool Pulse=false;
volatile bool QS=false;
static int outputType=SERIAL_PLOTTER;
char str[100];
  pinMode(3,OUTPUT);
  pinMode(blinkPin,OUTPUT);
  pinMode(fadePin,OUTPUT);
  mySerial.begin(9600);
  interruptSetup();
  serialOutput();
  if(QS==true){ fadeRate=255; serialOutputWhenBeatHappens(); QS=false; }
  ledFadeToBeat();
  if(difference>15){ digitalWrite(3,HIGH); delay(1000); }
  else             { digitalWrite(3,LOW); }
void ledFadeToBeat(){
  fadeRate-=15; fadeRate=constrain(fadeRate,0,255); analogWrite(fadePin,fadeRate);
void serialOutput(){
  switch(outputType){
    case PROCESSING_VISUALIZER: sprintf(str,"Signal: %d\r\n",Signal); Serial.print(str); mySerial.print(str); break;
    case SERIAL_PLOTTER: sprintf(str,"BPM: %d\r\n",BPM); Serial.print(str); mySerial.print(str); break;
void serialOutputWhenBeatHappens(){
  switch(outputType){
    case PROCESSING_VISUALIZER: sprintf(str,"BPM: %dd\r\n",BPM); Serial.print(str); mySerial.print(str); break;
volatile int rate[10];
volatile unsigned long sampleCounter=0;
volatile unsigned long lastBeatTime=0;
volatile int P=512;
volatile int T=512;
volatile int thresh=530;
volatile int amp=0;
volatile boolean firstBeat=true;
volatile boolean secondBeat=false;
void interruptSetup(){
  TCCR2A=0x02; TCCR2B=0x06; OCR2A=0X7C; TIMSK2=0x02; sei();
ISR(TIMER2_COMPA_vect){
  cli();
  Signal=analogRead(pulsePin);
  sampleCounter+=2;
  int N=sampleCounter-lastBeatTime;
  if(Signal<thresh&&N>(IBI/5)*3){ if(Signal<T)T=Signal; }
  if(Signal>thresh&&Signal>P){ P=Signal; }
  if(N>250){
    if((Signal>thresh)&&(Pulse==false)&&(N>(IBI/5)*3)){
      Pulse=true;
      digitalWrite(blinkPin,HIGH);
      IBI=sampleCounter-lastBeatTime;
      lastBeatTime=sampleCounter;
      if(secondBeat){ secondBeat=false; for(int i=0; i<=9; i++)rate[i]=IBI; }
      if(firstBeat){ firstBeat=false; secondBeat=true; sei(); return; }
      word runningTotal=0;
      for(int i=0; i<=8; i++){ rate[i]=rate[i+1]; runningTotal+=rate[i]; }
      rate[9]=IBI;
      runningTotal+=rate[9]; runningTotal/=10;
      BPM=60000/runningTotal;
      if(initCounter==0){ initBPM=BPM; initCounter=1; }
      difference=initBPM-BPM;
      QS=true;
  if(Signal<thresh&&Pulse==true){
    digitalWrite(blinkPin,LOW); Pulse=false; amp=P-T; thresh=amp/2+T; P=thresh; T=thresh;
  if(N>2500){
    thresh=530; P=512; T=512; lastBeatTime=sampleCounter; firstBeat=true; secondBeat=false;
  sei();
스피커 코드
​int speaker=5;
pinMode(speaker, OUTPUT);   //스피커
if(BPM<40){   //스피커
tone(speaker,440);   //스피커
delay(1000);   //스피커
}   //스피커
else{   //스피커
noTone(speaker);   //스피커
}   //스피커
​스피커 코드는 제가 짠 코드입니다.
아두이노에 있는 심박수 예제와 스피커 코드를 결합하였을때는 잘 작동되었는데
옥현님이 주신 코드와 결합하였을때는 '보드Arduino Nano 컴파일 에러'​라고 뜹니다
뭐가 문제인지 알려주세요...
추가적으로 심박센서가 많이 불안정한데 이는 어떻게 해결해야되나요?​
제가 합친코드는
char str[100];
int speaker=5; //스피커
  pinMode(3,OUTPUT);
  interruptSetup();
  serialOutput();
  ledFadeToBeat();
if(BPM<40){   //스피커
delay(1000);   //스피커
}   //스피커
else{   //스피커
}   //스피커
  switch(outputType){
  switch(outputType){
volatile int P=512;
volatile int T=512;
volatile int amp=0;
  cli();
  sampleCounter+=2;
  if(N>250){
      Pulse=true;
      rate[9]=IBI;
      QS=true;
  if(N>2500){
  sei();
위와 같습니다. 에러는 파일첨부하겠습니다.
심박센서가 많이 불안정한데 이를 어떻게 해야하는지 도움을 주시면 감사하겠습니다ㅠㅠ
조회수 4,567
D5핀 중복은 아래 글에서 답변으로 적어드렸고
톤은 타이머2를 사용합니다.
따라서 타이머 인터럽트를 사용하고 싶으면 타이머1을 공부해서 사용해보세요
심박센서 출력이 많이 흔들린다면 USB 케이블을 연겷 하지말고 배터리로 구동해보세요
PC 시리얼모니터로 통신하고 싶은 경우에는 블루투스 모듈을 사용해서 블루투스로 무선 전송해보세요
공지 사이트 이용 안내댓글[24] master 17-10-29 29743
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 새글 졸작부수다 22-05-23 111
질문 초음파+스텝모터 도꺼비 22-05-22 23
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 25
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 50
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 30
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 36
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 35
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지첨부파일 오소로롯 22-05-21 51
질문 아두이노 에러질문댓글[1] 이미지첨부파일 리니어 22-05-21 45
질문 아두이노 DRV2605 헵틱 모터 드라이버댓글[4] gano 22-05-21 52
