질문게시판 > 답변 : PWM질문입니다.
TODAY793 TOTAL375,819
BASIC4MCU | 질문게시판 | 답변 : PWM질문입니다.
작성자 master 작성일2018-05-16 09:31 조회771회 댓글1건
ìëì´ë¸ ëìì ëí ì´ë¯¸ì§ ê²ìê²°ê³¼
// DateTime : 2018-05-16 오전 9:33:26
#define DEBUG
#include <LiquidCrystal.h>
LiquidCrystal lcd(2,3,4,5,6,7,8,9,10,11,12);
SteppingMotor Ra ={39,0,true,0};
SteppingMotor Dec={41,0,true,0};
void sethz(int num,unsigned int hz){
  PWM->PWM_CH_NUM[num].PWM_CPRD=(3000000/hz);
  PWM->PWM_CH_NUM[num].PWM_CDTY=(1500000/hz);
struct SteppingMotor{
  int P_CWint P_CCWboolean Dirlong step//CW: true CCW: false
void ISR1(){ if(Ra.Dir )Ra.step++;  else Ra.step--;  }
void ISR2(){ if(Dec.Dir)Dec.step++; else Dec.step--; }
void ISR3(){ Ra.Dir =!Ra.Dir;  }
void ISR4(){ Dec.Dir=!Dec.Dir; }
void PWM_Init(){
  // PWM Set-up on pins PC7 and PA20(Arduino Pins 39(PWMH2): see Datasheet chap.38.5.1 page 973
  PMC->PMC_PCER1|=PMC_PCER1_PID36;               // PWM power ON
  PWM->PWM_DIS=PWM_DIS_CHID2;                    // Disable PWM channel 2
  PWM->PWM_DIS=PWM_DIS_CHID3;                    // Disable PWM channel 3
  // Select Instance=PWM; Signal=PWMH2(channel 2); I/O Line=PC7(P7,Arduino pin 39,see pinout diagram); Peripheral type B
  PIOC->PIO_PDR|=PIO_PDR_P7;                     // Set the pin to the peripheral PWM,not the GPIO
  PIOC->PIO_ABSR|=PIO_PC7B_PWMH2;                // Set PWM pin perhipheral type B
  //  Select Intancd=PWMl Signal=PWMH3(channel 2); I/O LIne=PC9(P9,Arduino pin 41,see pinout diagram); Peripheral type B
  //Added by me for generate another pulse
  PIOC->PIO_PDR|=PIO_PDR_P9;                     // Set the pin to the peripheral PWM,not the GPIO
  PIOC->PIO_ABSR|=PIO_PC9B_PWMH3;                // Set PWM pin perhipheral type B
  PWM->PWM_CLK=PWM_CLK_PREB(0)|PWM_CLK_DIVB(28); // Set the PWM clock rate to 3MHz(84MHz/28).
  PWM->PWM_CH_NUM[2].PWM_CMR=PWM_CMR_CPRE_CLKB;  // clock source as CLKB on channel 2,waveform left aligned
  //Added by me
  PWM->PWM_CH_NUM[3].PWM_CMR=PWM_CMR_CPRE_CLKB;  // clock source as CLKB on channel 3,waveform left aligned
  PWM->PWM_CH_NUM[2].PWM_CPRD=3000;              // Channel 2: Set the PWM frequency 3MHz/CPRD=1 KHz;
  PWM->PWM_CH_NUM[2].PWM_CDTY=1500;              // Channel 2: Set the PWM duty cycle to x%=(CDTY/ CPRD)*100%;
  //Added by me for another pulse out
  PWM->PWM_CH_NUM[3].PWM_CPRD=3000;              // Channel 3: Set the PWM frequency 3MHz/CPRD=1 KHz;
  PWM->PWM_CH_NUM[3].PWM_CDTY=1500;              // Channel 3: Set the PWM duty cycle to x%=(CDTY/ CPRD)*100%;
  PWM->PWM_IER1=PWM_IER1_CHID2;                  // Interrupt on Channel 2 Counter match
  //Added by me for channel 3
  PWM->PWM_IER1=PWM_IER1_CHID3;                  // Interrupt on Channel 3 Counter match
  NVIC_EnableIRQ(PWM_IRQn);                      // Enable interrupt
  PWM->PWM_ENA=PWM_ENA_CHID2;                    // Enable PWM Channel 2
  //Added by me
  PWM->PWM_ENA=PWM_ENA_CHID3;                    // Enable PWM Channel 3
  lcd.begin(20,4);    lcd.clear();
  lcd.setCursor(0,0); lcd.print("    Solomon  TCS    ");
  lcd.setCursor(0,1); lcd.print("      Ver  000      ");
  lcd.setCursor(0,2); lcd.print("   Void Laboratory  ");
  lcd.setCursor(0,3); lcd.print("   made by Dr.Void  ");
  PWM_Init();
  //lcd.begin(20,4);
  //attachInterrupt(Ra.P_CW,ISR1,RISING);        // 인터럽트 부착(하이 펄스 회수 측정)
  //attachInterrupt(Ra.P_CCW,ISR3,CHANGE);       // 방향체크
  //DEC 축 모터
  //attachInterrupt(Dec.P_CW,ISR2,RISING);       // 인터럽트 부착(하이 펄스 회수 측정)
  //attachInterrupt(Dec.P_CCW,ISR4,CHANGE);      // 방향 체크*/
  //delay(3000);
  lcd.clear();
  // pinMode(33,OUTPUT); pinMode(34,OUTPUT); pinMode(35,OUTPUT); for(int i=36;i<53;i++){ pinMode(i,INPUT_PULLUP); }
  // Serial.begin(9600); pinMode( 2,OUTPUT); pinMode( 3,OUTPUT);
  /*lcd.clear();
  lcd.setCursor(0,0);
  switch(keycheck(33,34,35)){
    case 0: lcd.print("NoInput");        break;
    case 36: lcd.print("MENU");          break; //5
    case 37: lcd.print("DEC-");          break;
    case 38: lcd.print("Prev");          break;
    case 39: lcd.print("num1");          break;
    case 40: lcd.print("num4");          break;
    case 41: lcd.print("num7");          break;
    case 42: lcd.print("num*");          break;
    case 43: lcd.print("RA+");           break; //6
    case 44: lcd.print("Enter");         break;
    case 45: lcd.print("RA-");           break;
    case 46: lcd.print("num2");          break;
    case 47: lcd.print("num5");          break;
    case 48: lcd.print("num8");          break;
    case 49: lcd.print("num0");          break;
    case 50: lcd.print("LCD BackLight"); break; //7
    case 51: lcd.print("DEC+");          break;
    case 52: lcd.print("Next");          break;
int keycheck(const int pin1,const int pin2,const int pin3){
  int i;
  digitalWrite(pin1,LOW);
  for(i=pin3+1;i<pin3+9;i++){ if(!digitalRead(i))return i; }
  digitalWrite(pin1,HIGH); digitalWrite(pin2,LOW);
  for(;i<pin3+17;i++){
    #ifdef DEBUG
      Serial.print(i); Serial.print(": "); Serial.println(digitalRead(i));
    #endif
  digitalWrite(pin2,HIGH); digitalWrite(pin2,LOW);
  for(;i<pin3+25;i++){ if(!digitalRead(i))return i; }
  return 0;
LCD 핀과 PWM핀에서 핀 중복이 있는 것 아닌지 체크해보세요
PWM핀을 옮기는 것보다 LCD 핀을 옮기는 것이 쉬울겁니다.
조회수 771
DrVoid님의 댓글
DrVoid 작성일
늦은시간에 올린 글인데도 답변을 달아주셔서 감사합니다.
할당한 PWM이 2번이라서 다른 PWM은 문제없을거라 생각하였는데 역시나..
정말 감사합니다. 도움이 필요할때마다 글을 올릴게요.
정말로 감사합니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 25
공지 사이트 이용 안내 댓글[4] master 17-10-29 4676
질문 마스터님 봐주세요~ 댓글[2] 이미지새글첨부파일 현이꽃 19-01-22 17
답변 답변글 답변 : 마스터님 봐주세요~ 댓글[6] 새글 master 09:50 14
질문 c언어 조언 해주세요. 댓글[2] 새글 c린이 19-01-22 15
질문 손문일 새글 손문일 19-01-22 18
답변 답변글 답변 : 손문일 새글 master 19-01-22 9
답변 답변글 답변 : 손문일 새글 손문일 19-01-22 6
답변 답변글 답변 : 답변 : 손문일 새글 master 19-01-22 8
질문 블루투스 조이스틱 질문좀요 새글 현이꽃 19-01-22 9
답변 답변글 답변 : 블루투스 조이스틱 질문좀요 댓글[1] 새글 master 19-01-22 12
질문 atmega128 풀업 스위치 댓글[2] 새글 c린이 19-01-22 13
질문 master님 스테핑 모터 3개 제어 관련 문의드립니다. 이미지새글첨부파일 원스타 19-01-22 21
답변 답변글 답변 : master님 스테핑 모터 3개 제어 관련 문의드립니다. 댓글[4] 새글 master 19-01-22 12
답변 답변글 답변 : 답변 : master님 스테핑 모터 3개 제어 관련 문의드립니다. 새글 원스타 19-01-22 8
답변 답변글 답변 : 답변 : 답변 : master님 스테핑 모터 3개 제어 관련 문의드립니다. 댓글[1] 새글 master 19-01-22 11
질문 아두이노 스케치 반복문 질문 master 19-01-20 16
질문 스위치 회로 댓글[2] 이미지 동지 19-01-19 26
질문 LCD 회로가 바뀌었는데 이미지첨부파일 Lami 19-01-19 21
답변 답변글 답변 : LCD 회로가 바뀌었는데 master 19-01-20 14
질문 C언어 댓글[4] c린이 19-01-18 32
질문 아두이노 하나로 2개의 센서 데이터 받기 질문 master 19-01-18 17
질문 ATmega128에서 TWI(I2C)에 대한 코딩 질문입니다!! 댓글[2] 이미지첨부파일 질문Y 19-01-15 36
질문 아두이노 소프트웨어 시리얼 질문 댓글[2] 이미지첨부파일 hktsakura 19-01-15 28
답변 답변글 답변 : 아두이노 소프트웨어 시리얼 질문 댓글[5] 이미지 master 19-01-15 35
답변 답변글 답변 : 답변 : 아두이노 소프트웨어 시리얼 질문 댓글[4] master 19-01-15 32
답변 답변글 답변 : 답변 : 답변 : 아두이노 소프트웨어 시리얼 질문 댓글[3] master 19-01-16 28
질문 아두이노 적외선센서 2개를 이용해서 출입인원 카운팅을 하려고 합니다. 배우러왔습니다 19-01-14 25
답변 답변글 답변 : 아두이노 적외선센서 2개를 이용해서 출입인원 카운팅을 하려고 합니다. 댓글[1] master 19-01-15 19
답변 답변글 답변 : 답변 : 아두이노 적외선센서 2개를 이용해서 출입인원 카운팅을 하려고 합니다. 댓글[1] 배우러왔습니다 19-01-15 12
2019년 1월
