질문게시판 > 답변 : 질문드립니다.
TODAY1,087 TOTAL2,162,928
BASIC4MCU | 질문게시판 | 답변 : 질문드립니다.
작성자 master 작성일2019-06-14 07:04 조회3,567회 댓글0건
// DateTime : 2019-06-14 오전 7:02:49
#include <mega128.h>
#include <delay.h>
#include <stdio.h>
#include "lcd.h"
#define Do  1908
#define Re  1700
#define Mi  1515
#define Fa  1432
#define Sol 1275
#define La  1136
#define Si  1012
bit flag=0;
interrupt [TIM3_COMPAvoid timer3_compa_isr(void){ // 1sec
  static char ss0,mm=0,hh=12;
  static char as=10,am=0,ah=11;
  char str[21];
  if(++ss>=60){ ss=0;
    if(++mm>=60){ mm=0if(++hh>=24)hh=0; }
  if(hh<=12){ sprintf(str," AM %02d:%02d:%02d ",hh   ,mm,ss); }
  else      { sprintf(str," PM %02d:%02d:%02d ",hh-12,mm,ss); }
  LCD_Pos(1,0); LCD_Str(str);
  if(hh==ah&&mm==am&&ss==ad){ flag=1; }
void main(void){
  int  alarm[]={Do,Re,Mi};
  int  i,melody;
  LCD_Init();
  LCD_Pos(0,0); LCD_Str("  [ Time ] ");
  TCCR3B=0x0COCR3AH=62499>>8OCR3AL=62499&0xFFETIMSK=0x10//1sec
  SREG=0x80;
    if(flag){ flag=0; // Buzzer(melody[i]);
      for(i=0i<3i++){
        PORTG|=1<<PORTG4;    delay_ms(100);
        PORTG&=~(1<<PORTG4); delay_ms(100);
https://www.basic4mcu.com/bbs/board.php?bo_table=gesiyo9&wr_id=138
멜로디 예제 참고하세요
이해가 잘 안되면 게시판에 멜로디 출력에 관한 글이 여러개 있으니 읽어보세요
// DateTime : 2019-06-14 오전 7:11:50
#include <delay.h>
#include <stdio.h>
#include "lcd.h"
// pitch
#define Do   0
#define DoS  1
#define Re   2
#define ReS  3
#define Mi   4
#define Fa   5
#define FaS  6
#define Sol  7
#define SolS 8
#define La   9
#define LaS  10
#define Ti   11
unsigned int ocr1a[7][12]={
    30577,28860,27240,25711,24268,22906,21620,20407,19261,18180,17160,16197,
    15288,14429,13619,12855,12133,11452,10809,10203963090898579,64791,
    61155,57722,54482,51424,48538,45814,43242,40815,38524,36362,34321,32395,
    15288,14429,13619,12855,12133,11452,10809,102039630908985798098,
     764372146809642760665725540451014814454442894048,
     360634043213303228622701255024062271214420231910
// , 1802, 1701, 1606, 1515, 1430
void sound(char octavechar pitch){
    TCCR1B=8
    if(octave>6)octave=6;
    if(pitch>11)pitch=11;
    TCCR1B&=~7if((octave*12+pitch)<23)TCCR1B|=2else TCCR1B|=1;
    OCR1A=ocr1a[octave][pitch];
bit flag=0;
  char str[21];
  if(++ss>=60){ ss=0;
void main(void){
  int  i;
  DDRB=0x20;  //포트 B.5 펄스(멜로디) 출력
  LCD_Init();
  TCCR1A=0x40TCCR1B=8TCCR1C=0x80OCR1A=0;
  SREG=0x80;
    if(flag){ flag=0;
      for(i=0;i<3;i++){ // 3회반복
        sound(4,Do); delay_ms500);
        sound(4,Re); delay_ms500);
        sound(4,Mi); delay_ms500);
        TCCR1B=0;    delay_ms(2000); // 무음
PB5로 출력한다면 이렇게하면 되겠습니다.
2010.11.20.
약 9년 전에 멜로디 예제를 만들었습니다.
많은 사람들이 제 소스를 참고하고, 아두이노 소스를 참고해서 새로운 코드를 작성하고 있으나
더 나아진 것도 있지만 나아지지 않은채로 제 소스를 조금 변형하기만 한 것도 있습니다.
타이머의 동작원리를 이해한다면 대단한 것은 아닙니다.
서보모터와 초음파센서 경우에도 타이머를 사용해서 예제를 만들었는데
제 소스를 보고 공부한 후 변형해서 많이 만듭니다.
문제는...제가 만든 소스보다 더 복잡한 것이 있습니다.
남의 소스와 출처를 올리기엔 쪽팔리는지...
어차피 내 소스를 보고 공부했다면 출처를 올리는 것이 처음 소스를 만들어준 사람에 대한 예의일텐데 말이죠...
조회수 3,567
공지 사이트 이용 안내댓글[24] master 17-10-29 29641
질문 아트메가 128 을 이용해서 블루투스 + 적외선 센서 코딩 중 물어볼게있습니다!! 새글 noster 19:32 12
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 새글 블루툿 10:51 20
답변 답변글 답변 : 아두이노 블루투스 통신 관련 질문 있습니다!! 새글 master 11:05 15
질문 아두이노 블루투스 통신댓글[1] 새글 블루툿 22-05-20 22
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[3] 이미지첨부파일 보겐을운용 22-05-19 185
질문 온도센서로 서보모터 제어 코딩댓글[1] 진수네1조 22-05-18 67
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 114
