질문게시판 > { }가 자꾸 맞지가 않아요 ㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠ
TODAY1,251 TOTAL2,174,643
BASIC4MCU | 질문게시판 | { }가 자꾸 맞지가 않아요 ㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠ
작성자 4564856 작성일2019-06-14 15:54 조회3,248회 댓글0건
else 쪽에 자꾸만 오류가 뜨는데 왜 그런건지 잘 모르겠어요ㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠ 혹시 알려주실 수 있으신가요ㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠ
//initializing and declaring led rows
  int column[3]={8,12,11};
//initializing and declaring led layers
unsigned int count = 0;
int latchPin = 8; //12
int clockPin = 10; //11
int dataPin = 11; //14
int layer1 = 2;
int layer2 = 3;
int layer3 = 4;
int layer4 = 5;
int trig = 13;
int echo = 9;
int piezo = 7;
int touch = 6;
byte data[] = {
            0b11111111, 0b11111111,
            0b10000000, 0b00000000,
            0b11000000, 0b00000000,
            0b11100000, 0b00000000,
            0b11110000, 0b00000000,
            0b11111000, 0b00000000,
            0b11111100, 0b00000000,
            0b11111110, 0b00000000,
            0b11111111, 0b00000000,
            0b11111111, 0b10000000,
            0b11111111, 0b11000000,
            0b11111111, 0b11100000,
            0b11111111, 0b11110000,
            0b11111111, 0b11111000,
            0b11111111, 0b11111100,
            0b11111111, 0b11111110,
void _595_out1(){
  digitalWrite(layer1 , 1);
  digitalWrite(layer2 , 1);
  digitalWrite(layer3 , 1);
  digitalWrite(layer4 , 1);
  digitalWrite(latchPin, LOW);
  shiftOut(dataPin, clockPin, MSBFIRST, data[0]);
  shiftOut(dataPin, clockPin, MSBFIRST, data[1]);
  digitalWrite(latchPin, HIGH);
  //digitalWrite(latchPin, HIGH);
  randomSeed(analogRead(10));
 pinMode(latchPin, OUTPUT);
 pinMode(clockPin, OUTPUT);
 pinMode(dataPin, OUTPUT);
  pinMode(layer1, OUTPUT);
  pinMode(layer2, OUTPUT);
  pinMode(layer3, OUTPUT);
  pinMode(layer4, OUTPUT);
  pinMode(piezo, OUTPUT);
 pinMode(trig, OUTPUT);
 pinMode(echo, INPUT);
  pinMode(touch, INPUT);
  digitalWrite(trig, LOW);
  digitalWrite(echo, LOW);
  delayMicroseconds(2);
  digitalWrite(trig, HIGH);
  delayMicroseconds(10);
  unsigned long duration = pulseIn(echo, HIGH);
float distance = duration  * 17 / 1000;
 int touchValue = digitalRead(touch);
 Serial.println(touchValue);
    Serial.print(distance);
    Serial.println("cm");
   delay(5);
 if (0 < distance < 200) {
   digitalWrite(layer1, HIGH);
   digitalWrite(layer2, HIGH);
   digitalWrite(layer3, HIGH);
   digitalWrite(layer4, HIGH);
    digitalWrite(latchPin,LOW);
    shiftOut(dataPin,clockPin,MSBFIRST,255);
    shiftOut(dataPin,clockPin,LSBFIRST,255);
    digitalWrite(latchPin,HIGH);
    tone(piezo, 262);
  if (touchValue == HIGH)
     digitalWrite(layer1, LOW);
   digitalWrite(layer2, LOW);
   digitalWrite(layer3, LOW);
   digitalWrite(layer4, LOW);
   shiftOut(dataPin,clockPin,MSBFIRST,0);
    shiftOut(dataPin,clockPin,LSBFIRST,0);
   noTone(piezo);
   count = 1;
  else if ( distance == 0 || distance < 150)
    digitalWrite(layer1,LOW);
   shiftOut(dataPin,clockPin,MSBFIRST,data[1]);
    shiftOut(dataPin,clockPin,LSBFIRST,data[1]);
   noTone(piezo);
 else {
   digitalWrite(layer1,HIGH);
   delay (50);
  delay (50);
   delay (50);
  delay (50);
   delay (50);
  delay (50);
   delay (50);
  delay (50);
    shiftOut(dataPin,clockPin,MSBFIRST,data[0]);
  analogWrite(piezo, LOW);
조회수 3,248
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 286
