질문게시판 > 답변 : { }가 자꾸 맞지가 않아요 ㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠ
TODAY234 TOTAL1,076,357
BASIC4MCU | 질문게시판 | 답변 : { }가 자꾸 맞지가 않아요 ㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠ
작성자 master 작성일2019-06-14 16:18 조회548회 댓글0건
// DateTime : 2019-06-14 오후 4:12:32
int column[3]={8,12,11};               //initializing and declaring led rows
int latchPin=8,clockPin=10,dataPin=11//initializing and declaring led layers
int layer1=2,layer2=3,layer3=4,layer4=5;
int trig=13,echo=9;
int piezo=7,touch=6;
byte data[]={
  0b11111111,0b11111111,
  0b10000000,0b00000000,
  0b11000000,0b00000000,
  0b11100000,0b00000000,
  0b11110000,0b00000000,
  0b11111000,0b00000000,
  0b11111100,0b00000000,
  0b11111110,0b00000000,
  0b11111111,0b00000000,
  0b11111111,0b10000000,
  0b11111111,0b11000000,
  0b11111111,0b11100000,
  0b11111111,0b11110000,
  0b11111111,0b11111000,
  0b11111111,0b11111100,
  0b11111111,0b11111110,
unsigned int count=0;
void _595_out1(){
  digitalWrite(layer1,1); digitalWrite(layer2,1); digitalWrite(layer3,1); digitalWrite(layer4,1);
  digitalWrite(latchPin,0); shiftOut(dataPin,clockPin,MSBFIRST,data[0]); shiftOut(dataPin,clockPin,MSBFIRST,data[1]); digitalWrite(latchPin,1);
  pinMode(latchPin,OUTPUT); pinMode(clockPin,OUTPUT); pinMode(dataPin,OUTPUT);
  pinMode(layer1,OUTPUT);   pinMode(layer2,OUTPUT);   pinMode(layer3,OUTPUT); pinMode(layer4,OUTPUT);
  pinMode(piezo,OUTPUT);    pinMode(touch,INPUT);
  pinMode(trig,OUTPUT);     pinMode(echo,INPUT);
  randomSeed(analogRead(10));
  digitalWrite(trig,1); delayMicroseconds(10); digitalWrite(trig,0);
  unsigned long duration=pulseIn(echo,1);
  float distance=duration*17/1000;
  int touchValue=digitalRead(touch);
  Serial.println(touchValue); Serial.print(distance); Serial.println("cm"); delay(5);
  if(0<distance<200){
    digitalWrite(latchPin,0); shiftOut(dataPin,clockPin,MSBFIRST,255); shiftOut(dataPin,clockPin,LSBFIRST,255); digitalWrite(latchPin,1);
    tone(piezo,262);
    if(touchValue==1){
      digitalWrite(layer1,0); digitalWrite(layer2,0); digitalWrite(layer3,0); digitalWrite(layer4,0);
      digitalWrite(latchPin,0); shiftOut(dataPin,clockPin,MSBFIRST,0); shiftOut(dataPin,clockPin,LSBFIRST,0); digitalWrite(latchPin,1);
      noTone(piezo);
      count=1;
    else if(distance==0||distance<150){
      digitalWrite(latchPin,0); shiftOut(dataPin,clockPin,MSBFIRST,data[1]);  shiftOut(dataPin,clockPin,LSBFIRST,data[1]);  digitalWrite(latchPin,1);
      noTone(piezo);
      digitalWrite(layer1,1); delay(50);
      digitalWrite(layer2,1); delay(50);
      digitalWrite(layer3,1); delay(50);
      digitalWrite(layer4,1); delay(50);
      digitalWrite(layer1,0); delay(50);
      digitalWrite(layer2,0); delay(50);
      digitalWrite(layer3,0); delay(50);
      digitalWrite(layer4,0); delay(50);
      analogWrite(piezo,0);
조회수 548
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 1672
공지 사이트 이용 안내댓글[11] master 17-10-29 11132
공지 [무료 공개] 소스코드 하이라이트 v2.0 beta [2013.02.07]댓글[1] 이미지첨부파일 master 18-01-23 4190
질문 avr 미세먼지센서에 관련하여 질문 있습니다!! 새글 jhjh 20-05-28 6
질문 아두이노 질문입니다!댓글[1] 새글 아누이도 20-05-28 8
질문 아두캠 사진촬영댓글[1] 새글 던질까 20-05-28 11
질문 atmega 128 을 이용한 UART 통신 질문 있습니다! 이미지새글첨부파일 옥수수깡 20-05-28 8
답변 답변글 답변 : atmega 128 을 이용한 UART 통신 질문 있습니다! 새글 master 20-05-28 7
질문 아두이노 실행 반복/중단 문제입니다댓글[1] 새글 KSJ126 20-05-28 8
질문 아두이노 수정 부탁드려요댓글[1] 새글 알둘이놀 20-05-28 13
질문 안녕하세요.. 아두이노 완전초짜질문있습니다.댓글[2] 이미지새글 g대학 20-05-28 13
질문 아두이노 관련 질문입니다.댓글[1] 이미지새글 아누이도 20-05-28 15
질문 초음파 2개 제어해서 거리에 따른 LED 불 켜기댓글[1] 새글 전과자14학번 20-05-28 15
질문 esp32 microptyhon으로 가변저항기와 서보모터 새글 하잇 20-05-28 12
답변 답변글 답변 : esp32 microptyhon으로 가변저항기와 서보모터댓글[1] 새글 master 20-05-28 7
질문 코드비전 코드좀 봐주세요댓글[1] 새글 하미레스 20-05-28 29
답변 답변글 답변 : 코드비전 코드좀 봐주세요댓글[2] 새글 master 20-05-28 24
질문 atmega128과 앱인벤터, 블루투스를 이용한 데이터 수신댓글[1] 새글 jiseok 20-05-27 22
질문 동작감시센서 전구에 대한 질문 입니다댓글[2] 새글 골름 20-05-27 17
질문 아두이노 dc모터와 서보모터 동시 제어 관련댓글[2] 새글첨부파일 김민우요 20-05-27 38
질문 워터펌프 블루투스 제어에서 ⸮ 가 시리얼모니터에 무한으로 출력됩니다..댓글[4] 이미지새글첨부파일 요승 20-05-27 26
질문 초음파 2개 제어해서 LED 점등 질문댓글[3] 새글 전과자14학번 20-05-27 44
질문 8051 어셈블리어 질문 좀 드리겠습니다.댓글[1] 이미지새글첨부파일 XGXG 20-05-27 28
질문 회로도 질문입니다댓글[3] 이미지새글첨부파일 포도좋아 20-05-27 37
질문 AVR 재 질문댓글[1] 새글 전과자14학번 20-05-27 17
질문 로드셀(Load cell) 장력 제어 설계에 대한 질문드립니다.댓글[1] 태원 20-05-27 25
질문 ssd1309댓글[1] 던질까 20-05-27 14
질문 Atmega128P BLDC 모터관련 질문좀할게요(2)댓글[2] 차니 20-05-27 27
질문 HC-SR501 센서 사용댓글[1] woody 20-05-26 13
질문 아두이노 인터럽트 기능을 이용해서 스위치를 on-off할때마다 모터 속도를 조절을댓글[1] 옹스 20-05-26 32
