질문게시판 > 아두이노 레오나르도 knock 예제 질문
TODAY1,260 TOTAL2,174,652
BASIC4MCU | 질문게시판 | 아두이노 레오나르도 knock 예제 질문
작성자 master 작성일2019-06-15 11:04 조회4,312회 댓글0건
첨부 이미지
첨부 이미지
위 사진은 knock 예제를 아두이노 레오나르도에 제가 꽂은거고
밑 사진은 아두이노 knock 예제 영상입니다.
그런데 똑같이 꽂았는데 도무지 작동을 하지 않네요...
시리얼 모니터 보면 가만히 있어도 knock! 이라고 계속 뜨고
센서값 보여주게끔 바꿔도 0으로만 계속 뜨고...
이유가 뭘까요?
아래는 예제 코드입니다. (각주 포함)
  Knock Sensor
  This sketch reads a piezo element to detect a knocking sound.
  It reads an analog pin and compares the result to a set threshold.
  If the result is greater than the threshold, it writes "knock" to the serial
  port, and toggles the LED on pin 13.
  The circuit:
- positive connection of the piezo attached to analog in 0
- negative connection of the piezo attached to ground
- 1 megohm resistor attached from analog in 0 to ground
  created 25 Mar 2007
  by David Cuartielles <http://www.0j0.org>;
  modified 30 Aug 2011
  by Tom Igoe
  This example code is in the public domain.
// these constants won't change:
const int ledPin = 13;      // LED connected to digital pin 13
const int knockSensor = A0; // the piezo is connected to analog pin 0
const int threshold = 100;  // threshold value to decide when the detected sound is a knock or not
// these variables will change:
int sensorReading = 0;      // variable to store the value read from the sensor pin
int ledState = LOW;         // variable used to store the last LED status, to toggle the light
  pinMode(ledPin, OUTPUT); // declare the ledPin as as OUTPUT
  Serial.begin(9600);       // use the serial port
  // read the sensor and store it in the variable sensorReading:
  sensorReading = analogRead(knockSensor);
  // if the sensor reading is greater than the threshold:
  if (sensorReading >= threshold) {
    // toggle the status of the ledPin:
    ledState = !ledState;
    // update the LED pin itself:
    digitalWrite(ledPin, ledState);
    // send the string "Knock!" back to the computer, followed by newline
    Serial.println("Knock!");
  delay(100);  // delay to avoid overloading the serial port buffer
// DateTime : 2018-10-16 오전 9:21:57
int ledPin=13,knockSensor=A0;
int threshold=100;
int val;
int ledState=0,flag=0;
  pinMode(ledPin,OUTPUT);
  val=analogRead(knockSensor);
  if(val>=threshold){
    if(flag==0){ flag=1;
      Serial.print("val:"); Serial.println(val);
      ledState=!ledStatedigitalWrite(ledPin,ledState);
  elseflag=0; }
"Knock!"이라고 뜬 것만으로도 검출이 된겁니다.
시리얼모니터에 한 번만 출력하도록 수정했으니 이 코드로 돌려보세요
입력을 하지 않았는데도 출력된다면
값이 얼마나 들어오는지 체크해서
가장 높은 값보다 더 큰 값으로 아래 설정값을 변경하세요
int threshold=100;
1. 입력을 하지 않았을 때에 가장 큰 값과
2. 입력을 했을 때의 가장 작은값
위 두 개의 중간 값으로 threshold를 정하면 됩니다.
해결하였습니다. UNO기준으론 모두 GND에 꽂힌거였는데 제가 한쪽은 GND 한쪽은 5V에 꽂아서 그런거였네요.
조회수 4,312
질문 서보모터 제어에 관하여 궁금합니다댓글[3] 이미지첨부파일 오소로롯 22-05-24 66
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 286
