질문게시판 > 답변 : 8051 초보자질문입니다
TODAY400 TOTAL2,169,350
BASIC4MCU | 질문게시판 | 답변 : 8051 초보자질문입니다
작성자 master 작성일2019-06-15 16:53 조회3,085회 댓글0건
// DateTime : 2019-06-15 오후 4:41:48
#include <io51.h>
#define L_PPI_A  *((unsigned char*)0x1c008)
#define L_PPI_B  *((unsigned char*)0x1c009)
#define L_PPI_C  *((unsigned char*)0x1c00a)
#define L_PPI_CR *((unsigned char*)0x1c00b)
#define D_PPI_A  *((unsigned char*)0x1c014)
#define D_PPI_B  *((unsigned char*)0x1c015)
#define D_PPI_C  *((unsigned char*)0x1c016)
#define D_PPI_CR *((unsigned char*)0x1c017)
#define R_PPI_A  *((unsigned char*)0x1c01c)
#define R_PPI_B  *((unsigned char*)0x1c01d)
#define R_PPI_C  *((unsigned char*)0x1c01e)
#define R_PPI_CR *((unsigned char*)0x1c01f)
#define TO_L_SHIFT 0x18
bit led1=P1.0;
bit led2=P1.1;
bit led3=P1.2;
bit led4=P1.3;
bit SW1=P1.4;
bit SW2=P1.5;
bit SW3=P1.6;
bit SW4=P1.7;
void delay(int i){ while(i--); }
void busy_flag_check(void){
  data unsigned char ir_value;
  L_PPI_CR=0x92L_PPI_C=0xf3;
  doL_PPI_C=0xf6ir_value=L_PPI_BL_PPI_C=0xf2; } while(ir_value&0x80);
  L_PPI_CR=0x90L_PPI_C=0xf3;
void msg_cmd_write(unsigned char msg_cmd){ busy_flag_check(); L_PPI_C=0xf4L_PPI_B=msg_cmdL_PPI_C=0xf0L_PPI_C=0xf3; }
void msg_char_display(char write_char){ busy_flag_check(); L_PPI_C=0xf5L_PPI_B=write_charL_PPI_C=0xf0L_PPI_C=0xf3; }
void msg_string_display(char*s){
  while(*s){ msg_char_display(*s++); delay(500); }
void d_f(unsigned char pb_font){
  int k;
  for(k=0k<8k++){ D_PPI_A=0x00D_PPI_B=pb_fontD_PPI_C=0delay(10000); D_PPI_A=0xffD_PPI_C=0xff; }
void d_e(unsigned char pa_font){
  int k;
  for(k=0k<8k++){ D_PPI_A=pa_fontD_PPI_B=0x00D_PPI_C=0delay(10000); D_PPI_B=0xffD_PPI_C=0xff; }
void b_g(unsigned char pb_font){
  int k,b=0xf3;
  for(k=0k<8k++){ D_PPI_A=0x00D_PPI_B=pb_fontD_PPI_C=0delay(12500); D_PPI_A=0xffb=(b<<0x01); D_PPI_C=0xff; }
void p_c(unsigned char pc_ext){ R_PPI_B=0xf0delay(10000); }
void p_e(unsigned char pe_ext){ R_PPI_B=0x0fdelay(10000); }
int lcd_r(unsigned char*l_r){ int k=0msg_cmd_write(0x80); msg_string_display("Riding"); delay(10000); }
int lcd_p(unsigned char*l_p){
  int k=0;
  msg_cmd_write(0x80); msg_string_display("Please");
  msg_cmd_write(0xc0); msg_string_display("Try Again"); delay(10000);
void main(void){
  int k=0;
  R_PPI_CR=0x80D_PPI_CR=0x80b_g(0xff);
    if(SW1==1){
      led3=0d_f(0xff); R_PPI_B=0xf0;
      if(led1==1){ msg_cmd_write(0x80); msg_string_display("Riding"); }
    else if(SW2==1){
      led1=0d_e(0xff); R_PPI_B=0x0f;
      if(led3==1){
      P1=0xffR_PPI_B=0xffSW1=0xffSW2=0xffled1=1led2=1led3=1msg_cmd_write(0x01);
버스교통카드단말기를 만들려고 합니다.
현재 딥스위치 1 동작을 함과 동시에
교통 카드가 태그되었다는걸 표현하였습니다.
LED Green lamp 점등
Dot matrix에 Green lamp 점등
릴레이에 Green lamp 점등
lcd 모니터에 Riding 표시
딥스위치 2 동작을 함과 동시에
LED Red lamp 점등
Dot matrix에 Red lamp 점등
릴레이에 Red lamp 점등
lcd 모니터에 Please try agin 표시를 하였습니다.
현재 인터럽트부분 메인문을 작성을 하지 못하는 상태입니다.
제가 하고 싶은 동작은
먼저 딥스위치1번이 동작되어있는 상태에서 아무 현상도 나타나지 않습니다.
이때 인터럽트를 누르면 위의 딥스위치 1 동작현상이 나타나고
딥스위치2번이 동작되어있는 상태에 아무 현상도 나타나지 않는 상태에서
인터럽트를 누르면 딥스위치  2 동작현상이 나타나고
다시 인터럽트를 누르면 딥스위치 1 동작현상이 나타나게 하고싶습니다.
인터럽트 설정 및 사용법은 서적이나 웹검색으로 공부하시고요
질문 내용을 요약하면
"딥스위치는 동작모드인데
딥스위치를 변경 하더라도 바로 모드가 변경되는 것이 아니고
인터럽트 누를 때에 딥스위치를 읽어서 딥스위치 모드대로 동작한다. " 가 맞겠죠?
// DateTime : 2019-06-15 오후 4:48:29
char mode=0// 전역변수 추가
외부인터럽트함수(){
  if     (SW1==1)mode=1;
  else if(SW2==1)mode=2;
void main(void){
  int k=0;
  // 외부인터럽트 설정 추가
    if(mode==0){
    if(mode==1){
    if(mode==2){
      if(led3==1){
mode 변수를 추가했습니다.
조회수 3,085
공지 사이트 이용 안내댓글[24] master 17-10-29 29743
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 새글 졸작부수다 22-05-23 111
질문 초음파+스텝모터 도꺼비 22-05-22 23
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 25
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 50
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 30
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 36
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 35
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지첨부파일 오소로롯 22-05-21 51
질문 아두이노 에러질문댓글[1] 이미지첨부파일 리니어 22-05-21 45
질문 아두이노 DRV2605 헵틱 모터 드라이버댓글[4] gano 22-05-21 51
