질문게시판 > 답변 : 아두이노 코딩해석부탁드립니다!!
TODAY2,140 TOTAL2,173,339
BASIC4MCU | 질문게시판 | 답변 : 아두이노 코딩해석부탁드립니다!!
작성자 master 작성일2019-07-08 19:03 조회3,905회 댓글0건
#include <SoftwareSerial.h>
#include <Adafruit_Fingerprint.h>
#include <Servo.h>
SoftwareSerial mySerial(2,3);
LiquidCrystal_I2C lcd(0x27,16,2);
Adafruit_Fingerprint finger=Adafruit_Fingerprint(&mySerial);
Servo myservo;
  lcd.init(); lcd.clear(); lcd.backlight(); delay(500);
  myservo.attach(10); myservo.write(0);     delay(1000);
  pinMode(13,OUTPUT); //부저
  Serial.begin(9600); while(!Serial); delay(100); Serial.println("\n\nAdafruit finger detect test");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if(finger.verifyPassword()){ Serial.println("Found fingerprint sensor!"); }
  else                       { Serial.println("Did not find fingerprint sensor:("); while(1); }
  finger.getTemplateCount();
  Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
  Serial.println("Waiting for valid finger...");
  lcd.clear(); lcd.setCursor(0,0); lcd.print("Press finger"); delay(500);
  if(finger.fingerID==2){
    myservo.write(90); delay(1000); // OPENING
    tone(13,261,255);  delay(200);
    tone(13,330,255);  delay(200);
    tone(13,392,255);  delay(200);
    tone(13,523,255);  delay(200);
    lcd.clear(); lcd.setCursor(0,0); lcd.print("finger matched"); delay(1000);
    lcd.clear(); lcd.setCursor(0,0); lcd.print("Lock off");       delay(1000);
    finger.fingerID=5;
  else if(finger.fingerID==5){
    lcd.clear(); lcd.setCursor(0,0); lcd.print("Safe Opened"); delay(1000);
  else if(finger.fingerID==4){
    myservo.write(0); delay(2000); // CLOSING
    lcd.clear(); lcd.setCursor(0,0); lcd.print("Lock on"); delay(2000);
    finger.fingerID=6;
  else if(finger.fingerID==6){
    lcd.clear(); lcd.setCursor(0,0); lcd.print("Safe Closed"); delay(1000);
    lcd.clear();
    lcd.setCursor(0,0); lcd.print("Finger not found");
    lcd.setCursor(0,1); lcd.print("Press again");
    delay(2000);
  getFingerprintIDez();
  delay(50); //don't ned to run this at full speed.
uint8_t getFingerprintID(){
  uint8_t p=finger.getImage();
  switch(p){
    case FINGERPRINT_OK:               Serial.println("Image taken");         break;
    case FINGERPRINT_NOFINGER:         Serial.println("No finger detected");  return p;
    case FINGERPRINT_PACKETRECIEVEERRSerial.println("Communication error"); return p;
    case FINGERPRINT_IMAGEFAIL:        Serial.println("Imaging error");       return p;
    default:                           Serial.println("Unknown error");       return p;
  // OK success!
  p=finger.image2Tz();
  switch(p){
    case FINGERPRINT_OK:               Serial.println("Image converted");                     break;
    case FINGERPRINT_IMAGEMESS:        Serial.println("Image too messy");                     return p;
    case FINGERPRINT_FEATUREFAIL:      Serial.println("Could not find fingerprint features"); return p;
    case FINGERPRINT_INVALIDIMAGE:     Serial.println("Could not find fingerprint features"); return p;
  // OK converted!
  p=finger.fingerFastSearch();
  if     (p==FINGERPRINT_OK              ){ Serial.println("Found a print match!");           }
  else if(p==FINGERPRINT_PACKETRECIEVEERR){ Serial.println("Communication error");  return p; }
  else if(p==FINGERPRINT_NOTFOUND        ){ Serial.println("Did not find a match"); return p; }
  else                                    { Serial.println("Unknown error");        return p; }
  // found a match!
  Serial.print("Found ID#");            Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
  return finger.fingerID;
// returns-1 if failed,otherwise returns ID#
int getFingerprintIDez(){
  uint8_t p;
  p=finger.getImage();         if(p!=FINGERPRINT_OK)return-1;
  p=finger.image2Tz();         if(p!=FINGERPRINT_OK)return-1;
  p=finger.fingerFastSearch(); if(p!=FINGERPRINT_OK)return-1;
  // found a match!
들여쓰기를 하면 분석하기 더 좋을겁니다.
직접 주석을 작성해보세요
조회수 3,905
공지 사이트 이용 안내댓글[24] master 17-10-29 29810
질문 적외선 거리 센서로 블루투스 알람 설정 코딩... 새글 ededed 22:56 3
질문 아두이노 api 질문댓글[1] 새글첨부파일 리니어 19:19 16
질문 atmega128 키패드 입력 오류에 대하여 질문 있습니다.댓글[2] 새글 마프하나 16:07 38
질문 초음파센싱을 통한 리니어벨트 (스텝모터사용) 조건문댓글[1] 새글 아두이노대학 15:01 17
질문 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 새글 아트메가넘어려워 14:10 20
답변 답변글 답변 : 아트메가128/ srf05 초음파센서를 이용한 타이머 인터럽트 질문입니다 새글 master 14:56 16
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. 새글 aasdw 06:28 34
답변 답변글 답변 : atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데..댓글[1] 새글 master 14:09 24
답변 답변글 답변 : Atmega128 블루투스 오류 질문 새글 master 13:51 20
답변 답변글 답변 : 아두이노 간단한 프로그램 새글 master 12:06 15
질문 atmega128 타이머 작성시 키패트 입력으로 인터럽트 사용에 대하여 질문이 있습니다.댓글[1] 이미지새글 마프하나 22-05-25 37
질문 로드셀 무게 센서 질문드립니다.댓글[2] 새글 제비고기 22-05-25 37
질문 ADC,uart DMA댓글[1] 이미지새글첨부파일 hiㅡO3O 22-05-25 26
질문 아두이노 스텝모터 리미트 문의드립니다.댓글[4] 이미지첨부파일 스트렌져 22-05-24 40
질문 atmega128 GPS,블루투스 질문드립니다.댓글[1] 코딩초보1 22-05-24 37
질문 서보모터 제어에 관하여 궁금합니다댓글[3] 이미지첨부파일 오소로롯 22-05-24 58
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[8] 이미지 마프하나 22-05-23 78
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 240
답변 답변글 답변 : 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 … master 22-05-24 32
질문 보드레이트 질문댓글[1] 죠르디 22-05-23 34
질문 atmega 128 블루투스 질문 입니다댓글[1] yhj2644 22-05-23 56
질문 아트메가 공부중에 질문있습니다..댓글[1] suid82 22-05-23 42
질문 아두이노의 지속 시간에 대해 질문합니다. merry 22-05-23 56
