질문게시판 > 아두이노로 빛 파장 계산하기
TODAY808 TOTAL2,172,007
BASIC4MCU | 질문게시판 | 아두이노로 빛 파장 계산하기
작성자 master 작성일2019-08-07 09:28 조회4,733회 댓글0건
어떤 센서가 필요하고 코딩은 어떻게 해야하는 지 알려주세요
How to Make a "chameleon" With Arduino
More by the author:
About: You either hate me or love me. More About mindminus »
You must have seen chameleons changing colors and blending in the surroundings, in an amazing way. The way that chameleons actually do this is really molecular. If you look at the skin of a chameleon, you find that they have several layers of specialised cells called chromatophores and these are cells that can change colour. And that's where I came up with an idea of building a device that acts alike, with arduino.
Teacher Notes
Teachers! Did you use this instructable in your classroom?
Add a Teacher Note to share how you incorporated it into your lesson.
Step 1: Intro
Hardware Used
TCS3200 Color Sensor from DFRobot, $7.90
Arduino Nano from DFRobot, $22.00
Light Disc with 7 SMD RGB LED, $8.90
Breadboard, x1
Jumper Cables, a few
Here I used Arduino Nano because I want the device to be as compact as possible with a low power consumption. However, if you do not have power or sizing requirements, any other Arduino microcontroller will just do the job —— and saves money.
Step 2: Wiring
To connect the TCS3200 Color Sensor with Nano, you'll need to expand some extra ports. The wirings should follow correctly with the program, to ensure functionality. Connect the LED port of color sensor with 3.3V on Nano. See attached wiring diagram for details.
Step 3: Programming
After all wirings done, you can now go to Arduino IDE and upload the codes for your chameleon. Note: the Metro Library is needed. You can find it here and install it in advance.
Here I leave a zip file with the the code.
Step 4: Test and Enjoy!
I used different colored papers to do demo tests. Just put the colored paper beneath the color sensor, and it starts to change color accordingly! Looks a bit more like a "chameleon" now :p
The sensor data will also be affected by ambient light, so it works better in the night.
The container I used is a printed vase found on Thingiverse, I am sure you will easily find a nicer one at home or made by your self.
Enjoy.
https://www.instructables.com/id/How-to-make-a-chameleon-with-Arduino/
조회수 4,733
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 9685
공지 사이트 이용 안내댓글[24] master 17-10-29 29794
질문 atmega128에서 스위치1개는LED, 스위치 1개는 세그먼트의 동작하게 하려는데.. 새글 aasdw 06:28 22
질문 아두이노 간단한 프로그램 새글 행복지수업 22-05-25 23
질문 atmega128 타이머 작성시 키패트 입력으로 인터럽트 사용에 대하여 질문이 있습니다. 이미지새글 마프하나 22-05-25 28
질문 아두이노 스텝모터 리미트 문의드립니다.댓글[2] 이미지새글첨부파일 스트렌져 22-05-24 30
질문 atmega128 GPS,블루투스 질문드립니다.댓글[1] 새글 코딩초보1 22-05-24 32
질문 서보모터 제어에 관하여 궁금합니다댓글[3] 이미지첨부파일 오소로롯 22-05-24 49
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[8] 이미지 마프하나 22-05-23 64
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 193
답변 답변글 답변 : 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 … 새글 master 22-05-24 27
질문 atmega 128 블루투스 질문 입니다댓글[1] yhj2644 22-05-23 50
질문 아트메가 공부중에 질문있습니다..댓글[1] suid82 22-05-23 38
질문 Atmega128 UART통신 echo 반복 질문댓글[2] ming2ming 22-05-23 54
질문 아두이노의 지속 시간에 대해 질문합니다. merry 22-05-23 50
답변 답변글 답변 : 아두이노의 지속 시간에 대해 질문합니다. master 22-05-23 37
질문 초음파+스텝모터 도꺼비 22-05-22 36
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 40
질문 아두이노 인터럽트 질문있습니다.댓글[1] 띵꽁 22-05-22 50
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] master 22-05-22 47
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 70
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 49
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 48
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 54
