BASIC4MCU | 질문게시판 | 답변 : 아두이노 세븐 세그먼트 제어
작성자 master 작성일2019-08-29 21:21 조회3,028회 댓글0건
https://www.basic4mcu.com/bbs/board.php?bo_table=gac&wr_id=9816
// MCU BASIC: https://www.basic4mcu.com// DateTime : 2019-08-29 오후 9:11:02// by Ok-Hyun Park//#include <Adafruit_NeoPixel.h>#ifdef __AVR__#include <avr/power.h>#endif//#define A 3#define B 4#define C 8#define D 10#define E 9#define F 7#define G 11#define digit1 6#define digit2 5#define PIN 12#define NUMPIXELS 20#define buttonPin 2//Adafruit_NeoPixel pixels=Adafruit_NeoPixel(NUMPIXELS,PIN,NEO_GRB+NEO_KHZ800);//const int segs[7]={ A,B,C,D,E,F,G};const int numbers[10][7]={{ 1,1,1,1,1,1,0},{ 0,1,1,0,0,0,0},{ 1,1,0,1,1,0,1},{ 1,1,1,1,0,0,1},{ 0,1,1,0,0,1,1},{ 1,0,1,1,0,1,1},{ 1,0,1,1,1,1,1},{ 1,1,1,0,0,1,0},{ 1,1,1,1,1,1,1},{ 1,1,1,1,0,1,1},};const int NUMBER_OF_FIELDS=2;//int values[NUMBER_OF_FIELDS];int bookled,delayval=500,k=0,j=0,i=0;int fieldIndex=0,randomNum=0;char ch,store=0;//void setup(){Serial.begin(9600);#if defined(__AVR_ATtiny85__)if(F_CPU==16000000)clock_prescale_set(clock_div_1);#endifpixels.begin();pinMode(buttonPin,INPUT_PULLUP);for(int i=0; i<7; i++){ pinMode(segs[i],OUTPUT); }pinMode(digit1,OUTPUT); pinMode(digit2,OUTPUT);}//void loop(){if(Serial.available()){ch=Serial.read();if(store!=ch){if(store>='0'&&store<='9'){if(fieldIndex<NUMBER_OF_FIELDS){values[fieldIndex]=(values[fieldIndex]*10)+((int)store-'0');}}else if(store==','){ fieldIndex++; }else { randomNum=values[0]; bookled=values[1]; fieldIndex=0; values[0]=0; }store=ch;}}//lightnumber1(randomNum%10); delay(10);lightnumber2(randomNum/10); delay(10);//pixels.clear(); pixels.show();//if(digitalRead(buttonPin)==LOW){randomNum=0;for(j=0; j<5; j++){for(k=0; k<3; k++){pixels.setPixelColor(bookled-2+k,pixels.Color(10,10,10));}pixels.show(); delay(delayval); pixels.clear();pixels.show(); delay(delayval);}}}//void lightnumber1(int num1){digitalWrite(digit1,LOW); digitalWrite(digit2,HIGH);for(int i=0; i<7; i++){ digitalWrite(segs[i],numbers[num1][i]); }}//void lightnumber2(int num2){digitalWrite(digit1,HIGH); digitalWrite(digit2,LOW);for(int i=0; i<7; i++){ digitalWrite(segs[i],numbers[num2][i]); }}
루프문만 보면 3종류의 코드가 있습니다.
if(Serial.available()){ch=Serial.read();if(store!=ch){if(store>='0'&&store<='9'){if(fieldIndex<NUMBER_OF_FIELDS){values[fieldIndex]=(values[fieldIndex]*10)+((int)store-'0');}}else if(store==','){ fieldIndex++; }else { randomNum=values[0]; bookled=values[1]; fieldIndex=0; values[0]=0; }store=ch;}}이 부분은 시리얼 수신 데이터가 있어야하므로 평소에는 실행되지 않습니다.if(digitalRead(buttonPin)==LOW){randomNum=0;for(j=0; j<5; j++){for(k=0; k<3; k++){pixels.setPixelColor(bookled-2+k,pixels.Color(10,10,10));}pixels.show(); delay(delayval); pixels.clear();pixels.show(); delay(delayval);}}이 부분은 스위치를 눌렀을 때만 동작하므로 평소에는 실행되지 않습니다.//lightnumber1(randomNum%10); delay(10);lightnumber2(randomNum/10); delay(10);//pixels.clear(); pixels.show();중간에는 이 코드가 들어 있는데요일 자리는 10ms 딜레이라서 10ms 동안켜지지만십 자리를 출력 후 10ms 딜레이라서 10ms 동안 켜지는 것으로 생각하겠지만pixels.clear(); pixels.show();이 코드를 실행하는데에도 시간이 걸리므로 십자리 출력에는 일자리보다 더 많은 시간동안 출력 됩니다.시리얼수신이 있거나 스위치를 눌렀을 때는 훨씬 더 많은 시간동안 십자리가 표시됩니다.lightnumber1(randomNum%10); pixels.clear(); pixels.show();lightnumber2(randomNum/10); pixels.clear(); pixels.show();이런식으로 변경하면 특별한(시리얼수신 또는 스위치입력) 일이 발생하지 않을 때에 일자리와 십자리가 동일한 시간동안 켜지게 됩니다.
조회수 3,028등록된 댓글이 없습니다.
