모터 > Understanding and programming an ESC
TODAY787 TOTAL2,229,345
BASIC4MCU | 모터 | BLDC모터 | Understanding and programming an ESC
작성자 키트 작성일2017-09-05 15:13 조회2,300회 댓글0건
ESC Programming on Arduino (Hobbyking ESC)
Picture of ESC Programming on Arduino
Hello Community,
I'm going to show you, how to program and use the Hobbyking ESC. I just found a few information and tutorials, which really didn't help me very much, so i decided to program an own sketch, which is very simple to understand.
Important to know:
* ESC means Electronic Speed control
* The ESC has a 5v(not used), GND and Signal Pin like a Servo
* You control it like a Servo with  write() http://arduino.cc/de/Reference/ServoWrite
* or writeMicroseconds  http://arduino.cc/de/Reference/ServoWriteMicroseconds
In my Example i use writeMicroseconds, because it is easier to understand.
So let's go...
Remove these adsRemove these ads by Signing Up
Step 1: Getting ESC information
Picture of Getting ESC information
You really should remark the Amperevalue of your ESC. This tutorial is only tested on 20 AMP ESC :
http://www.hobbyking.com/hobbyking/store/__15202__hobby_king_20a_esc_3a_ubec.html
I can't really promise, that this is working with an other ESC but i think so, because in the english manual are 20 and 30 Amp ESC's described. In the German version is a generalisation from 10 to 120 Amp, thats why I think this could work for every ESC.
Source:
German: http://tom-620.bplaced.net/rc_modelle/zubehoer/regler/hobby_king/hk_80A_regler_deutsch.pdf
English: http://www.hobbyking.com/hobbyking/store/uploads/811103388X7478X20.pdf
Step 2: Connection to Arduino
Picture of Connection to Arduino
I tried it with an arduino uno R3. I think it's also possible with an e.g. arduino Duemilanove or Mega.
First you have to connect the ESC to you lipo or NiMH. When you have done that you connect the ESC like so:
*  Black to GND
* White/Yellow to PIN 9
Because you connected the ESC to your battery, the ESC is put under voltage. Thats why it It is important, that you DON'T connect the red wire to your 5v Port, because it could destroy your computer's USB Port.
On this picture you can see the correct connection between ESC and Arduino (Mega).
Picture source: http://1.bp.blogspot.com/-eqDaRgO5FjU/T9U3avwT2-I/AAAAAAAAALE/-8pj4qD12Q0/s1600/Figure2_2_edit.jpg
Step 3: Upload sketch
Picture of Upload sketch
Just copy and paste this Code to your IDE:
Coded by Marjan Olesch
Sketch from Insctructables.com
Open source - do what you want with this code!
#include
int value = 0; // set values you need to zero
Servo firstESC, secondESC; //Create as much as Servoobject you want. You can controll 2 or more Servos at the same time
  firstESC.attach(9);    // attached to pin 9 I just do this with 1 Servo
  Serial.begin(9600);    // start serial at 9600 baud
//First connect your ESC WITHOUT Arming. Then Open Serial and follo Instructions
  firstESC.writeMicroseconds(value);
  if(Serial.available())
    value = Serial.parseInt();    // Parse an Integer from Serial
Step 4: Understanding and programming an ESC
Picture of Understanding and programming an ESC
ESC are programable like IC's or even your Arduino. You just don't have a language to program,  but a menu made of sounds.
To come in this menu, which runs infinite btw you just have to do following Steps:
* Connect your ESC
* Configure the code (as much as ESC's you have and Pin-configuration)
* You should hear nothing, because the Arduino sends a zero
* Open your Serial Monitor and send '2000'. it means the highest Signal the ESC can receive
* You will hear the sounds which are described on the picture ( Source: Manual: http://www.hobbyking.com/hobbyking/store/uploads/811103388X7478X20.pdf)
The Hobbyking ESC's can receive a Signal between 700 and 2000 us(microseconds). 700 means throttle at lowest position and 2000 on the highest Position. If you want to know what exactly you du, when you pick a menu visit the manual.
Example:
- Write 2000 us
- Wait until D-D-D-D to chose lipo as batterytype
- When it apperas, write at the third 'D' 700 in your Serial ( short delay, thats why you have to send it at the third 'D')
- ESC will make a sound, and the Option is chosed.
I Hope i could help you with this tutorial.
Visit my Youtubechannel:   http://www.youtube.com/diiaf
http://www.instructables.com/id/ESC-Programming-on-Arduino-Hobbyking-ESC/?ALLSTEPS
조회수 2,300
모터HOME > 모터 > 전체 목록
