BASIC4MCU | 모터 | 서보모터 | ATmega128 - 53개의 서보모터 구동
작성자 키트 작성일2017-09-05 17:16 조회2,318회 댓글0건첨부파일
// pwm 배열 56(7byte*8bit)개 중에서 포트G가 5개라서 53개의 전체 포트에 PWM출력을 합니다.// PORTA : 0~7// PORTB : 8~15// PORTC : 16~23// PORTD : 24~31// PORTE : 32~39// PORTF : 40~47// PORTG : 48~52
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354 //--------------------------------------------------------// CVAVR//--------------------------------------------------------#include <mega128.h>#include <delay.h>//#define U_C unsigned char//U_C PWM[7][241]={0,}; //7*241=1687byteint count=0;//interrupt [TIM0_COMP] void timer0_comp_isr(void){ //10usec 주기if(count==0){PORTA=0xFF; PORTB=0xFF; PORTC=0xFF; PORTD=0xFF; PORTE=0xFF; PORTF=0xFF; PORTG=0xFF;}else if(count<60){}else if(count<240){PORTA=PWM[0][count]; PORTB=PWM[1][count];PORTC=PWM[2][count]; PORTD=PWM[3][count];PORTE=PWM[4][count]; PORTF=PWM[5][count];PORTG=PWM[6][count];}else if(count==240){PORTA=0; PORTB=0; PORTC=0; PORTD=0; PORTE=0; PORTF=0; PORTG=0;}if(++count>1999)count=0;}//void servo(U_C no,U_C angle){ // no:0~52 // angle: 0~180 //28mschar pos[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};char neg[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F};U_C i,index,m;SREG&=~0x80;index=no/8; m=no%8;for(i=0;i<angle;i++)PWM[index][i+60]|=pos[m]; // 0 ~ angle : highfor( ;i<= 180;i++)PWM[index][i+60]&=neg[m]; // angle~180(2400us) : lowSREG|=0x80;}//void main(void){U_C i,no;DDRA=0xFF; DDRB=0xFF; DDRC=0xFF; DDRD=0xFF; DDRE=0xFF; DDRF=0xFF; DDRG=0x1F;TCCR0=0x0A; OCR0=19; TIMSK=2; // 16000000/8/(1+19),10usSREG=0x80;while(1){for(i=0;i<180;i++){ // 600usec~2400usec까지 1도 단위로 증가for(no=0;no<53;no++)servo(no,i); delay_ms(20); // 53개 PWM값 설정}for(i=180;i>0;i--){ // 600usec~2400usec까지 1도 단위로 증가for(no=0;no<53;no++)servo(no,i); delay_ms(20); // 53개 PWM값 설정}}}cs
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657 //--------------------------------------------------------// AVRStudio//--------------------------------------------------------#define F_CPU 16000000UL // 16 MHz#include <avr/io.h>#include <avr/interrupt.h>#include <util/delay.h>//#define U_C unsigned char//volatile U_C PWM[7][241]; //7*241=1687bytevolatile int count=0;//ISR(TIMER0_COMP_vect){ //10usec 주기if(count==0){PORTA=0xFF; PORTB=0xFF; PORTC=0xFF; PORTD=0xFF; PORTE=0xFF; PORTF=0xFF; PORTG=0xFF;}else if(count<60){}else if(count<240){PORTA=PWM[0][count]; PORTB=PWM[1][count];PORTC=PWM[2][count]; PORTD=PWM[3][count];PORTE=PWM[4][count]; PORTF=PWM[5][count];PORTG=PWM[6][count];}else if(count==240){PORTA=0; PORTB=0; PORTC=0; PORTD=0; PORTE=0; PORTF=0; PORTG=0;}if(++count>1999)count=0;}//void servo(U_C no,U_C angle){ // no:0~52 // angle: 0~180 //28mschar pos[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};char neg[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F};U_C i,index,m;SREG&=~0x80;index=no/8; m=no%8;for(i=0;i<angle;i++)PWM[index][i+60]|=pos[m]; // 0 ~ angle : highfor( ;i<= 180;i++)PWM[index][i+60]&=neg[m]; // angle~180(2400us) : lowSREG|=0x80;}//int main(void){U_C i, no; int k;DDRA=0xFF; DDRB=0xFF; DDRC=0xFF; DDRD=0xFF; DDRE=0xFF; DDRF=0xFF; DDRG=0x1F;TCCR0=0x0A; OCR0=19; TIMSK=2; // 16000000/8/(1+19),10usfor(k=0;k<1687;k++)PWM[0][k]=0; //7*241=1687byteSREG=0x80;while(1){for(i=0;i<180;i++){ // 600usec~2400usec까지 1도 단위로 증가for(no=0;no<53;no++)servo(no,i); _delay_ms(20); // 53개 PWM값 설정}for(i=180;i>0;i--){ // 600usec~2400usec까지 1도 단위로 증가for(no=0;no<53;no++)servo(no,i); _delay_ms(20); // 53개 PWM값 설정}}}cs 10us 주기의 타이머가250 count 루프를 돌면10us*250= 2500us2500us 주기로 g_cnt가 0~7까지 증가하고스위치 문에서 g_cnt에 해당하는 포트를 출력합니다.2500us * 8 = 20ms2500us --- 2500us --- 2500us --- 2500us --- 2500us --- 2500us --- 2500us --- 2500usPA출력 --- PB출력 --- PC출력 --- PD출력 --- PE출력 --- PF출력 --- PG출력 --- 아무것도 안함//돌려보지 않은 예제니 문제가 있으면 덧글로 적어주세요^^
조회수 2,318등록된 댓글이 없습니다.
