통신 > SSD1306( dot matrix OLED/PLED 128x64) 아두이노 라이브러리
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 통신
I2C-IIC,TWI | SSD1306( dot matrix OLED/PLED 128x64) 아두이노 라이브러리
작성자 master 작성일18-04-26 12:17 조회2,008회 댓글0건
https://github.com/digistump/DigistumpArduino/tree/master/digistump-avr/libraries/DigisparkOLED
이 라이브러리를 c 스타일로 변경 해봤습니다.
// DateTime : 2018-04-26 오후 12:19:40
/**SSD1306xLED-Drivers for SSD1306 controlled dot matrix OLED/PLED 128x64 displays*/
#include <stdlib.h>
#include <stdint.h>
#include <avr/io.h>
#include <Arduino.h>
#include <Wire.h>
#include <util/delay.h>
#define U08  uint8_t
#define U16  uint16_t
//#define _nofont_8x16 //tBUG
#ifndef   _nofont_8x16 //tBUG
  #define FONT8X16    1
#endif
#define FONT6X8    0
#include "font6x8.h"
#ifndef _nofont_8x16 // tBUG Optional removal to save code space
  #include "font8x16.h"
#endif
#ifndef SSD1306
  #define SSD1306   0x3C // Slave address
#endif
#define start_cmd  0x00
#define start_data 0x40
// Some code based on "IIC_wtihout_ACK" by http: //www.14blog.com/archives/1358
U08 ssd1306_init[]={ // Initialization Sequence
  0xAE,     // Display OFF(sleep mode)
  0x20,0b00,// Set Memory Addressing Mode // 00=Horizontal Addressing Mode; 01=Vertical Addressing Mode; // 10=Page Addressing Mode(RESET); 11=Invalid
  0xB0,     // Set Page Start Address for Page Addressing Mode,0-7
  0xC8,     // Set COM Output Scan Direction
  0x00,     //---set low column address
  0x10,     //---set high column address
  0x40,     //--set start line address
  0x81,0x3F,// Set contrast control register
  0xA1,     // Set Segment Re-map.A0=address mapped; A1=address 127 mapped.
  0xA6,     // Set display mode.A6=Normal; A7=Inverse
  0xA8,0x3F,// Set multiplex ratio(1 to 64)
  0xA4,     // Output RAM to Display // 0xA4=Output follows RAM content; 0xA5,Output ignores RAM content
  0xD3,0x00,// Set display offset.00=no offset
  0xD5,     //--set display clock divide ratio/oscillator frequency
  0xF0,     //--set divide ratio
  0xD9,0x22,// Set pre-charge period
  0xDA,0x12,// Set com pins hardware configuration
  0xDB,     //--set vcomh
  0x20,     // 0x20,0.77xVcc
  0x8D,0x14,// Set DC-DC enable
  0xAF      // Display ON in normal mode
U08 oledFont,oledX,oledY=0;
// Program: 5248 bytes
void SSD1306_setFont(U08 font){ oledFont=font; }
void SSD1306_cmd (U08 c){ Wire.beginTransmission(SSD1306_add); Wire.write(start_cmd); Wire.write(c); Wire.endTransmission(); }
void SSD1306_data(U08 b){ if(Wire.writeAvailable()){ Wire.endTransmission(); Wire.beginTransmission(SSD1306_add); Wire.write(start_data); } Wire.write(b); }
void SSD1306_Cursor(U08 x,U08 y){ Wire.beginTransmission(SSD1306_add); Wire.write(start_cmd); Wire.write(0xb0+y); Wire.write((x>>4)|0x10); Wire.write((x&0x0f)|0x01); Wire.endTransmission(); oledX=xoledY=y; }
void SSD1306_fill(U08 f){
  U08 m,n;
  for(m=0;m<8;m++){
    SSD1306_cmd(0xb0+m); SSD1306_cmd(start_cmd); SSD1306_cmd(0x10); // page0-page1 // low column start address // high column start address
    Wire.beginTransmission(SSD1306_add); Wire.write(start_data); for(n=0;n<128;n++)SSD1306_data(f); Wire.endTransmission();
  setCursor(0,0);
void SSD1306_clear(){ fill(0); }
size_t SSD1306_wr(byte c){
  U08 i=0,ci;
  if(c=='\r')return 1;
  if(c=='\n'){
    if(oledFont==FONT6X8){ oledY++;                      } // if(oledY>7)oledY=7; // tBUG
    else                 { oledY+=2if(oledY>6)oledY=6; } // tBUG  Large Font up by two // tBUG
    setCursor(0,oledY);
    return 1;
  ci=c-32;
    if(oledX>122){ oledX=0oledY++; if(oledY>7)oledY=7setCursor(oledX,oledY); } // tBUG
    Wire.beginTransmission(SSD1306_add); Wire.write(start_data); for(i=0;i<6;i++)SSD1306_data(pgm_read_byte(&ssd1306xled_font6x8[ci*6+i])); Wire.endTransmission(); setCursor(oledX+6,oledY);
      if(oledX>120){ oledX=0oledY+=2if(oledY>6)oledY=6setCursor(oledX,oledY); } // oledY++; //tBUG Large Font up by two // tBUG
      Wire.beginTransmission(SSD1306_add); Wire.write(start_data); for(i=0;i<8;i++)Wire.write(pgm_read_byte(&ssd1306xled_font8x16[ci*16+i  ])); Wire.endTransmission(); setCursor(oledX  ,oledY+1);
      Wire.beginTransmission(SSD1306_add); Wire.write(start_data); for(i=0;i<8;i++)Wire.write(pgm_read_byte(&ssd1306xled_font8x16[ci*16+i+8])); Wire.endTransmission(); setCursor(oledX+8,oledY-1);
  #endif
  return 1;
void SSD1306_bitmap(U08 x0,U08 y0,U08 x1,U08 y1,const U08 bitmap[]){
  U16 j=0U08 y,x;
  // if(y1%8==0)y=y1/8; // else y=y1/8+1; // tBUG:: this does nothing as y is initialized below
  // THIS PARAM rule on y makes any adjustment here WRONG //usage oled.bitmap(START X IN PIXELS,START Y IN ROWS OF 8 PIXELS,END X IN PIXELS,END Y IN ROWS OF 8 PIXELS,IMAGE ARRAY);
  for(y=y0;y<y1;y++){ setCursor(x0,y); Wire.beginTransmission(SSD1306_add); Wire.write(start_data); for(x=x0;x<x1;x++)SSD1306_data(pgm_read_byte(&bitmap[j++])); Wire.endTransmission(); }
  setCursor(0,0);
void SSD1306_begin(){
  Wire.begin(); for(U08 i=0;i<sizeof(ssd1306_init);i++)SSD1306_cmd(ssd1306_init[i]); clear();
댓글 : 0
조회수 : 2,008
통신 목록
PC버전
