센서 > 코드비젼 통신테스트 소스코드 (주기 변경)
TODAY1,169 TOTAL2,267,990
BASIC4MCU | 센서 | 자이로센서 | 코드비젼 통신테스트 소스코드 (주기 변경)
작성자 키트 작성일2017-08-21 16:29 조회1,300회 댓글0건
#define mpu6050_mahonysampleFreq 61.0f // sample frequency in Hz
위 선언은 함수 실행 주기(타이머인터럽트 주기)와 관계 됩니다.
void mpu6050_mahonyUpdate(float gx, float gy, float gz, float ax, float ay, float az) {
 float norm;
 float halfvx, halfvy, halfvz;
 float halfex, halfey, halfez;
 float qa, qb, qc;
 // Compute feedback only if accelerometer measurement valid (avoids NaN in accelerometer normalisation)
 if(!((ax == 0.0f) && (ay == 0.0f) && (az == 0.0f))) {
  // Normalise accelerometer measurement
  norm = sqrt(ax * ax + ay * ay + az * az);
  ax /= norm;
  ay /= norm;
  az /= norm;
  // Estimated direction of gravity and vector perpendicular to magnetic flux
  halfvx = q1 * q3 - q0 * q2;
  halfvy = q0 * q1 + q2 * q3;
  halfvz = q0 * q0 - 0.5f + q3 * q3;
  // Error is sum of cross product between estimated and measured direction of gravity
  halfex = (ay * halfvz - az * halfvy);
  halfey = (az * halfvx - ax * halfvz);
  halfez = (ax * halfvy - ay * halfvx);
  // Compute and apply integral feedback if enabled
  if(mpu6050_mahonytwoKiDef > 0.0f) {
   integralFBx += mpu6050_mahonytwoKiDef * halfex * (1.0f / mpu6050_mahonysampleFreq); // integral error scaled by Ki
   integralFBy += mpu6050_mahonytwoKiDef * halfey * (1.0f / mpu6050_mahonysampleFreq);
   integralFBz += mpu6050_mahonytwoKiDef * halfez * (1.0f / mpu6050_mahonysampleFreq);
   gx += integralFBx; // apply integral feedback
   gy += integralFBy;
   gz += integralFBz;
  } else {
   integralFBx = 0.0f; // prevent integral windup
   integralFBy = 0.0f;
   integralFBz = 0.0f;
  // Apply proportional feedback
  gx += mpu6050_mahonytwoKpDef * halfex;
  gy += mpu6050_mahonytwoKpDef * halfey;
  gz += mpu6050_mahonytwoKpDef * halfez;
 // Integrate rate of change of quaternion
 gx *= (0.5f * (1.0f / mpu6050_mahonysampleFreq));  // pre-multiply common factors
 gy *= (0.5f * (1.0f / mpu6050_mahonysampleFreq));
 gz *= (0.5f * (1.0f / mpu6050_mahonysampleFreq));
 qa = q0;
 qb = q1;
 qc = q2;
 q0 += (-qb * gx - qc * gy - q3 * gz);
 q1 += (qa * gx + qc * gz - q3 * gy);
 q2 += (qa * gy - qb * gz + q3 * gx);
 q3 += (qa * gz + qb * gy - qc * gx);
 // Normalise quaternion
 norm = sqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3);
 q0 /= norm;
 q1 /= norm;
 q2 /= norm;
 q3 /= norm;
원래 값이 61Hz (타이머 주기 16.384ms) 였으니 색칠한 코드의 상수값을 찾아서 수정 해줘야 합니다.
// Mahony update function (for 6DOF)
void mpu6050_mahonyUpdate(float gx,float gy,float gz,float ax,float ay,float az){
    float norm,halfvx,halfvy,halfvz,halfex,halfey,halfez,qa,qb,qc;
    if(!((ax==0.0f)&&(ay==0.0f)&&(az==0.0f))){
        norm=sqrt(ax*ax+ay*ay+az*az);
        ax/=norm; ay/=norm; az/=norm;
        halfvx=q1*q3-q0*q2; halfvy=q0*q1+q2*q3; halfvz=q0*q0-0.5f+q3*q3;
        halfex=(ay*halfvz-az*halfvy); halfey=(az*halfvx-ax*halfvz); halfez=(ax*halfvy-ay*halfvx);
        integralFBx+=halfex*0.0032786885245901639344262295081967; // integral error scaled by Ki //mpu6050_mahonysampleFreq=61.0f
        integralFBy+=halfey*0.0032786885245901639344262295081967;
        integralFBz+=halfez*0.0032786885245901639344262295081967;
        gx+=integralFBx; gy+=integralFBy; gz+=integralFBz; // apply integral feedback
        gx+=halfex; gy+=halfey; gz+=halfez; // mpu6050_mahonytwoKpDef=(2.0f*0.5f)
    gx*=0.0081967213114754098360655737704918; // pre-multiply common factors  //mpu6050_mahonysampleFreq=61.0f
    gy*=0.0081967213114754098360655737704918;
    gz*=0.0081967213114754098360655737704918;
    qa=q0; qb=q1; qc=q2;
    q0+=(-qb*gx-qc*gy-q3*gz); q1+=(qa*gx+qc*gz-q3*gy); q2+=(qa*gy-qb*gz+q3*gx); q3+=(qa*gz+qb*gy-qc*gx);
    norm=sqrt(q0*q0+q1*q1+q2*q2+q3*q3);
    q0/=norm; q1/=norm; q2/=norm; q3/=norm;
    qw=q0; qx=q1; qy=q2; qz=q3; /* *get quaternion  */
    yaw=atan2(2*q1*q2-2*q0*q3,2*q0*q0+2*q1*q1-1); // mpu6050_getRollPitchYaw
    pitch=-asin(2*q1*q3+2*q0*q2);
    roll=atan2(2*q2*q3-2*q0*q1,2*q0*q0+2*q3*q3-1);
    flag=1;
수정할 상수값이 두 곳입니다.
위 코드부터 보면
#define mpu6050_mahonytwoKiDef (2.0f * 0.1f) // 2 * integral gain
2.0f * 0.1f = 0.2 이므로 1/61에 곱하면 0.0032786885245901639344262295081967가 됩니다.
아래 코드는 0.5 에 1/61을 곱하면 0.0081967213114754098360655737704918가 됩니다.
타이머 주기를 20ms로 변경 한다면
61Hz는 50Hz가 되고
1/50=0.02
위 상수값은 0.02에 0.2를 곱하면 0.004
아래 상수값은 0.02에 0.5를 곱하면 0.01
동작시켜본 것은 아니니 참고하세요
조회수 1,300
센서HOME > 센서 > 전체 목록
