센서 > Ferrocen/MPU-9150 · GitHub
TODAY438 TOTAL2,278,974
BASIC4MCU | 센서 | 자이로센서 | Ferrocen/MPU-9150 · GitHub
작성자 키트 작성일2017-08-21 16:47 조회1,495회 댓글0건
 README.md
MPU-9150
This repository contains the source code of library for use with popular IMU sensors from InvenSense®as MPU-6500, MPU-6050, MPU-9150 and MPU-9250. Library based on "Embedded MotionDriver v5.1" and is designed for run on Atmel AVR 8-bit Microcontrollers with sufficient memory (FLASH memory size must be at least 32Kbytes and SRAM no less than 4Kbytes).
This code compiled by WinAVR (20121007) and tested on ATMega2560.
Processing demo file
At the  Processing/MPUAirplane  you can find a simple "Processing 2.1" sketch for visualizing the work with IMU sensors. Additional dependencies for ProcessingToxicLibs and OBJLoader libraries.
At the  Processing/FlightInstruments  you can find sketch with model of attitude indicator and directional gyro that simulates the earth’s horizon and сourse deviation indicator. This is a copies of the real flight instruments called an "Electric Attitude Indicator (Model: 4300)" and "Directional Gyro Indicator (Model: 3300)" by Mid-Continent Instrument Co.
Processing Demo
NOTE
This source code does not contain any filters prevent drift from y-axis (YAW).
조회수 1,495
센서HOME > 센서 > 전체 목록
