BASIC4MCU | 센서 | 온습도센서 | LM35-애노드 FND
작성자 키트 작성일2017-08-29 11:45 조회1,568회 댓글0건본문
////[lcd] [AVR PortE]//RS (pin4) ----- bit 0//RD (pin 5) ----- bit 1//EN (pin 6) ----- bit 2//사용안함 bit 3//DB4 (pin 11) --- bit 4//DB5 (pin 12) --- bit 5//DB6 (pin 13) --- bit 6//DB7 (pin 14) --- bit 7#include#include#include//unsigned char fnd_table[10]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};unsigned int adc_value, temp=0, fnd_cnt=0;char fnd_buf[4];//interrupt [TIM0_COMP] void timer0_comp_isr(void){ // 매치 인터럽트PORTA=0x0F;switch(fnd_cnt){case 0: PORTC=fnd_table[fnd_buf[0]]; PORTA=~1; break;case 1: PORTC=fnd_table[fnd_buf[1]]; PORTA=~2; break;case 2: PORTC=fnd_table[fnd_buf[2]]; PORTA=~4; break;case 3: PORTC=fnd_table[fnd_buf[3]]; PORTA=~8; break;}if(++fnd_cnt>3)fnd_cnt=0;}//void main(void){float temp_f;DDRA=0x0F; DDRC=0xFF;TCCR0=0x0D; OCR0=249; TIMSK=2; //16000000/ 64/(1+249)= 1000Hz=1msADCSRA=0xE7;SREG=0x80;while(1){delay_ms(1);adc_value=ADCW;temp_f=(float)adc_value * 1000.0 / 1023.0;temp=(int)temp_f;fnd_buf[0]=temp/1000;fnd_buf[1]=(temp/100)%10;fnd_buf[2]=((temp/10)%10);fnd_buf[3]=temp%10;}}
조회수 1,568등록된 댓글이 없습니다.
