BASIC4MCU | 센서 | 가스센서 | e2v Gas Sensor Evaluation Kits
작성자 키트 작성일2017-08-29 14:20 조회1,667회 댓글0건본문
Our evaluation kits offer a low cost way of getting started quickly in gas sensing. Using an evaluation kit can save months of development time and cost by providing a fully working PCB and software to drive and monitor the gas sensors of your choice.
Each kit is microprocessor controlled with a USB interface and comes complete with PC application software on CD for data logging and set-up. A universal mains adapter and USB lead is also provided. Gas sensors should be ordered separately.
Evaluation Kits are available for:
- Metal Oxide Semiconductor Gas Sensors (MICS-EK1)
- Infrared Gas Sensors (IR-EK2)
MICS-EK1: Evaluation Kit for Metal Oxide Semiconductor Gas Sensors
- Operates two 4 pin leaded sensors
- Operates one 10 pin surface mount sensor (single or dual) with additional adapter PCB (order separately)
- Automatic measuring of sensor resistance changes
- Automatic load resistor switching
- Settable heater drive levels
- Ambient temperature monitoring
- Provision for humidity sensor (customer fit)
- Expansion header for additional applications
Accessories
A set of 5 adapter PCBs to allow a 10 pin surface mount sensor (single or dual) to be used with the MICS-EK1 Evaluation Kit. Each board is pinned on the underside for plugging into the two sensor sockets on the Evaluation Kit. On the topside are pads for the user to solder down a 10 pin surface mount gas sensor.
METAL-OXIDE-KIT
A set of 3 Metal Oxide Gas Sensors for evaluation and experimentation: MICS-2610 (Ozone), MICS-2710 (NO2) and MICS-5521 (CO/VOC).
Downloads
User Guide (V1)
Firmware (V1.01)
PC Software (V1.0 available for download soon)
IR-EK2: Evaluation Kit for Infrared Gas Sensors
- Operates 6 or 7 pin (single gas) sensors
- Operates 8 pin (twin gas) sensors
- Calibrates sensors and monitors gas concentration levels
- Adjustable bulb drive voltage (3.0V to 5.0V)
- Adjustable reference and active channel gains
- 16 bit Analog to Digital Conversion (ADC) for reference and active channels
- Monitor gas sensor temperature on devices with integrated thermistor or IC temperature sensor
- PCB mounted temperature sensor IC provided for devices without integrated temperature monitoring
- Supplied with gas flow hood
Accessories
IR-GAS-SENSOR-KIT
A set of 2 Infrared Gas Sensors for evaluation and experimentation: IR11BD (CO2) and IR12BD (Hydrocarbons)
IR-TWIN-GAS-KIT
One IR15TT Twin Gas Sensor (CO2 and Hydrocarbons).
Downloads
Datasheet
User Guide (V1)
Firmware (V1.00)
ECVQ - EK3: Evaluation kit for Electrochemical and Pellistor gas sensors:
- For use with the e2v range electrochemical gas sensors
- For use with e2v pellistor/thermal conductivity gas sensors: Individual bead pairs, VQ500 series heads, VQ600 series heads
- Simple control and set-up of sensors
- USB interface to a Personal Computer (PC)
- Free PC application software for easy control and data logging
- Adjustable pellistor bridge voltage (1.6 V to 4.6 V)
- Adjustable electrochemical bias voltage (-700mV to +350mV)
- 16-bit Analog to Digital Conversion (ADC) for sensor outputs
- Calibrate sensors with linear response and monitor gas concentration levels
- Four configurable alarm outputs
- Two configurable analog outputs (12-bit DAC)
- Four digital inputs
- JTAG header for user software upload
- Supplied with universal mains adapter
- Supplied with user manual on CD
Accessories
JAS767906AA
Standard Gas Flow Hood for VQ500 series, Infrared mini-sensors and electrochemical (nonreactive
gas) sensors
JAS769638AA
Premium Gas Flow Hood recommended for reactive gases e.g. H2S, NO2, Cl2, ClO2, ETO
Downloads
조회수 1,667등록된 댓글이 없습니다.
